Old 06-27-2011, 01:07 AM   #3106
rai
Originally Posted by defcone View Post
You'll be right, just put some ca to stop it from delaminating.
Fuhh...what a relieve..Good to hear that.I guessed it was my fault too for being too lazy to ca glue the inner chassis as it was too much of a work...
Thanks again defcone
rai is offline   Reply With Quote
Old 06-27-2011, 01:31 AM   #3107
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
The Spec-R Diff blades seem to be working well... Nice hard plastic.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 06-30-2011, 01:18 AM   #3108
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
anybody got good stock "non-boosted" setups? 10.5 to 17.5T all will work. gettin really frustrated with the car as it would not generate nearly the same grip as the other cars in our competition. anything goes at this point ...just want to try different things.
thx
Infinity -- Orion ESC -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 06-30-2011, 04:12 AM   #3109
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Now we carry full yokomo parts.....hehehe
we are still putting more items into the website and also updating the shipping cost.
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-30-2011, 06:45 AM   #3110
defcone's Avatar
Trader Rating: 15 (100%+)
thx
I just run the setups found on petitrc.com, the asphalt base setup ronald volker posted ages ago works well everywhere. Mind posting what you are running atm? What tires, treatment...etc?
defcone is offline   Reply With Quote
Old 06-30-2011, 07:52 AM   #3111
Teddy's Avatar
From my setup experience with "no-boosted" class, you have to run with 4 equal spring (i use 4 HPI SILVER or 4 BLUE), 1.5° camber all around and a little longer wheelbase (1mm backward on rear suspension).
Use Mazda Speed body or LTC-R if you still miss corner speed.
Try and let me know.
thx
Teddy is offline   Reply With Quote
Old 06-30-2011, 02:19 PM   #3112
RAL
RAL's Avatar
This was my setup for 17.5 NT at this years ROAR Region 12 race on outdoor asphalt. It worked very well.
Old 07-01-2011, 01:28 AM   #3113
here is what i am running currently with the flex chassis plate. thx for the tips! keep em comin
Old 07-01-2011, 02:51 AM   #3114
kschu's Avatar
i was running similar setting like yours except, rear inner camber i run 0 shim and outer camber i run 0 shim too.
geardiff , i run 2000 oil now .
Old 07-01-2011, 06:57 AM   #3115
rai
Default Adding shims
Ran through all posts but cant seem to find the answer so apologies for the repetition (if it was discussed before). I ran through the setups on petitrc and found setups on low-medium grip track. What are the purpose of adding shims on the rear bulkhead such as 2mm and 1mm shims on the rear hub? Does it improve handling? Havent tried it yet but no harm to ask first.
Does it implies on the WX chassis too?
Many thanks
Old 07-21-2011, 01:59 AM   #3116
kschu's Avatar
bump up ~
Old 07-21-2011, 04:04 AM   #3117
Many thanks
from my humble point of view: shims on the rear bulkhead or on the rear outer hub, affect the camber change on the rear. the more the inner link is downward compared to the outer mount, the more camber change is made when forces are applied. also a shorter camber link gives more rapid camber change in general.
most of the guys run it like ronald nowadays with 2mm on the inside and 0.5mm on the outside with a short link.
in general my opionion is that the front camber links should be as closely as posible to being level. and the rear ones you want the inside mount to be roughly 0.5mm lower than the outside mounting position to give "perfect" camber change.
addition: if you increase both shims at both ends equally you will raise the "instant rollcenter" given you slightly more grip normally. (also depending on track conditions etc).
Old 07-21-2011, 09:14 AM   #3118
rai
I see. So adding shims do improve the grip at the rear and again this all depends on the track conditions. I will have a look and try different shim sizes to suit the local track here. Many thanks.
Old 07-21-2011, 01:35 PM   #3119
Default BD5-WX
Hi, I just took delivery a BD5-WX (I believe this is the latest iteration of the car). Before I break the factory seal, can somebody who purchased the kit tell me if there's also a ball diff included (it says it comes with a gear diff and spool) or any other extras. Chassis weights, aluminum spring retainers, different spring sets etc? Thanks.
Electro-MAX RC is offline   Reply With Quote
Old 07-21-2011, 03:55 PM   #3120
transplantlife's Avatar
Trader Rating: 43 (98%+)
who sells the BD 5 WX in the states?
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
