Old 05-24-2011, 12:52 PM   #3031
Lagunikas's Avatar
Hi all
I have some questions about WX kit
It comes with both chassis? solid and higt traction?
Comes with gear and ball diff? or only gear?
Xray T3 '11 // Nosram Pearl ISTC - X12 OctaWind - S9551
Tamiya F104 // Xerun 120A - GM Dr.Speed 17.5 - S9650
Mugen MRX4-R // Tekin RX8 - Tekin T8
Lagunikas is offline   Reply With Quote
Old 05-24-2011, 01:03 PM   #3032
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Lagunikas View Post
Hi all
Only gear diff and high traction chassis plate.
defcone is offline   Reply With Quote
Old 05-24-2011, 01:51 PM   #3033
WR version and WX have the same price, and WR comes with two chassis plates and ball and gear diff? Why they two have the same price?
ARC R11 - LRP Powered
Find RC news on: http://www.rcelectrico.es
Psycho_ is offline   Reply With Quote
Old 05-24-2011, 02:10 PM   #3034
Lagunikas's Avatar
Anyone can post the parts to upgrade WR to WX?
Old 05-24-2011, 06:49 PM   #3035
defcone's Avatar
the shopwhere you buy them from are the same price but on site theyre slightly different. the wx comes with steel spool cups as well
Old 05-24-2011, 06:52 PM   #3036
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
actually WR is special edition for japan market..but dunno why other place got sell it...
Give the best while u can !
kschu is offline   Reply With Quote
Old 05-24-2011, 10:21 PM   #3037
thankyou for your reply~
Originally Posted by luic View Post
Im not Ronald, but my setup is identical from your, with only a minor change in rear RC, i put 1 mm in and 0.5 out ( in camber link) or 2 - 0.5, when i need to react quicker i put a yokomo springs Green - pink, sometimes a litle thin oil.
In bumpsteer i always use 0 mm.
Greetings, Luis C.
I tested last night, change softer springs, 1 mm in and 0.5 out (in camber link), shock oil from 45 change to F40 & R35 and remove 2mm bumpsteer..
but still understeer very hard...................
Originally Posted by part-time racer View Post
I dont run a bd, but i would remove the front gear diff and run a spool. ?
ok, i will run a spool later..
Originally Posted by kschu View Post
maybe u can try LTC-R bodyshell, remove the 2mm bumpsteer, move forward your front wheelbase. use hpi pink spring infront
LTC-R make the car fast response in initial turn, in mid-corner i feel the car not stable but the laptime faster than speed6 body 0.2s..
Originally Posted by Yokomo_Ant3 View Post
Try 0.5-1mm ackerman shims, and definatly remove front gear diff and bump steer
ok, i will try it later~~
teamsanwa is offline   Reply With Quote
Old 05-24-2011, 11:08 PM   #3038
27Levin's Avatar
Send a message via MSN to 27Levin
Yes, BD5WX come with the steel spool cups and BD-201R8 - Steering Center Link 8mm.
WX new items is
BD-201P5 - BD5WX Steering Bell Crank Post 5mm
BD-202S5 - BD5WX Steering Bell Crank with Bearing ( Package come is one )
Also come with wide position rear sway bar
I think same as this one.
SD-412RS - Rear Sway-Bar Set
Yokomo parts in the US
Drift Speed.Com
[email protected]
27Levin is offline   Reply With Quote
Old 05-25-2011, 12:54 PM   #3039
Teddy's Avatar
Hi,
someone can tell me a good starting setup for BD5, very open track - Stock motor (13.5_fix timing)?
maybe somewhere on the web, like PETIT RC ones.
thanks
Teddy is offline   Reply With Quote
Old 05-26-2011, 09:59 AM   #3040
hacker's Avatar
Trader Rating: 141 (100%+)
I have the chance to pick up a new bd5 kit at a good price, but umming and eering whether I should pick up a WX instead. I race outdoor asphalt.
Does the standard bd5 come with a chassis that is good for indoor or outdoor? I'm assuming it's an indoor chassis as the new models come with a 2nd chassis for asphalt.
The 'Limited Edition' comes with graphite parts. Will I be able to tell the difference between bd5 standard parts and the LE parts?
Is the WR/WX, and even the 'worlds spec' that much better than the bd5, bd5LE?
hacker is offline   Reply With Quote
Old 05-26-2011, 01:57 PM   #3041
gregsbox's Avatar
Hi Can anyone explain how this part differs from the standard part ?
Bulkheads cap 3.5mm
When do we need to use it?
[YOKOMO] [XRAY] [SANWA] [TEKIN] [ALIGN] [JR]
www.thisisrc.com
www.thisisbluerain.com
gregsbox is offline   Reply With Quote
Old 05-29-2011, 08:04 AM   #3042
rai
Default Pro and cons?
Can anybody tell me the pros and cons between using ball head caps for the suspensions as found in the yokomo WX with the standard shock cap ball type that uses screws to hold the suspension(found / use in Yokomo drift package SD)? I know that using the ball head caps are more prone to detach during collisions...Any pros and cons?
rai is offline   Reply With Quote
Old 05-29-2011, 10:12 AM   #3043
"I tested last night, change softer springs, 1 mm in and 0.5 out (in camber link), shock oil from 45 change to F40 & R35 and remove 2mm bumpsteer..
but still understeer very hard................... "
Im sorry to hear this, but green-pink are harder, not softer.
I read a lot of times about Front pivot blocks 42.0 mm, roll more, i use it in some tracks and work best from 43.5 mm, but the front is more nervous.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 05-29-2011, 12:29 PM   #3044
Turbokisa's Avatar
the new ball cup that come with WX is much better...
kschu do you know part number of that ball cups? And ball studs same as in WR?
27Levin, is this parts have any differences in geometry compare with WR ones?
Russian Touring Masters
russiantm.com
Turbokisa is offline   Reply With Quote
Old 05-29-2011, 12:37 PM   #3045
Turbokisa's Avatar
Originally Posted by teamsanwa View Post
how can i solve these problems..? could you mind provide any suggestion for me?
teamsanwa, to increase steering try this:
1. Camber -1.5deg at rear.
2. Ride height 5.5mm at rear
3. Rear toe-in 2.5deg
4. Front pivot blocks FR42.0 + FF42.0
5. Double joint driveshafts at front
Try it step by step, not all at ones. =)
I hope this will help.
russiantm.com
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
