Old 04-22-2011, 07:13 PM   #2971
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Happy easter day everyone...
Give the best while u can !
kschu is offline   Reply With Quote
Old 04-23-2011, 10:00 AM   #2972
pcar951's Avatar
Trader Rating: 19 (100%+)
For all you guys running ECS style front drive shafts. The TC6 slipper spool fits easily in the BD5 with a little shimming. I ran the slipper spool all last carpet season, never broke a pin or bent a shaft. Might be worth a try if you're having problems.
pcar951 is offline   Reply With Quote
Old 04-23-2011, 01:22 PM   #2973
Hi, I have one question for Ronald:
- What is your opinion about hudy setup system?
alejandrospeed is offline   Reply With Quote
Old 04-23-2011, 05:41 PM   #2974
housey's Avatar
Having a little problem guys, wonder if you can help.
I've just installed the Roche lightweight axles and they seem to be a bit long, as in they push the bones towards the centre of the car. This now means that the driveshaft blades push up against the inside of my geardiff outdrives and it binds up the whole thing as well as squashes and damages the blades themselves.
Has anyone else come across this same problem?
Chris Swallow - Team Yokomo - GM Racing - Ko Propo
Donny Racing - http://donnyracing.yolasite.com/forum.php
Poweeeeerrrrr!
housey is offline   Reply With Quote
Old 04-24-2011, 03:34 AM   #2975
altreyx's Avatar
You too m8, and to all the other guys
Happy Easter!!
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 04-24-2011, 03:59 AM   #2976
VintageFrog1's Avatar
Trader Rating: 40 (100%+)
Happy Easter!!
Happy Easter Guys,
From Tom Erceg and all the guys at AERCCC Down Under
VintageFrog1 is offline   Reply With Quote
Old 04-24-2011, 06:02 AM   #2977
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
It wont be the Roche axles, the Yok blades just do that as they are such a soft plastic. You just have to keep replacing them frequantly. I went through sooooooooooo many at TITC haha.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-24-2011, 10:13 AM   #2978
SammyZ's Avatar
Trader Rating: 138 (100%+)
seriously? what ...do they break?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 04-24-2011, 10:53 AM   #2979
housey's Avatar
Well something isn't right as its binding up the whole differential action. It didn't do it with the original axles. I matched them up with original axles and the distance between the wheel hex pin hole and the u/j joint holes is definitely longer on the roche axles. Its bad enough that its squashing the blades out and I've never actually run the car. Obviously if I increase the camber so its positive it moves the driveshafts out and it all frees up again. So the problem is definitely the length of the roche axles.
Poweeeeerrrrr!
Old 04-25-2011, 02:13 AM   #2980
defcone's Avatar
Trader Rating: 15 (100%+)
Post
Well the obvious solution is to go back to yokomo axles
defcone is offline   Reply With Quote
Old 04-25-2011, 03:04 AM   #2981
defcone's Avatar
Post
Old 04-25-2011, 03:21 AM   #2982
housey's Avatar
Good point, but some people on here must be using the roche axles and I don't hear them having the same problem. So they are doing something different to me and I'd like to know what.
TBH the more I look at it the more I think its the blades, those things stick out a long old way from the end of the bone. I don't have any blades on the front so there's no issues there.
Does anyone know of any different blades that fit. Xray, Associated, Schui?
Poweeeeerrrrr!
Old 04-25-2011, 07:36 AM   #2983
defcone's Avatar
Maybe try filing some of the ends off.
Old 04-25-2011, 08:09 AM   #2984
I have similar problem, but with alu yokomo cardans, im sure are the blades. When compress the suspension, hits the bottom of diferential.
Normally, you can removed a litle material of blades, but this reduce the hardness, may reduce some material of the bottom of diff vessels, the Xray blades make good job, but the 3.5 mm (Ref. 30 5241).
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 04-25-2011, 08:42 AM   #2985
pcar951's Avatar
I'm using TC6 blades, just have to enlarge the pin holes slightly, they're more durable that the Yokomo blades. Wonder if the others that are using Roche axles are running wider arms/holders?
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
