Old 04-14-2011, 07:51 PM   #2941
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by luic View Post
Hello, this my setup for last weekend, at 1rd of National Race, the car work very good, in extremely hot weekend, i make TQ and finally 2º.
I need some tip, because only work with new tyres, with hot conditions and used tyres not work at all, the performance go down for about 0.4 - 0.6 s.
Is in low resolution format.
Regards, Luis C.
hi mate, is it your race is control tyres? sometimes i did notice using front block 42 + 42 create too more roll in front/traction thus making the rear will loose faster especially with old tyres..
if your not running control tyres, then maybe u can go for 36R tyres? or else u might need to change your setup due to the car loosing out during hot temp.
i saw u running 5000 oil at rear geardiff? share some comment bout it pls...the maximum oil i run at rear is 2000...never try 5000 tho...
Give the best while u can !
kschu is offline   Reply With Quote
Old 04-14-2011, 07:55 PM   #2942
kschu's Avatar
Originally Posted by VintageFrog1 View Post
Ha! Tell me about it! Mine is the same. As soon as the track temperature rises, my car turns to #$%^. Back rotates no matter what you change on it.
Maybe these BD5's just dont like hot weather and tires more than 5 laps old, lol. Absolutely pissing me off.
hi mate, maybe u can change something in your setup when heat build up on thetrack..like reducing the punch of your car as too much punch in hot temp will cause tyre spining alot and even make the car bcome very loose.
Old 04-14-2011, 08:49 PM   #2943
pcar951's Avatar
Trader Rating: 19 (100%+)
Regards, Luis C.
Just looked at your setup. Are you really saucing full front? I usually sauce about 1/2 front on my BD5. Have you temped your tires right after a heat? A couple of things I'd do right away: raise the front roll center, lengthen front wheel base, go to 1000 diff fluid. JMO, worth a try??
pcar951 is offline   Reply With Quote
Old 04-14-2011, 09:00 PM   #2944
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Regards, Luis C.
A few things I would try. Try the Yokomo springs again, always found these easier to drive in the heat and same lap times as HPI. Try Green/Pink or even Pink/Blue. Try arm sweep (43.5 FF block) working well for us atm down under, and test some lighter oil in your gear diff, try 2000 instead of 5000
HTH.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-15-2011, 07:37 AM   #2945
Thanks at lot for all responses guys, Jaco Blues are control tyre so i don´t can change.
Normally i use yokomo DOT 2 -3 (800-1000 wt) in rear diff, with good diff feeling, but when got hot, the retention diff effect are litle or nothing, i tested some greases, and 5000 with 60ºC in track are similar effect to ~1500-2000, the diff are before the heat at 35-40ºC room temperature.
I know, this effect change with diferent brands of oils, some are thicks, others thines.
In this track, with 42 front blocks i are 0.2 faster, i have to test arm sweep, and yokomo springs, take note.
Max temp of tyres, after heat, are 62-63ºC.
With lighter shock oil (30), i feeling more traction, but more degradation.
The car go very neutral, and easy to drive, even it not have enough grip, but i can not drive too fast.
Videos of final A: http://www.rcelectrico.es/videos/cam...-elche-final-a my car is number 1, Blue-Orange, in first final i use new tyres, in 2º final my tires go off, i don´t know why, (this tyres are from first heat), in 3º final, very bad luck and litle nervous. (we only have 3 set of tyres for all race, 2 in heats and another 1 in finals.)
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 04-15-2011, 10:39 AM   #2946
defcone's Avatar
Trader Rating: 15 (100%+)
Greetings, Luis C.
Did other cars slow down in laptimes as well?
defcone is offline   Reply With Quote
Old 04-15-2011, 10:31 PM   #2947
fastolfart's Avatar
luic
My tip is to try running the standard 40.5 or 41.5 rear arms.
The 39.5 arms are really for foam tyres or extreme grip.
It is so hard to fix the driver, but so easy to blame the car.
fastolfart is offline   Reply With Quote
Old 04-15-2011, 10:32 PM   #2948
kschu's Avatar
Originally Posted by fastolfart View Post
luic
i test 40.5mm and 41.5, it's gv the car slightly understeer...
Old 04-16-2011, 01:36 AM   #2949
Yes, Defcone, all cars slow down in terms of time, but i slow down a litle more compare with fastes guys, i need a litle change, when temp raise and tyres are used, (2nd -3nd battery), slow down litle less.
Today go to track, to test some things, take note all your tips, and test, but today is not than hot, with other day, 20º at 9:00.
Thanks, Luis C.
Old 04-16-2011, 02:33 AM   #2950
VintageFrog1's Avatar
Trader Rating: 40 (100%+)
Does anyone know the difference between the following parts:
BD-671
BD-630
Cheers
VintageFrog1 is offline   Reply With Quote
Old 04-16-2011, 02:47 AM   #2951
defcone's Avatar
BD-671
BD-630
Cheers
the 671 is a oneway whereas the 630 isnt.
Old 04-17-2011, 07:55 AM   #2952
[QUOTE=R.Völker;8923922]yes you should remove a bit material of the c-hubs (by knife is fine). plastic c-hubs dont break so easy compared to the graphite ones, so in case there is a track where you break a lot graphite c-hubs, you should switch to plastic.
Ronald,
Do the Low Vabration Front Universals really help in driving consistency? I was told that the car will understeer once the Front Low Vibrations CVDs are installed?
Also, does the Spec-r CVD last long?
Hope you could PM me for my querries.
I recently bought the Spec-r but I'm not sure if I'm going to onstall them.
Sanwa M11x/Tamiya 417x/Orion/Orca
jonp is offline   Reply With Quote
Old 04-17-2011, 10:56 AM   #2953
kschu's Avatar
[QUOTE=jonp;8976972]
Ronald,
do u mean specr double joint? If yes, u might need to change the pin to xray 1.5mm if u wan more durability from it. U also need to enlarge the c-hub hole Alittle to prevent any binding during Cornering....it will smoother out ur car in Cornering due to no chattering.
Old 04-17-2011, 02:00 PM   #2954
Nico''s Avatar
I bought Spec R double articulation drive shafts too but I have some problems:
- the hole in the the axle is not enough wide for 1.5mm pin
- drive shafts arrived with 3mm bearings but if I use these bearings, there is a play between bearing and pin.
So what to do please?
Nico' is offline   Reply With Quote
Old 04-17-2011, 04:55 PM   #2955
altreyx's Avatar
Regards, Luis C.
I can be wrong but try the ball diff at rear. If you loose your car with the gear diff nothing is better than to come back to use the ball diff. Gear diff is working well with a good grip. Anyway i never used it with an oil more than 1k, always between 700/1000
Also for me if your wheels are after a race at 60° means you are too much stiff as setup. Jaco Blue should be 32shore, Sorex 36 on our asphalt will stop to work at about 55/60°
Try to use a softer spring and may be a softer oil. My last race with a really hot weather (air temperature over 36°C) i went down from MM550 to a 450, i was having serious problem of grip due to the temperature. Losi40 is about 550 so some point less may be could you help too.
What kind of chassis are you using? W or WR?
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
