Old 04-11-2011, 09:32 PM   #2926
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Vitomon
front n rear use longer wheelbase...it's does give little more steering in some track...
use softer gdiff oil for more low speed steering...or thicker for high speed steering...
Give the best while u can !
kschu is offline   Reply With Quote
Old 04-12-2011, 12:46 AM   #2927
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
thx for the tips guys. i actually shortened the wheelbase in the front to get more steering. couldnt imagine why this would take away steering as it is supposed to make the car more aggressive. will revert the front wheelbase to standard kit position.
concerning the gear diff oil: i am using 1000cst oil but since there is always a little leaking, i would think the gear diff in the back, runs quite "smoothly". i will try a little softer oil like a 800 oder 700. our tracks here are usually not very high grip as they are a little dusty most of the time.
will report back after the weekend, after testing some more. hopefully the weather holds up
Infinity -- Orion ESC -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 04-12-2011, 12:52 AM   #2928
kschu's Avatar
what geardiff r u running now? spec-r or yokomo ?
both geardiff require to change new o-ring if leaking occur...i put green slime in the o-ring before assembling the geardiff...
Old 04-12-2011, 01:00 AM   #2929
i run the yokomo gear diff. the green slime is already ordered but has not arrived yet, will do that to the o-ring too to stop leaking.
maybe i will also try the good old balldiff, if it fits the conditions here better than the gear diff.
Old 04-12-2011, 01:26 AM   #2930
defcone's Avatar
Trader Rating: 15 (100%+)
what motor class you running?
defcone is offline   Reply With Quote
Old 04-12-2011, 01:42 AM   #2931
for the moment i run mostly 13.5T "0-boost" class. the second car is for modified. havent tried the modfied on asphalt yet. so the problems are largely in the 13.5T "0-boost" class.
Old 04-13-2011, 01:19 AM   #2932
kschu's Avatar
hmm...please try and update us here..
Old 04-13-2011, 01:38 AM   #2933
defcone's Avatar
I ran sore 36 with tweak additive was on warmer for fifteen minutes and I had too much steering. maybe you could give that a go, also you could try moving the rear wing forward what body are you using?
Old 04-13-2011, 03:23 AM   #2934
sofar no new results. have to wait for the weekend to put some practice sessions in if the weather stays good.
@defcone: i am currently using the profoform mazda6. i tried the speed 6 but it had less steering in my opinion. i will try the ltc-r which should give a good amount of steering.
as for the additive, i will try to get some tiretweak for the weekend.
Old 04-13-2011, 04:01 AM   #2935
kschu's Avatar
speed 6 should hv plenty more steering than mazda6..and ltc even hv more steering..
Old 04-13-2011, 03:16 PM   #2936
SammyZ's Avatar
Trader Rating: 138 (100%+)
whats the difference between the BD5 front one-way and the BD5W front
one way?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 04-13-2011, 08:13 PM   #2937
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
one way?
Bearings are flipped as the belt swapped sides between these models
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-14-2011, 01:48 PM   #2938
Hello, this my setup for last weekend, at 1rd of National Race, the car work very good, in extremely hot weekend, i make TQ and finally 2.
I need some tip, because only work with new tyres, with hot conditions and used tyres not work at all, the performance go down for about 0.4 - 0.6 s.
Is in low resolution format.
Regards, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 04-14-2011, 02:23 PM   #2939
SammyZ's Avatar
that makes sense thanks man
Hotbodies USA
SweepRacing USA
Old 04-14-2011, 05:13 PM   #2940
VintageFrog1's Avatar
Trader Rating: 40 (100%+)
Regards, Luis C.
Ha! Tell me about it! Mine is the same. As soon as the track temperature rises, my car turns to #$%^. Back rotates no matter what you change on it.
Maybe these BD5's just dont like hot weather and tires more than 5 laps old, lol. Absolutely pissing me off.
VintageFrog1 is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
