Old 04-04-2011, 02:39 PM   #2896
Ronald ¿What front and rear width typically used in asphalt? Thanks
conejero is offline   Reply With Quote
Old 04-04-2011, 07:59 PM   #2897
Thank you
Originally Posted by pcar951 View Post
I found my WR a little twitchy too, here's some things that I've done to calm it down:
- less front camber
- raise the front roll center (.5 or 1mm shims)
- move some weight forward
- heavier shock oil all around
I also took a little steering out with exponential, to tame it just off center. Hope it helps, worked for me.
dex410usa is offline   Reply With Quote
Old 04-05-2011, 05:35 AM   #2898
standard width (5.0mm hex) with 43.5mm suspension mounts front and 42./46.4 rear, but to be honest I didnt tested much with that
R.Völker is offline   Reply With Quote
Old 04-05-2011, 06:27 AM   #2899
- less front camber
Help me, 1.4 mm front sway bar, too.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 04-05-2011, 07:18 AM   #2900
ronald... what kind of track do u like most...? why...?
zamrioo2 is offline   Reply With Quote
Old 04-05-2011, 12:02 PM   #2901
pcar951's Avatar
Trader Rating: 19 (100%+)
Greetings, Luis C.
Shouldn't need a heavier front bar, you may lose steering on corner entry. I'm running TC6 1.25 (black) sway bars front and rear and the car is consistent through the corner.
pcar951 is offline   Reply With Quote
Old 04-05-2011, 01:22 PM   #2902
defcone's Avatar
Trader Rating: 15 (100%+)
- less front camber
What body are you using? You can try moving the rear wing a little bit rearwards.
defcone is offline   Reply With Quote
Old 04-05-2011, 01:42 PM   #2903
I'm missing 30 grams. ¿I ride the two front pieces
15 grams? ¿I put the steel fasteners for the part of
down to the chassis? ¿I put more weight to the center of the chassis?
¿I distribute around the chassis?
Old 04-05-2011, 03:21 PM   #2904
For me work well, especially when the grip going up, with a 1.3 front bar and 1.2 rear is sometimes a little nervous, of 1.4 bar has calmed down the front and loss of direction is insignificant.
Thanks, Luis C.
Conejero, donde has perdido el peso? ...
Old 04-05-2011, 06:43 PM   #2905
Could anyone kind enough to tell me what the bump steer setting on the setting sheet means?
What is the effect on handling if I put spacer there?
keithlaw is offline   Reply With Quote
Old 04-06-2011, 04:18 AM   #2906
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Default specR double joint shafts
hi guys,
i recently tried the spec-r double joint shafts for the bd5 in the front of course. performance on track is way better than with the standard shafts but i incurred a problem, maybe you guys can pitch in to help.
the shafts seem to touch the inner side of the c-hubs and on a slight touch or crash the c-hubs break very easily. i already used up 5 c-hubs in the last race meeting before the double joint shafts i used one c-hub for many months.
any ideas what could be the problem or any of you guys found a solution??
greets
v
Infinity -- Orion ESC -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 04-06-2011, 07:02 AM   #2907
I use the tips of cardan Roche lightened with originales.Gira shields to maximum and no shakes, is perfect and economical .
Luic ........ me faltan 30 grs para llegar al minimo
Old 04-06-2011, 09:52 AM   #2908
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
u mean u use Roche Lightweight Axle ?
Give the best while u can !
kschu is offline   Reply With Quote
Old 04-06-2011, 09:52 AM   #2909
kschu's Avatar
Originally Posted by vitomon View Post
hi guys,
greets
v
hi mate,
u need to enlarge the C-hub hole...
Old 04-06-2011, 12:22 PM   #2910
hi guys,
greets
v
yes you should remove a bit material of the c-hubs (by knife is fine). plastic c-hubs dont break so easy compared to the graphite ones, so in case there is a track where you break a lot graphite c-hubs, you should switch to plastic.
the two 15g weights are fine!
a sunny day on an asphalt track with medium or high traction is perfect but i do like carpet racing a lot, consistent track condition and often very challenging.
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
