Old 03-31-2011, 04:52 AM   #2881
Originally Posted by dameetz View Post
Ronald, do you usually use the 8mm steering center link? Also I ask this on last page regarding zero rebound shock, do you drill a hole on the top shock shaft to get zero rebound. I always see your car is using the longer rear stabilizer, what difference does it make compare to the stock one?
Thanks.
always 8mm center link because of more steering.
on carpet never, but sometimes on asphalt we are using a hole in the shock cap to get zero rebound as this feels easier and controllable to drive. recommend this more on low/medium traction.
about rear stablizer "kschu" was right..
R.Völker is offline   Reply With Quote
Old 03-31-2011, 04:53 AM   #2882
Originally Posted by ddd2k View Post
hi ronald what gear diff oil do you use?
I never tried dot 4 but like dot 1 on carpet as well. most of the time I use dot 2
Old 03-31-2011, 01:39 PM   #2883
VintageFrog1's Avatar
Trader Rating: 40 (100%+)
Whilst ojn the subject of gear diffs, I have noticed in some photos from the Tourer series that you are running Blue coloured outdrives for your gear diff, and not the standard silver outdrives that come supplied with the diff. Which model of car do the Blue outdrives belong too? I've been looking at replacing the standard items for various reasons including durability and clearance issues for the plastic blades.
VintageFrog1 is offline   Reply With Quote
Old 03-31-2011, 07:08 PM   #2884
dameetz's Avatar
Originally Posted by kschu View Post
According to Umino, the longer 'SD' style sway bar is a bit softer initially, and adjusts better to changes in surface condition, making it easier when setting up the car..
(from Team Yokomo)
Thanks for the info Ronald and kschu.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 03-31-2011, 09:29 PM   #2885
ronald...
1. why most of the time at asphalt u use camber front 1.5 rear 2.0... haven't u try f2.0, r2.5 or more/less...? need to know your feeling whenever u use other than f1.5 n r 2.0...
2. your favourite insert for sorex 36r at high temp track (noon)...? i was using speed mind medium grey but seem not work because always overheat my tire about 4-5laps...
thanc for relpy...
zamrioo2 is offline   Reply With Quote
Old 03-31-2011, 10:00 PM   #2886
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by zamrioo2 View Post
ronald...
thanc for relpy...
maybe u can use 40R sorex tyres since your race didnt control tyre...
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-31-2011, 11:25 PM   #2887
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Thats a prototype diff from before the actual gear diff was realeased. The Blue alloy is the same material as the ball diff outdrives if im not mistaken.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-01-2011, 04:20 AM   #2888
correct
Old 04-01-2011, 04:23 AM   #2889
ronald...
thanc for relpy...
1.personally I use 1.5° all around. Maybe in some sheets 2.0° is listed when Umino set the car but I have no explanation why to use 2.0° instead of 1.5°
2.I have no experience with non-controlled tires actually so I can not recommend anything,sorry!
Old 04-01-2011, 07:30 AM   #2890
Hello Ronald, thank you very much for your time, are very helpfull, well and Kschu, ... etc, thanks for your responses guys, this help a lot, more drivers around the world read here.
Ronald, next week is the 1st round of Nationals here, i run a setup pretty similar to your asphalt setup, i use 42.0 mm FF-FR, work best for me, sometimes change rear RC to 1 - 1 mm, instead 2 - 0.5 mm as you use in rear.
But sometimes i need more traction, especially when the heat gets too high, can you recommend to maintain traction? , hydraulic, additive ... i use MR+Xenon, with good results, ... the track is low grip, medium with water-sugar.
Thanks, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 04-02-2011, 04:25 AM   #2891
Thanks, Luis C.
which tires are you using? I do like CS tire max additive which is similar to MR,sometimes also "LRP asphalt".
If you have to run in hot condition maybe you remove tire warmers quite early before the start (10-15minutes). but its in general not easy to find good traction in hot condition if track hasnt that much grip
Old 04-02-2011, 04:31 AM   #2892
Hi Ronald,
In spain we use Jaco tyres (blue), and we also use the chassis of BD5-ws (not high-traction chassis)
alejandrospeed is offline   Reply With Quote
Old 04-03-2011, 01:43 AM   #2893
Thanks, i like CS, too, i testing with tyre warmes, yesterday the car have good feeling, easy to drive and very good traction, the temperature at track are 44ºC.
I hope, have same feeling next week.
Alejandro, prepare your car, see you next week .
Regards, Luis C.
Old 04-04-2011, 12:15 AM   #2894
Had my first run with the Yokomo! The car is super fast and tons of steering. I used Volker asphalt sorex 36 setup. I had only one problem the car was a bit twitchy for my liking is there a way to calm it down?
dex410usa is offline   Reply With Quote
Old 04-04-2011, 10:05 AM   #2895
pcar951's Avatar
Trader Rating: 19 (100%+)
I found my WR a little twitchy too, here's some things that I've done to calm it down:
- less front camber
- raise the front roll center (.5 or 1mm shims)
- move some weight forward
- heavier shock oil all around
I also took a little steering out with exponential, to tame it just off center. Hope it helps, worked for me.
pcar951 is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
