Old 03-27-2011, 05:57 PM   #2836
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by VintageFrog1 View Post
Hi
Ive got the bd5 and am using the standard Yokomo gear diff in the rear, with the standard cvd's, blades, and outdrives.
The problem i am facing at the moment is with the blades. The blades are not lasting at all. They wear out with a couple of runs, explode outwards, and then consequently the outdrives get chewed out.
Ive been shaving down/ modifying the back of the blade as it tells you to do on the small pamphlet that comes with the gear diff due to clearance issues with the the gear diff outdrives.
What would be be a good susbstitute to get around this issue?
I have been told to use team bomber blades, but im not sure if these will fit in the gear diff outdrives. Ive also been told to use shorter Tamiya 416 cvd's with standard yokomo blades to give more clearance to avoid modifying and therefore weakening the blades.
Thanks guys
What turn motor are you running? I have had the same problem, I just got pliers and compressed them then heating them with a lighter so that it was a really tight fit and that seemed to solve the problem.
defcone is offline   Reply With Quote
Old 03-27-2011, 11:02 PM   #2837
VintageFrog1's Avatar
Trader Rating: 40 (100%+)
Hi,
Im running in mod with a 4.5t speed passion.
I was told to do wohat you have advised also, but to put heat shrink around the blades. Doesnt feel too professional though
Ive gone and ordered a SPEC-R diff to see how things go, and will try some other mods too....
Cheers
VintageFrog1 is offline   Reply With Quote
Old 03-28-2011, 01:16 AM   #2838
defcone's Avatar
Hi,
Cheers
Yeah, when I ran mod the blades lasted me around 2-3 race meets. So around 12 races? Mod eats up consumables on your car like crazy, so you have to be prepared for that. Currently I think I'm running the 3racing blades that came with the sakura diff, can't be certain just found some blades in my parts box. They look beefier than my yokomo blades and they look to be stronger as they still look relatively new after one race in 17.5t.
Edit: I am running 44mm tamiya aluminum dog bones in the rear though, doesn't seem that 0.5mm could do much in prolonging blade life.
Old 03-28-2011, 02:43 AM   #2839
Default Spring rate in LBS
Hi!
Aonyone can help me with springs?
pink and blue?
What lbs values they have?
Thank you!
m
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 03-28-2011, 04:02 AM   #2840
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by M.Abramowicz View Post
Hi!
pink and blue?
Thank you!
m
Black - 14.50
Blue - 14.80
Yellow - 15.70
Pink - 16.26
Green - 17.00
Orange - 18.50
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-28-2011, 04:05 AM   #2841
Hi,
Cheers
Tom, Try some other blades, maybe we can try get some xray ones in there as they last forever! The Yokomo diff has very soft alloy, and the blades are also soft...its gonna chew out eventually. If you replace the outdrives, the problem will go away. But without changing blades will just happen again The Spec R diff is not as good as the Yokomo one (feel wise).
Antoni Caretti
Old 03-28-2011, 06:34 AM   #2842
hey guys,
signed up on rctech today. I would like to help as good as I can if needed.
But dont ecpect too much knowledge,lol
Ronald
R.Völker is offline   Reply With Quote
Old 03-28-2011, 07:02 AM   #2843
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by R.Völker View Post
hey guys,
Ronald
glad to see u here mate...
congratulation for dominating the TCM mod class..
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-28-2011, 07:10 AM   #2844
BigBellyCat's Avatar
hey guys,
Ronald
OMG!
BigBellyCat is offline   Reply With Quote
Old 03-28-2011, 07:40 AM   #2845
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
hey guys,
Ronald
glad to see you join rctech. looking forward to some good info
congrats on the latest TCM win.
first off i am looking for a good outdoor setup using sorex36 tires. any ideas?
greets
w
vitomon is offline   Reply With Quote
Old 03-28-2011, 08:17 AM   #2846
fuhh... after we lost martin... glad ronald come down here for pro support...
zamrioo2 is offline   Reply With Quote
Old 03-28-2011, 08:24 AM   #2847
pcar951's Avatar
Trader Rating: 19 (100%+)
hey guys,
Ronald
Welcome Ronald.
pcar951 is offline   Reply With Quote
Old 03-28-2011, 09:00 AM   #2848
jackdani's Avatar
hey guys,
Ronald
hi Ronald!
i think we all are very happy to have you here, too bad you did not join us earlier!
anyway congrats for all your recent wins and god luck with all the questions you will receive soon!
- Team Durando DNX408 v2
- Alpha a852 Lutz edition
- Runner Time fuel
- Sanwa m11x
- Pitshark.it
jackdani is offline   Reply With Quote
Old 03-28-2011, 10:29 AM   #2849
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
hey guys,
Ronald
Ronald,
what procedures do you take to prepare your car for a run/ between runs? Also, what tools and techniques do you use for set-up (Set-up station, camber gauge, droop over ride..)
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 03-28-2011, 12:26 PM   #2850
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by Owen RaCing View Post
Ronald,
Id like to know this as well
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
