Old 03-22-2011, 04:41 PM   #2821
What can you say about the wearing of parts like spool exit, blade, ball diff exit etc...
i m bored of my tamiya 416 who need always maintenance, so i m lookin for new car like a bd 5 ( or maybe an xray... ).
Manson is offline   Reply With Quote
Old 03-22-2011, 07:53 PM   #2822
How do you guys balance your bd5 car? The car does not have holes on the chassis.
dex410usa is offline   Reply With Quote
Old 03-22-2011, 08:16 PM   #2823
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
get the roche steel spool for front.
use spec-r / yokomo geardiff behind...
they can last u pretty long time before u need to replace them with new parts.
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-22-2011, 08:18 PM   #2824
kschu's Avatar
i file off a little bit the middle of shock tower front and rear...then use my tools (2.0mm, 3.0mm) to hold it up and see which side is heavier or lighter...just add or remove weight from there...
Old 03-22-2011, 08:27 PM   #2825
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
I drilled my own holes in the chassis so i could use the Hudy balance tools.
Shopkeeper is offline   Reply With Quote
Old 03-22-2011, 09:27 PM   #2826
defcone's Avatar
Trader Rating: 15 (100%+)
I just used the screw holes down the center if the chassis lol but lately I couldn't be bothered with balancing
defcone is offline   Reply With Quote
Old 03-23-2011, 04:45 AM   #2827
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
you so dodgy keefy
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-23-2011, 05:45 PM   #2828
pcar951's Avatar
Trader Rating: 19 (100%+)
+1
pcar951 is offline   Reply With Quote
Old 03-24-2011, 01:34 AM   #2829
university_dave's Avatar
The main chassis plate in our conversion kit has balancing holes
We tested the full conversion for the first time on Saturday back to back with a BD5W, unfortunately the timing at the track was intermittant all day so we were unable to collect any empirical data on lap times. The conversion did feel more responsive in quick direction changes and seemed to carry more corner speed, but these are only subjective impressions.
We have another test day with the conversion and a BD5W on Saturday at Moto Arena http://moto-arena.co.uk and will be running in the first round of a major UK series on the Sunday, so we should be able to gather some proper data.
We've taken some better photos, including some of the prototype motor mount and the chassis plate on its own, which are now up on our website at http://www.akularacing.co.uk/portfol...aracingar-01a/. We've also been working with our supply chain and can now include all the Photon parts to complete the conversion and have also managed to reduce the overall price slightly.
I'll let you know how we get on at the weekend, any comments or suggestions please let me know.
Tom Reynolds, Akula Racing Ltd
www.smc-racing.com
university_dave is offline   Reply With Quote
Old 03-26-2011, 11:01 PM   #2830
pcar951's Avatar
Anyone running the BD5 at the ROAR Carpet Nats?
Old 03-27-2011, 03:01 AM   #2831
VintageFrog1's Avatar
Trader Rating: 40 (100%+)
Hi
Ive got the bd5 and am using the standard Yokomo gear diff in the rear, with the standard cvd's, blades, and outdrives.
The problem i am facing at the moment is with the blades. The blades are not lasting at all. They wear out with a couple of runs, explode outwards, and then consequently the outdrives get chewed out.
Ive been shaving down/ modifying the back of the blade as it tells you to do on the small pamphlet that comes with the gear diff due to clearance issues with the the gear diff outdrives.
What would be be a good susbstitute to get around this issue?
I have been told to use team bomber blades, but im not sure if these will fit in the gear diff outdrives. Ive also been told to use shorter Tamiya 416 cvd's with standard yokomo blades to give more clearance to avoid modifying and therefore weakening the blades.
Thanks guys
VintageFrog1 is offline   Reply With Quote
Old 03-27-2011, 04:23 AM   #2832
kschu's Avatar
Originally Posted by VintageFrog1 View Post
Hi
Thanks guys
how many camber r u running at the rear? i did see running more than -1.5 camber will cause the blade to out quite fast....
Old 03-27-2011, 01:31 PM   #2833
Undertaker1's Avatar
Hello
I need some help.
I have two Geardiffs,1 Spec-R,1 Yokomo.
Both of them are extream leaking,what can i do?
Undertaker1 is offline   Reply With Quote
Old 03-27-2011, 01:34 PM   #2834
try to grease the orings with some green slime.
Originally Posted by Undertaker1 View Post
Hello
I need some help.
Old 03-27-2011, 01:38 PM   #2835
At the moment, im running -2.0 in the rear. Thats weird though, you'd think that you should be able to run -2.0 without issue without having to hop up the car
Ijm wondering if the combination of team bomber blades and a spec-r diff and outdrives would get around the issue.....
Cheers
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
