Old 03-16-2011, 12:59 PM   #2791
CanyonCarverR1's Avatar
Originally Posted by RAL View Post
The bearing holes fit tighter on the updated part. It will also help you get rid of those "chicken strips" They are in CA, you'll get the part in two days or so.
http://www.driftspeed.com/index.php?...oducts_id=1699
Yep, I've got that part. I was looking for the "refined steering bel cranks".
p.s. Driftspeed has perhaps THE best customer service of any R/C online store I've used, and I've used a few.
CanyonCarverR1 is offline   Reply With Quote
Old 03-16-2011, 01:10 PM   #2792
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
I think that is the refined part. Maybe the translation is a bit misleading. I will try to find out.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 03-16-2011, 01:13 PM   #2793
masterhit's Avatar
Trader Rating: 15 (100%+)
Originally Posted by ddd2k View Post
I had the same problem before so I end up using xray C-hub and steering block which I also converted to xray ECS to eliminate the chatter. The car width is the same.
Awesome info, thank you very much for putting that up. Does it matter which length of X-Ray ECS's are used?
Thanks!
Mike Slaughter
masterhit is offline   Reply With Quote
Old 03-16-2011, 01:18 PM   #2794
masterhit's Avatar
If they ever go "full line" I would be ecstatic..... And very broke....
Or even broker if they started carrying more Honda parts.....
Mike Slaughter
Old 03-16-2011, 03:39 PM   #2795
RAL
RAL's Avatar
Mike Slaughter
Yeah not too many Honda's in drifting. The GT500 cars look very tempting. They should be in stock soon. I think it could be a good class to bring down the cost of on-road for new people or racers on a budget looking for a "fun" class. If something like a Speed Passion Cirtix combo is used in the car, speedo and motor the cost would be around $300. And most people have stick packs from their 10th scale TC or off-road cars that will drop right in. No need for a 1s speedos or lipo packs. They are basically the Yokomo 1/12th scale cars with rubber tires and a gear diff. Keep in mind that design won the World Championship in 1/12th scale.
http://www.teamyokomo.com/jpn/index.htm
Especially this one, since you like Hondas:
http://www.teamyokomo.com/gt/lineup/hsv/gt5_hsv.html
Masami interviews Yokomo staff about the GT500 cars:
+ YouTube Video
GT500 with 17.5 on Yatabe Carpet Layout
+ YouTube Video
Old 03-16-2011, 03:42 PM   #2796
RAL
RAL's Avatar
Default GT500
And on indoor asphalt...
+ YouTube Video
Old 03-16-2011, 06:40 PM   #2797
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
Martin has posted on how to fix the steering slop if you are using the older stuff. I did this along with the plastic in the ball cup trick and have no slop in the steering.
Martin Hofer:
remove the 0.3mm shim between steering plate and steering plate holdes and replace it with a 0.1mm shim, put some ca into the holes of the steering plate where the flanged bearing goes in but let it dry before pushing in the bearing
this way you can take it apart if necessary
additionally:
put some (very small amount) ca on the steering posts, where the bearings of the steering plate holder are later, but first do the lower bearing, let the CA dry, push the bearing on, then put some ca on the area where the upper bearing will go, let dry and then push the steering plate holder along with the upper bearing on
place a 4*6*0.25mm spacer on top and screw it all back together
and tatatata you got a 100% slopfree steering
Shopkeeper is offline   Reply With Quote
Old 03-16-2011, 07:07 PM   #2798
Thanks!
Mike Slaughter
Both 52 and 50mm will fit but I can feel when the car bottoms down the 52 seems has some resistance on corners...the 50mm is the perfect fit.
ddd2k is offline   Reply With Quote
Old 03-17-2011, 12:16 AM   #2799
pcar951's Avatar
Trader Rating: 19 (100%+)
+1 Tony is great!
pcar951 is offline   Reply With Quote
Old 03-17-2011, 01:18 AM   #2800
Shopkeeper's Avatar
Finally got this resized so I could attach it, sorry for poor quality. Here is my setup I have been using that has been working very well for me. It got cut off in the notes but I am using the 2nd generation bd rear sway bar.
Old 03-17-2011, 02:53 AM   #2801
dameetz's Avatar
Do you make the 1.0mm hole on the shox cap to get zero rebound?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 03-17-2011, 02:57 AM   #2802
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
yes
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-17-2011, 06:38 PM   #2803
university_dave's Avatar
We've almost finished our chassis conversion kit for the BD5 and I wanted to share some initial photos and images with you all.
We've done some fairly major weight distribution changes, the motor moves a whole 4mm closer to the centre of the car, and the chassis is perfectly symmetrical side to side for completely even flex.
I'll be getting some better photos of the conversion up on Friday, but in the meantime have a look at http://www.akularacing.co.uk/portfol...aracingar-01a/ for some initial photos and CAD images.
Let me know what you think, We're pretty happy with the performance so far - really looking forward to testing the new motor mount this weekend.
Tom Reynolds, Akula Racing Ltd
www.smc-racing.com
university_dave is offline   Reply With Quote
Old 03-17-2011, 09:37 PM   #2804
defcone's Avatar
To be honest, 135 pounds sounds a bit steep for what you're getting. How much faster were the laptimes when testing with this new chassis when compared to the w? It's good though finally there are aftermarket parts for this car which isn't made by yokomo.
defcone is offline   Reply With Quote
Old 03-18-2011, 01:52 AM   #2805
At the moment we've not done comparative performance tests of the whole conversion with the BD5W - the prototype layshaft and motor mount only arrived this week. We're testing tomorrow so should have some empirical data after that.
As for price that will be pretty much worst case, we're currently working with our supply chain to try and get the price down as much as we can. We're also looking at including all of the Photon parts you need to complete the conversion (although not the bearings as most racers will have that size as spares) but that will depend on how much cost it will add to the conversion.
www.smc-racing.com
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
