Old 03-08-2011, 10:02 AM   #2731
SammyZ's Avatar
Trader Rating: 138 (100%+)
can someone measure the front of the BD5 chassis plate? Im talking about the nose. I want to see if the BD5 plastic bumper will fit the old BD/SD cars.
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 03-08-2011, 04:09 PM   #2732
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
I don't have the measurements here, but the bd5 front is much narrower than the bd, the will not directly interchange.
Shopkeeper is offline   Reply With Quote
Old 03-08-2011, 04:13 PM   #2733
Shopkeeper's Avatar
Originally Posted by dex410usa View Post
Thank you, do you know where can i get the toe blocks?
www.driftspeed.com
Old 03-08-2011, 06:14 PM   #2734
dbworms's Avatar
Still need help eliminating chatter... HELP!
dbworms is offline   Reply With Quote
Old 03-08-2011, 06:20 PM   #2735
housey's Avatar
You can't eliminate it without double joint driveshafts.
If you are only drifting then the Spec-R driveshafts might do you alright. I hear they aren't the best for racing, but just drifting shouldn't stress them out too much.
Chris Swallow - Team Yokomo - GM Racing - Ko Propo
Donny Racing - http://donnyracing.yolasite.com/forum.php
Poweeeeerrrrr!
housey is offline   Reply With Quote
Old 03-08-2011, 07:14 PM   #2736
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
get Litemodz !
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-08-2011, 07:26 PM   #2737
dbworms's Avatar
consider me a complete noob in this subject matter. I googled double joint drive shafts, but I don't see any parts that appears to fit the bd5.
I am running standard drive shafts that come with the bd5. I only had it for a few weeks and I assumed the chattering noise was from the low ground clearance and the hellaflush style wheel fitment scraping the body.
Old 03-08-2011, 08:33 PM   #2738
housey's Avatar
The chatter is because the standard driveshafts are what is called a universal joint. What this joint can't do is provide a constant rotational speed once the joint is at an angle. That means that the main bone is spinning pretty consistently while the drive axle is constantly accelerating and decelerating twice(?) every 360 degrees. As you can imagine this causes a great amount of G on the wheel when spinning really fast. This coupled with wheel imbalance and general slop causes a pretty big vibration or 'chatter'.
A true CVD (litemodz cvs) or a double cardan joint shaft (spec-r ecs) can rotate the axle and bone at the same speed consistently throughout the full 360 degree rotation at large joint angles. Therefore there is no acceleration and deceleration of the axle/wheel combo; this is why they remove the chatter vibrations.
Hope that helps. Ask away if there is anything else you need
Or if someone is real clever and I've said it wrong, feel free to me and put me right
Poweeeeerrrrr!
Old 03-08-2011, 08:50 PM   #2739
dbworms's Avatar
Thanks housey, I found the part you were refering to. The video from the spec r site and your explanation helped me understand the problem.
Old 03-08-2011, 08:50 PM   #2740
Shopkeeper's Avatar
Did you get new wheels?
I have been running the stock drives with a spool up front for almost a year and never had chatter at full steering. I am going to guess something else is going on. It is for sure chattering when you drive it on the ground right? It will probably chatter like crazy just sitting on a stand. I have seen the inside of some wheels hit the arm when turned, could that be happening? Have you checked your bearings to make sure you dotn have a bad bearing? Have you checked to make sure you dont have a bent axle?
Old 03-08-2011, 08:58 PM   #2741
kschu's Avatar
i think chattering only can be notice when u full throttle turning the wheel at full lock when the car is on car stand...
on ground , it's might not so noticeable BUT it's does reduce your car speed when u on/off throttle turning the wheel to full lock...
Old 03-08-2011, 09:29 PM   #2742
defcone's Avatar
Trader Rating: 15 (100%+)
[Smartass]technically if the axle is rotating isn't it still in acceleration?
defcone is offline   Reply With Quote
Old 03-09-2011, 01:49 AM   #2743
Originally Posted by Nico' View Post
thanks Sleepstream, I will try it because I almost always fing my BD5W has too much overall grip, especially rear grip.
Do you have the same feeling guys?
Yup had the same feeling. Funnily did something out of the ordinary last night.. Leaned the rear shocks to the 2nd lowest holes & swap the springs front to back (vice versa). Felt better..
Sleepstream is offline   Reply With Quote
Old 03-09-2011, 01:51 AM   #2744
Hugh Jazz's Avatar
Keefy cracking the Engineering jokes now.
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 03-09-2011, 01:56 AM   #2745
dbworms's Avatar
Was more of a bump than a crash, so the chassis is alright. As I see it running wheel-less on the stand, the axles and bearings look fine. The problem I'm experiencing is depicted exactly as it is on spec r's website. (look for C.V. Universal Swing Shaft (For YOKOMO BD5)) RCTech isn't letting me post the link
And yes as Kschu mentioned, it only happens on full throttle at full lock which is pretty often when drifting.
Noob question again, but does spools equal solid axles? I realized I do not have front one way pulleys up front. Only a solid axle set.
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
