Old 03-06-2011, 04:33 PM   #2716
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
I have that editable setup sheet from a few pages back. How is the best way to convert that to a size that I can attach to here.
Shopkeeper is offline   Reply With Quote
Old 03-06-2011, 05:41 PM   #2717
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by luic View Post
No, the track is not prepared, for this year the tyres are Jaco Blue control tyre, my setup is in attachment, i convert to low resolution Jpeg image for upload.
For this setup, now i go with Hpi silver all rounds and 0% rebound, and 3š toe-in in rear.
Greetings, Luis C.
I'd definitely go 3 deg. toe in in the rear instead of 3.5 when the grip goes up, I found that with my 17.5t car it was around 0.1 a lap on average when I dropped from 3.5 to 3 degrees.
Your droop settings, is that 5.5 front and 4.5 rear when u measure from the bottom of the a-arms? I found that running less droop when grip is high tends to give more corner speed, maybe try the religious 6front/5rear droop that most people seem to run.
When you say your car is slow, how is it actually slow?
defcone is offline   Reply With Quote
Old 03-07-2011, 01:09 AM   #2718
dbworms's Avatar
Hello guys. Need some help trouble shoot my bd5.
After my BD5 suffered some heavy bumps against the wall recently, I took apart the suspension area to check for damage and the chassis appears to be fine.
But once I mount the wheels, there's the terrible sound of the belt griding somewhere around the steering mechanism but only when full lock is applied on either direction. Once, I take the weeks off, I don't see any abnormal behavior at full steer lock.
I also notice that the wheels are slightly bent and off balance. Will this be cured with a new set of wheels, or is something in the steering mechanism grinding the belt drive?
Any tips would be much appreciated. Thanks,
dbworms is offline   Reply With Quote
Old 03-07-2011, 01:42 AM   #2719
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
it's called chattering...only happen during cornering...
can be solve by use double joint U. Joint.
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-07-2011, 02:22 AM   #2720
dbworms's Avatar
Thanks kschu for the tip. Can you point me to an appropriate part that fits the bd5? Or do all tc universal joints fit?
Old 03-07-2011, 02:28 AM   #2721
defcone's Avatar
What motor class do you run?
Old 03-07-2011, 03:05 AM   #2722
dbworms's Avatar
Hello defcone,
I do not run a particular vehicle class as I use my car for drifting. I am running a 11t brush motor.
Old 03-07-2011, 03:38 AM   #2723
defcone's Avatar
Hello defcone,
Oh for drifting won't you be using a oneway or diff up front and spool rear? With the diff up front there wont be any chatter.
Old 03-07-2011, 05:16 AM   #2724
dbworms's Avatar
Yes, I am using a front one way, rear spool setup. I don't have the problem with the wheels off. Only when I mount the (admittedly off balance) wheels which I find odd.
Old 03-07-2011, 01:01 PM   #2725
Thanks for responses, Arn0 make a hard work for me :http://www.petitrc.com/reglages/yoko...102/index.html
I use 6/5 mm droop, and 3š toe-in, with same results. I need to test roll centers how say pcar951.
Shopkeeper, thanks i read later, but Arn0 go to rescue me.
Defcone, yes i use 3š now, but in this first test i donīt have the rear pivot block, i slow to 0.2-0.4 for lap, very consistent but litle slow, generally due to a slight loss of steering.
Thanks, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 03-07-2011, 01:22 PM   #2726
Shopkeeper's Avatar
Thanks, Luis C.
I will check the link when I get home, thanks
Move your steering links to outer hole it will be better
Old 03-07-2011, 01:43 PM   #2727
Nico''s Avatar
Originally Posted by Sleepstream View Post
Yup it's put under the suspension mount to increase the rollcenters. It's easier then fiddling with 0.5mm or 1.0mm shims.
thanks Sleepstream, I will try it because I almost always fing my BD5W has too much overall grip, especially rear grip.
Do you have the same feeling guys?
Nico' is offline   Reply With Quote
Old 03-08-2011, 01:26 AM   #2728
how to change rear toe on the bd5?
dex410usa is offline   Reply With Quote
Old 03-08-2011, 02:00 AM   #2729
defcone's Avatar
Different rear toe blocks, with 2.0 front, 7.1 gives 3.5deg, 6.4 gives 3deg, 5.7 gives 2.5deg.
Old 03-08-2011, 09:48 AM   #2730
Thank you, do you know where can i get the toe blocks?
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
