Old 03-04-2011, 12:14 AM   #2701
where can order sway bars in the usa for the bd5???
dex410usa is offline   Reply With Quote
Old 03-04-2011, 12:42 AM   #2702
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
http://www.driftspeed.com/index.php?...f83d7fe87d9488
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 03-04-2011, 08:23 AM   #2703
Thank you but why so much for shipping?
Old 03-04-2011, 08:42 AM   #2704
masterhit's Avatar
Trader Rating: 15 (100%+)
If you get in touch with them they can usually set you up with priority mail shipping which reduces the price drastically.
They are some of the nicest and most accommodating people you will ever deal with in this hobby.
Mike Slaughter
masterhit is online now   Reply With Quote
Old 03-04-2011, 08:47 AM   #2705
Great will call them today. Thank you
Mike Slaughter
Old 03-04-2011, 11:29 AM   #2706
Lost Aggresiva's Avatar
Mike Slaughter
+1 on that. Just wish I could get all my RC stuff through them.
Bill D.
Lost Aggresiva is offline   Reply With Quote
Old 03-04-2011, 11:31 AM   #2707
Nico''s Avatar
Hi guys,
I wonder about the use of this part: suspension arm mount spacer ref [YOK-BD-301S]
http://www.teamyokomo.com/jpn/partsl...s_bd_301s.html ?
is it to rise the roll center?
Is it useful or not please?
Kschu, I'm waiting for my Asso greenslim for my Yor gear diff, can I use it too between the two parts of the gear diff case,because my rear gear diff leaks a little bit from this way?
I would like to change the gear diff O ring two, can I buy it alone and not all the maintenance kit?
thanks a lot,
Nico'
Nico' is offline   Reply With Quote
Old 03-04-2011, 11:12 PM   #2708
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by Nico' View Post
Hi guys,
thanks a lot,
Nico'
my geardiff no more leaking after using the greenslime in the o-ring...but it;s only last for 1 race...and u need to service it again...
and also after i switch to Yokomo geardiff super flex oil, my diff work even more smoother...
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-04-2011, 11:19 PM   #2709
Nico''s Avatar
Thanks Kschu,
I dont' find where to buy the Yokomo geardiff super flex oil, can you give a link please?
Nico'
Old 03-05-2011, 04:38 AM   #2710
Hi guys,
Is it useful or not ?
thanks a lot,
Nico'
Yup it's put under the suspension mount to increase the rollcenters. It's easier then fiddling with 0.5mm or 1.0mm shims.
Sleepstream is offline   Reply With Quote
Old 03-06-2011, 12:47 AM   #2711
pcar951's Avatar
Trader Rating: 19 (100%+)
A few posts back I was complaining that my TC was feeling "floaty" on the track (carpet). Well, I've been working with my BD5WR for a month now. I was looking to get a more "direct" feel out of the car and was struggling a bit. I've finally got the car to stay flatter in the corners without losing grip and it now feels more planted overall. Here's what I've done unlike other posted setups... if anyone's interested:
- Associated 1.25 sway bars front and rear
- raised front and rear roll center .5mm (under blocks)
- lengthened wheel base in the rear 1mm
- Associated 35wt (cst425?) front and rear
- reduced front droop to 6.6
- reduced rear droop to 5.4
It doesn't look like much but, these few changes transformed the car for me and made handling far more precise, the rest of the setup is basically box stock. Hopefully this will be helpful and time saving to others.
pcar951 is offline   Reply With Quote
Old 03-06-2011, 12:58 PM   #2712
Pcar51, thanks. What tyres do you use ?.
We run outdoor, the tracks here are low grip, in the morning the car are excelent, normally faster, but when the grip go up and temperature, the others drivers improve the performance of his cars, and my car and other Yoko not improved, normally with this good first heads, classified for A-main, but in finals i don´t know what i need to change for maintain the good performance of the car, i only have a car 2 months but i drive more years with other brands.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 03-06-2011, 01:23 PM   #2713
pcar951's Avatar
Greetings, Luis C.
We run Jaco blues as the spec tire for our indoor series.
Low roll centers and lots of droop are OK for my BD5 when the grip is low. But as you said, when grip comes up the car gets lazy and loses corner speed unless you make some changes. The biggest difference for me was higher roll center and less droop. Might be worth a try in the afternoons at your track.
Old 03-06-2011, 01:34 PM   #2714
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
Greetings, Luis C.
Is your track prepped with anything? What tires are you using? Can you post your setup?
Shopkeeper is offline   Reply With Quote
Old 03-06-2011, 02:20 PM   #2715
No, the track is not prepared, for this year the tyres are Jaco Blue control tyre, my setup is in attachment, i convert to low resolution Jpeg image for upload.
For this setup, now i go with Hpi silver all rounds and 0% rebound, and 3º toe-in in rear.
Greetings, Luis C.
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
