Old 02-26-2011, 02:26 AM   #2671
Nico''s Avatar
thanks altreyx ;-)
Nico' is offline   Reply With Quote
Old 02-26-2011, 02:57 AM   #2672
Nico''s Avatar
Hi guys,
I have a Yokomo gear diff but I don't like the ring a lot and I would like to know if I can use Spec R rings instead of Yokomo rings, I would like to use these rings: http://www.rc-mushroom.com/product_i...ducts_id=21275
Do you know if it's possible please?
Old 02-27-2011, 11:37 AM   #2673
Nico''s Avatar
And I would like to change my Wheel Hub Pin but I don't find them in the part list (only sold with Wheel Hub so it is expensive for a pin) ?
Do you know where I could only get these pins please?
Old 02-27-2011, 06:29 PM   #2674
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Nico' View Post
Hi guys,
The Yokomo O-rings are larger I.D. I have both... not interchangeable.
pcar951 is offline   Reply With Quote
Old 02-28-2011, 12:36 AM   #2675
university_dave's Avatar
And I would like to change my Wheel Hub Pin but I don't find them in the part list (only sold with Wheel Hub so expensive) ?
The Xray wheel pins (980210) are the same length but don't have a rounded end, so I've used a dremel to round off the ends enough for them to fit.
Tom Reynolds, Akula Racing Ltd
www.akularacing.co.uk
www.smc-racing.com
university_dave is offline   Reply With Quote
Old 02-28-2011, 01:35 AM   #2676
Nico''s Avatar
Thank you pcar951, between Yokomo and Spec R diffs which one leaks at lest please?
Tanks university_dave , I will try it with my X ray pins, a friend has also sent me and address where to buy it only , it is: http://banzaihobby.com/index.php?mai...sort=2a&page=2
Old 02-28-2011, 02:49 AM   #2677
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
my gdiff stop to leak after i apply some green slime on the o-ring...
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-28-2011, 02:53 AM   #2678
Nico''s Avatar
green slime by Associated?
Old 02-28-2011, 03:04 AM   #2679
kschu's Avatar
yes...
please try the new geardiff oil from Yokomo....it's totally different from the normal geardiff oil...it's brown colour and smell engine oil,...
Old 02-28-2011, 08:10 AM   #2680
pcar951's Avatar
The Yokomo leaks a little less.
Old 02-28-2011, 09:18 AM   #2681
Nico''s Avatar
I did it and it works perfectly! thanx
Old 02-28-2011, 05:35 PM   #2682
Nico''s Avatar
Hi,
When you use the outer hole of the steering block, do you use the same turnbuckles please?
because I think the plastic rods are almost not screwed and it seems to be very fragile?
Old 02-28-2011, 06:32 PM   #2683
defcone's Avatar
Trader Rating: 15 (100%+)
Hi,
If you are using the correct one which is meant for the steering link, you will be fine. I have been running mine for about half a year and no problems.
defcone is offline   Reply With Quote
Old 02-28-2011, 06:40 PM   #2684
kschu's Avatar
Hi,
8mm centerlink + outer hole need to use longer turnbuckle rod or u might risk the turnbuckle take off if someone hit u hard from side...
Old 02-28-2011, 07:02 PM   #2685
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
Hi,
Been running mine like that and havent had any problems yet.
Shopkeeper is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
