Old 02-19-2011, 11:22 PM   #2641
dameetz's Avatar
How do you guys find the steering throw on BD5? Mine has 28deg full lock, and I find it has a bit lack of steering to my liking. The new TRF417 got up to 30degs steering throw, when I tested a friend's TRF, the steering is abundant. If you have any method of increasing the full steering lock, pls advice me. BTW at the moment I m using the optional 8mm steering plate.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 02-20-2011, 01:21 AM   #2642
altreyx's Avatar
If you aim to have more steering try to reduce the rear toe-in if, normally i use 3° sometimes 2,5° and car is very nice. Also depend a lot on your setup. For my experience have a lot of steering doesn't mean to have a car able to turn better.
Normally on my car i have 26/27°deg sometimes reduced at 20 (more or less)
Instead if you really want really a car with more than 30° of steering i can't help you, for me is not necessary
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 02-20-2011, 06:13 AM   #2643
dameetz's Avatar
Thanks for replying. I have already install 2.5 deg rear toe block. My local track has lots of slow 180 deg corners. Thats why i want more steering. The Trf with 30degs steering throw clearly has an advantage over my car. They can easily dive in speed into the corners while i have to brake early to make the corners.
Anyway i ll try to find more steering using set up again.
Old 02-20-2011, 12:38 PM   #2644
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
hi guys,
are there any 4mm wheel-hex that fit the bd5?? standard kit ones are 5mm right?
cheers
vitomon is offline   Reply With Quote
Old 02-20-2011, 03:34 PM   #2645
jackdani's Avatar
hi all,
i have a question for you,
my car is really nice and fast but how do i get more steering??
thanks
- Team Durando DNX408 v2
- Alpha a852 Lutz edition
- Runner Time fuel
- Sanwa m11x
- Pitshark.it
jackdani is offline   Reply With Quote
Old 02-20-2011, 10:29 PM   #2646
dameetz's Avatar
Originally Posted by jackdani View Post
hi all,
thanks
I m having the same issue as you too. I was advised to reduce the rear toe, put on harder rear sway bar and maybe raising the rear roll center. I have yet to try the set up though, maybe this weekend.
Old 02-21-2011, 12:17 AM   #2647
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hi all,
thanks
how many more u need?
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-21-2011, 01:35 AM   #2648
jackdani's Avatar
As dameetz said i m in the same situation.. My local track is very tecnical and in 180* turns i lose really a lot from other cars because if i do not slow down more than the orbers i m out of the turn!!
This is pretty sad because for the rest the CAR locks good!
I do not know exactly how many degrees more i do need but for sure i need them even considering that on the radio everything is at maximum and that i use the same servo i used on the previous car!
8mm link will help?
Will help reducing the play on the steering mount??
- Runner Time fuel
- Sanwa m11x
- Pitshark.it
Old 02-21-2011, 01:43 AM   #2649
jackdani's Avatar
And has anyone tryied the gear diff on the front? Is it possibile?!
Yesterday at the race i saw two trf 417 with spec e in the front!
- Runner Time fuel
- Sanwa m11x
- Pitshark.it
Old 02-21-2011, 06:19 AM   #2650
kschu's Avatar
8mm link will help?
8mm sure will help
im running geardiff for front now for bashing on parking lot...but im not sure if it's suitable for other track..
Old 02-21-2011, 09:53 AM   #2651
Hi, I have a Yok mr4 tc-mini I need parts for ( seeing as how Yok usa is no longer selling parts)- where do I get parts? Thanks, Don
DLS II is offline   Reply With Quote
Old 02-22-2011, 05:06 AM   #2652
Bump!
Old 02-22-2011, 09:32 AM   #2653
kschu's Avatar
sorry, i dont have idea where to find the parts..
Old 02-22-2011, 09:48 AM   #2654
Beans! I used to get them from Yokomo USA. Yesterday when I tried to order, it went to a page that said they had stopped selling parts as of Dec. 31, 2008. I find it hard to believe that there is no parts support!!! Don
Old 02-22-2011, 11:56 PM   #2655
Originally Posted by vitomon View Post
hi guys,
cheers
anybody??
will tamiya 4mm wheel hex fit?
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
