Old 02-10-2011, 11:56 AM   #2626
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Best of luck Martin!
http://www.redrc.net/2011/02/martin-...to-schumacher/
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 02-10-2011, 01:56 PM   #2627
altreyx's Avatar
Good luck Martin!, thank you for your tips/suggestions about Yokomo since the old BD. They helped me a lot and i think many other people too.
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 02-13-2011, 02:43 PM   #2628
Trader Rating: 25 (100%+)
I have a BD5W forsale in the forsale thread
matt rem is offline   Reply With Quote
Old 02-13-2011, 03:33 PM   #2629
RC MARKET's Avatar
RED RC had upload A Final round 2 video !
RC MARKET is offline   Reply With Quote
Old 02-17-2011, 01:14 AM   #2630
OZDC's Avatar
Trader Rating: 16 (100%+)
Default Anyone had this problem?
Guys,
Has anyone else had the wear shown in the pic.
Its the underneath of the rear shock mounts.
It would appear that the pin from the drive shafts is hitting the block.
I have had some times where the car will suddenly spin for no reason on high speed corners and suspect this may be why.
It has happened on both sides but is more prevalent on the left.
I'll try grinding it down so there is plenty of clearance but I was wondering if anyone else had this problem, what it did to the car and how they resolved it.
thanks
DC
OZDC is offline   Reply With Quote
Old 02-17-2011, 01:16 AM   #2631
kschu's Avatar
Send a message via MSN to kschu
Originally Posted by OZDC View Post
Guys,
thanks
DC
Because your rear diff position u put to high....if u put to low position, it's should not happen..
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-17-2011, 01:59 PM   #2632
OZDC's Avatar
Ahh,
That makes sense.
I'll have a look.
Thanks a lot
DC
Old 02-17-2011, 02:43 PM   #2633
Nico''s Avatar
with aluminium rear drive shafts, I had the pins which went a little bit out of the bones, but not totally, which could damage as you showed us.
Nico' is offline   Reply With Quote
Old 02-17-2011, 07:15 PM   #2634
OZDC's Avatar
Thanks Nico,
They are steel shafts and the pins sit pretty flush with the blades
DC
Old 02-17-2011, 07:17 PM   #2635
kschu's Avatar
Thanks Nico,
DC
it's could be happen too even with steel dog bone...have u check your rear diff position ?
Old 02-17-2011, 07:45 PM   #2636
OZDC's Avatar
Not yet, I'm in the middle of a major rebuild.
Although I think you may be right.
I never thought of the cams changing the diff height, just the belt tension.
I'm not in front of the car now to check.
Are you meant to be able to adjust the belt tension with either a low or high diff. Or by setting the belt tension loose, am I raising the diff?
thanks
DC
Old 02-17-2011, 07:49 PM   #2637
kschu's Avatar
thanks
DC
yes, u able to adjust the belt tension with either low or high diff position.
hope u can solve the problem and enjoy the ride soon..
Old 02-18-2011, 12:58 AM   #2638
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
had that problem too, in my case it was the high diff position.
another question: i am currently running the kit-shocks with the black damper membrane. i was wandering if there are other pistons than the 1mm that come witht he kit. are there any 1.1mm pisonts available for the bd5 dampers?? or will the tamiya 1.1mm pistons fit into the dampers??? any suggestions other than drill the 1mm to 1.1mm??
thx for the help guys.
vitomon is offline   Reply With Quote
Old 02-18-2011, 01:35 AM   #2639
dameetz's Avatar
Originally Posted by Martin Hofer View Post
Tamiya and HB pistons fit BUT SHALL NOT BE USED!
The Yokomo shock body features a bigger inner diameter so if you use a tamiya piston the shock will get too soft as too much oil passes around the outside gap!
unfortunately that is not the same.
Try to get a 1.10 drill from somewhere
The answer is above. I m in the same situation as you, still looking for 1.1mm drill bit in my local area, if I cant find it I might order on ebay. Also read a few pages back,someone posted a link to an online hardware shop which sells 1.1mm drill bit.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 02-18-2011, 02:00 AM   #2640
kschu's Avatar
get a drill bit 1.1mm and drill the piston...
tamiya or other piston is not recommended to be use in bd5 shock...
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
