Old 02-06-2011, 08:38 PM   #2596
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by pcar951 View Post
Can someone tell me how using the inside hole on the steering block affects handling? Looks like it'd be less ackerman??
yeah,,,less angle too...
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-07-2011, 02:17 AM   #2597
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by daleburr View Post
The Tamiya TRF ones are a perfect fit, been using these in my BD for the past year.
Tamiya and HB pistons fit BUT SHALL NOT BE USED!
The Yokomo shock body features a bigger inner diameter so if you use a tamiya piston the shock will get too soft as too much oil passes around the outside gap!
Originally Posted by university_dave View Post
As pack isn't an issue with touring cars if you're really struggling to find a 1.1mm drill bit you could drill 1 hole out to 1.5mm and leave the other two at 1.0mm as it makes the average hole size 1.17mm.
I'd still rather get a 1.1mm drill bit though.
unfortunately that is not the same.
Try to get a 1.10 drill from somewhere
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 02-07-2011, 02:18 AM   #2598
using the inner hole on the steering block makes the car loose a lot of steering but also greatly reduces the risk to traction roll
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 02-07-2011, 08:03 AM   #2599
Trader Rating: 14 (100%+)
KSCHU:
Greetings
YHPM
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 02-07-2011, 08:32 AM   #2600
kschu's Avatar
Roche version 2 spool for yokomo Bd5 (spool cup made from spring steel)
Old 02-08-2011, 04:45 AM   #2601
Yokojojo's Avatar
Default Hmmmmmm
Originally Posted by Yokomo_Ant3 View Post
Drove my Yokomo yesterday for the first time in ages. Im happy Looking forward to racing it at TITC now. Now to get a WR chassis or not is the question
Hi Bro , i wouldnt ....you will have toooooo much grip but buy one for our track anyway
Serpent 411 TE * Orion R10 Pro * Pro Amps * Dualsky * AE B4/B44 *
Associated TC6 now like a shark * Reedy * ProAmps * Hobbywong * Thunderpower
McKune Design FGX * F201 carbon * F103GT Jaguar XJS14 niiice * T.O.P F1 coming soon
Yokojojo is offline   Reply With Quote
Old 02-08-2011, 01:20 PM   #2602
Nico''s Avatar
Hi,
I wonder if a front gear diff could be a good choice with 10,5 turns motors to have more corner speed?
what oil should I use, 100 000, 200 000 or more?
thanks,
Nico'
Nico' is offline   Reply With Quote
Old 02-08-2011, 01:32 PM   #2603
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally Posted by Nico' View Post
Hi,
thanks,
Nico'
i ran the gear diff in front on my photon with good results , use at least 100,000 in the front and about 10-15,000 in the rear.
Old 02-08-2011, 01:40 PM   #2604
Nico''s Avatar
Hi,
thanks, I have 100 000 and 300 000, what is the best to try first please?
Old 02-08-2011, 01:48 PM   #2605
Super Moderator
Marcos.J's Avatar
Hi,
100,000
Old 02-08-2011, 02:00 PM   #2606
Nico''s Avatar
why 100 000 instead of 300 000 please?
with 100 000 it's more a diff and with 300 000 it's closer to a spool?
Old 02-08-2011, 06:04 PM   #2607
kschu's Avatar
i notice lower cst of oil for front make the steering too much....my next trial will be using 350k cst oil for front gdiff...
hope this weekend is not raining....\
Old 02-08-2011, 07:01 PM   #2608
Kschu:
Hi,
YHPM
Old 02-08-2011, 07:09 PM   #2609
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
For the Yokomo/spec R diff, you will need at least 300k in the front or under high speed brakes the car will feel very unstable. For slower classes you might get away with a bit lighter. And you will never go away from 1000-3000 in the rear.
HTH,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 02-08-2011, 08:58 PM   #2610
kschu's Avatar
HTH,
Antoni
hope can try it soon...but i'm using 2000 for rear now...cant wait for the yokomo diff oil to release as it's different from the oil we using now...
it's specially made for the use on geardiff....
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
