Old 02-01-2011, 05:06 AM   #2566
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by fpart View Post
Hanulec How did you do at the birds? If you are using he Yokomo knuckle with the xray C-hubs, you need to use the xray bottom cylinder and use the normal top cylinder if I remember correctly. You may have to grind the knuckles to get the steering throw. I am using the Xray knuckle so I can't be sure.
Thanks tom.
Everything went well until round 4 and then my amain hopes in TC stock and superstock disappeared.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-01-2011, 07:09 AM   #2567
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Default setup help
hi guys,
i was testing the bd5w on our new winter track were the next ETS will be held. we are driving solaris wheels on sugar water treated tarmac. the grip on the track is great and the car was almost perfect. almost!
it suffers from understeer in mid corner and corner exit. any ideas of how to get rid of it?? i want the car to have less understeer and carry more cornerspeed in general. other than that the car is great.
glad for any pointers. attached a link to the current setup.
thx guys!!!!
SETUP
vitomon is offline   Reply With Quote
Old 02-01-2011, 07:43 AM   #2568
Nico''s Avatar
Hi guys, hi Vitomon,
I drive on asphalt in France so it's cold now and I have exactly the same feeling that you Vitomon about the BD5 W.
Nico' is offline   Reply With Quote
Old 02-01-2011, 08:32 AM   #2569
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by vitomon View Post
hi guys,
thx guys!!!!
SETUP
Try going to shock position 3 all round, or 2 front, 3 rear. And remove Anti dive from the front. U should really be using traction compound front and rear also I would also try harder springs when doing this, so silvers all round would be a good option.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 02-01-2011, 08:41 AM   #2570
thx antoni. i am actually using traction compound front and rear, was just too lazy to fill in
i started the day with shock positions 3/3 bu the 4/4 felt better and hat a 0.2s advantage per lap over the 3/3. but will give it another try with the harder springs and without the anti-dive.
what do you think of harder shock oil and or increased right height??
cheers
Old 02-01-2011, 08:42 AM   #2571
pcar951's Avatar
Trader Rating: 19 (100%+)
- wider rear track = more on power steering
- increased front camber (up to 2.5 deg) = more mid corner and overall steering
- front toe = .5-1.5 "negative"
- could, lower the front roll center and raise the rear
- make sure your diff isn't too tight
These things have worked for me, hope it helps.
pcar951 is offline   Reply With Quote
Old 02-01-2011, 11:50 AM   #2572
Send a message via AIM to Matt W
Default BD5 Belts
Hi guys,
I was wondering how many teeth the front and rear belts had on the yok bd5?
Matt W is offline   Reply With Quote
Old 02-01-2011, 12:12 PM   #2573
Front: 172
Rear: 63
pajenova is offline   Reply With Quote
Old 02-01-2011, 07:49 PM   #2574
hi guys,
thx guys!!!!
SETUP
What is your droop? too much weight is being transffed in the rear in mid and exit (on power), so less traction on the front... softer spring in the front or or stiffer spring on the rear so it doesn't transfer much weight on the rear, or higher ride height on the rear. you can also try more droop on the front. what chassis are you using the super flex (more holes) or the regular. but I hope you get the point why it is pushing...it more about weight distrubution.
ddd2k is offline   Reply With Quote
Old 02-02-2011, 09:38 AM   #2575
dameetz's Avatar
I m building my shocks now, I downloaded some of the set up sheets from petit rc. Most of 'em are using 1.1mm 3 holes piston, which part no is it? Correct me if I m wrong, the included pistons are 1.0 mm right? Also whats the difference in handling between the included blue diaphragm and the optional black one?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 02-02-2011, 10:20 AM   #2576
dameetz's Avatar
Also, where can I get info on suspension blocks combination? I m confuse by the manual info given which only gives measurement instead of toe deg.
Old 02-02-2011, 02:16 PM   #2577
Just drill the 1.0mm piston to 1.1mm size.
As for the suspension mount:
Sleepstream is offline   Reply With Quote
Old 02-02-2011, 03:43 PM   #2578
42 + 47.1 = 3.5 rear toe
42 + 46.4 = 3.0 rear toe
42 + 45.7 = 2.5 rear toe
41.3 + 47.1 = 4.0
And so on
Antoni Caretti
Old 02-02-2011, 07:18 PM   #2579
dameetz's Avatar
Thanks for the info guys, now where can I find 1.1mm drill bit? I do have a set of metric size drill bits but the increment is in 0.5mm, so I have 1.0mm and the next one is 1.5mm.
Also where do you guys measure your droop from? Bottom of the arm?
Old 02-02-2011, 08:39 PM   #2580
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
u can get from hardware shop...
i normally measure below the outer hinge pin...
Give the best while u can !
kschu is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
