Old 01-26-2011, 06:35 PM   #2551
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by dawgmeat View Post
Leaning very heavily towards the BD5, when ordering spares should I get the plastic or LW Suspension parts?
get plastic for c-hub, and for other parts, get the graphite...
Give the best while u can !
kschu is offline   Reply With Quote
Old 01-27-2011, 11:07 PM   #2552
how do i know my belts is tense enough...? always put finger pressure on the belts but not so sure it is in good tense...?
zamrioo2 is offline   Reply With Quote
Old 01-28-2011, 06:30 AM   #2553
wazee's Avatar
I've broken one right graphite and one normal plastic c-hub and didn't feel any difference in durability. The plastic one are cheaper of course...
I'm only racing stock with my bd5w and had some pretty bad crashes with some barriers or other cars and 2 c-hubs were the only parts that broke.
Usually I'm racing 1:8 nitro buggy in the summer and the bd5 is only my winter training car.
I thought these electric sedans are weaker but its holding up very good and all the spare parts i purchased will probably never be used. (Maybe if you race modified and you have some really bad ass crash you''ll need them...)
Thumbs up for the yokomo and its easy and awesome to drive
wazee is offline   Reply With Quote
Old 01-29-2011, 04:07 PM   #2554
pcar951's Avatar
Trader Rating: 19 (100%+)
I know this has been asked before but...Are the body mounts the same on the old BD and the BD5? It'd be nice to drop a BD body right on the BD5.
pcar951 is offline   Reply With Quote
Old 01-29-2011, 04:40 PM   #2555
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
As far as I recall they are not. They are larger diameter. They may still fit though.
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 01-29-2011, 04:55 PM   #2556
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Body goes straight on As fpart said though, you may need to enlarge the holes slighly depending on how big you did them to fit the BD. But same positions for sure
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 01-29-2011, 04:56 PM   #2557
pcar951's Avatar
Nice!! I hate painting bodies.
Old 01-29-2011, 06:38 PM   #2558
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Default BD5 shocks
For people running the single O-ring setup on their shocks, are you shimming it somehow?
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 01-31-2011, 03:21 AM   #2559
27Levin's Avatar
Send a message via MSN to 27Levin
I found one !
Use this BD-S2B, Check it out Drift Speed web
I really forgot the thing.
Sorry
Yokomo parts in the US
Drift Speed.Com
[email protected]
27Levin is offline   Reply With Quote
Old 01-31-2011, 01:54 PM   #2560
dawgmeat's Avatar
Originally Posted by hanulec View Post
please read back a few pages. the hardest part is getting the xray chubs working with the arms. everything else you need is documented at www.sidepieceracing.com
Will the BD5 steering knuckles fit the Xray C-hub and will the STEEL STEERING BUSHING (2+2)require shimming? Thanks in advance
Which ECS fits the BD5 50 or 52mm
dawgmeat is offline   Reply With Quote
Old 01-31-2011, 05:53 PM   #2561
hanulec's Avatar
Trader Rating: 27 (100%+)
I will need one of my friends to help me out around the knuckle question.
As for the ecs - either of them should fit. We found at snowbirds that adding 1mm of shim between the top spool and Mira outdrives yielded the best results.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-31-2011, 06:08 PM   #2562
fpart's Avatar
Hanulec How did you do at the birds? If you are using he Yokomo knuckle with the xray C-hubs, you need to use the xray bottom cylinder and use the normal top cylinder if I remember correctly. You may have to grind the knuckles to get the steering throw. I am using the Xray knuckle so I can't be sure.
スクービーは私のヒーローです!
Old 01-31-2011, 06:27 PM   #2563
kschu's Avatar
get the litemodz CVS...im using it now...im quite satisfied with it...now more drilling or reaming on the c-hub...just plug & play...
no more chattering during cornering now...
Old 01-31-2011, 08:25 PM   #2564
dawgmeat's Avatar
Only if you can get your order in time lol
Old 01-31-2011, 08:34 PM   #2565
kschu's Avatar
i dont have problem so far with the delivery....hehe
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
