Old 01-20-2011, 08:51 AM   #2491
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Originally Posted by dameetz View Post
Nice....I may want to try it out....they mention for BD5 I need to use 'TBD' type C-Hub....what's TBD??
Well Since the ECS has a wider joint in it the c hub has to be shaved to make clearance for where the joint goes through the C hub. The Xray C hubs have wider openings for the ECS to pass through and the top ones can be used with a little shaving. Someone at our track uses the Xray C hubs on the BD5 but I'm not sure what is involved in that.
Im sure someone on here has used the garbage Spec R Driveshafts and would have a solution to this problem because they would experience the same issue with those.
We used to run the Spec R Driveshafts in our TOP cars but they were so unreliable we wanted to make some way to make the Xray ECS's fit because they are rock solid. That is where the SPR Spool cups dervived from.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 01-20-2011, 09:09 AM   #2492
dameetz's Avatar
Yes I understand that....just want to know whats a TBD stand for and what it is actually....anyway anyone here know if the HB TCX's C-Hub can fit the BD5 arms? Coz I know my TCX has bigger C-Hub hole for use with its DCJ driveshafts.
P/S: I m still waiting for my BD5WR to arrive, hopefully this week
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 01-20-2011, 09:16 AM   #2493
I think TBD means To Be Decided. Basically meaning we dont run BD5s so we arent exactly sure what works best for the guys that do.
Old 01-20-2011, 10:00 AM   #2494
hanulec's Avatar
Trader Rating: 27 (100%+)
This weekend we should be able to test fit the TOP spool + Side Piece outdrives + XRay ECS with a BD5 (and TC6) to better understand the C-hub situation. If someone can provide the width measurements on the Yokomo c-hub then we will ha e a better clue if there is enough clearance.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-20-2011, 12:10 PM   #2495
jackdani's Avatar
can anyone tell me where i can find some setups for the bd5wr
thanks
- Team Durando DNX408 v2
- Alpha a852 Lutz edition
- Runner Time fuel
- Sanwa m11x
- Pitshark.it
jackdani is offline   Reply With Quote
Old 01-22-2011, 11:14 AM   #2496
Undertaker1's Avatar
petitrc.com/reglages/yokomo/SetupSheetsYokomoBD5
Undertaker1 is offline   Reply With Quote
Old 01-23-2011, 01:50 PM   #2497
dawgmeat's Avatar
Which rear A-arms come with the world spec, 41.5, 40.5 or 39.5?
dawgmeat is offline   Reply With Quote
Old 01-23-2011, 02:18 PM   #2498
Nico''s Avatar
Hi,
it comes the 40,5
I got this car too and I wonder if you use the kit weights ( 20g central and 15g X2 front)?
How do you wedge the lipo battery?
because I would like to put off the 20g weight but it was useful to lock the battery.
regards,
Nico'
Nico' is offline   Reply With Quote
Old 01-23-2011, 02:24 PM   #2499
jackdani's Avatar
hi guys,
here is the last laps of my first day practicing with the db5,
i have to be honest,
even if i changed very few things from the first laps, the car turned out very well and i managed to be very fast (for my standars of course)
hope you will enjoy!
p.s.
waiting for the first upgrade, alu spool cups!!
- Runner Time fuel
- Sanwa m11x
- Pitshark.it
Old 01-23-2011, 02:24 PM   #2500
jackdani's Avatar
hi guys,
http://www.youtube.com/watch?v=ydqZoLaqhkI
p.s.
- Runner Time fuel
- Sanwa m11x
- Pitshark.it
Old 01-23-2011, 05:46 PM   #2501
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by jackdani View Post
hi guys,
p.s.
look good....need little more tweak...corner was too wide...
Give the best while u can !
kschu is offline   Reply With Quote
Old 01-23-2011, 07:54 PM   #2502
hanulec's Avatar
Our local BD-5 racers were not at the track this weekend, but when talking with a former runner of the car they confirmed that both the TOP Photon Spool, and XRay C-Hubs fit within the car.
I've update the Side Piece Racing web site with this information. Once I'm able to perform a placement I'll upload them online.
Old 01-23-2011, 08:09 PM   #2503
Trader Rating: 25 (100%+)
The XRay ECS and XRay C hubs are the only real way to make this work, You have to open the hole in the Yokomo C hub to make a Spec R ECS fit. By opening the hole and removing the material, it makes the Yokomo C hub weak. With the boards here in the US, the Yokomo C hubs will break.
matt rem is offline   Reply With Quote
Old 01-24-2011, 12:03 AM   #2504
kschu's Avatar
how to fit in xray c-hub? then outer pin hole of bd5 arm is 1.5mm...
Old 01-24-2011, 01:30 AM   #2505
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by Nico' View Post
Hi,
it comes the 40,5
regards,
Nico'
39,5mm is the kit rear-wishbone and also what we always use
the outter hingepin is 2mm, Xray is 3mm, so you would need to drill up the hole to make the new hingepins fit, but the standard driveshafts are absolutely fine, as long as you take them apart the very first time before using them, cleaning them properly, heating them once and oil them with 2 drops of WD40
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
