Old 01-14-2011, 10:00 AM   #2461
Nico''s Avatar
Originally Posted by housey View Post
Yea you should do it really, especially if you are gonna run on asphalt.
thanks a lot , I'll do it,
I have an other question, drive shaft pin have not flat spot, I think it's would be really better to make one?
Nico' is offline   Reply With Quote
Old 01-14-2011, 01:48 PM   #2462
Originally Posted by jackdani View Post
ok the pinion here is 42T and the spur is 96T...which gives 4.5 a little too much for my sp 13.5 which actually i m running at 5.5/6
do you know if i can use a 81T rw spurgear pitch48?
Yes, you can use 81T 48dp, and 26 - 29 pinions for this FDR, aproximately.
Nico, is not necessary if you put a drop of thread lock in the screw, but if you make a flat spot in the center of pin, is more secure.
Greetings, Luis C.
## NOSRAM ## YOKOMO BD5W ## BMI DB12RR+ ##
luic is offline   Reply With Quote
Old 01-14-2011, 03:05 PM   #2463
Nico''s Avatar
Greetings, Luis C.
I used to put thread lock on screws T3 drive shafts but I wasn't enough, so I will make a flat spot, thanks.
Old 01-14-2011, 05:54 PM   #2464
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Yes , u can...I'm using 80t spur....
Give the best while u can !
kschu is offline   Reply With Quote
Old 01-15-2011, 11:57 AM   #2465
jackdani's Avatar
perfect, i put the 81T which fits perfect but i only used 2 screws do you think this should be a problem??
this is where i get so far!!
the car is sweet, outstanding quality and nicest piece of carbon i ve ever seen!
jackdani is offline   Reply With Quote
Old 01-15-2011, 12:00 PM   #2466
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
2 screws is fine
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 01-15-2011, 06:37 PM   #2467
housey's Avatar
I'm running a JAAD spool at the moment guys but the outdrives will soon be in need of replacement.
Trying to find any JAAD steel outdrives is like trying to find the pot of gold at the end of a rainbow! So I'm wondering if you lot know of any other outdrives that I can use that will fit. These maybe,
http://www.rc-mushroom.com/product_i...ducts_id=19229
or will those only fit the official Yoke BD5 spool?
Thanks in advance for your help.
housey is offline   Reply With Quote
Old 01-15-2011, 07:20 PM   #2468
SammyZ's Avatar
Trader Rating: 138 (100%+)
No those won't fit. I have the jaad spool and after half a season of mod racing the spool cups are worn out. Your only option is to get the yokomo spool and buy the steel option cups D-046 and run those.
Or wait for the new roche spool coming out soon with revised spool cups.
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 01-16-2011, 11:53 AM   #2469
Greg M's Avatar
This has probably already been asked, but I picked up a BD after a few years not racing touring cars. Got it real cheap and am loving racing on road again. A friend is wanting to get into it as well, so I have an opportunity to sell the BD. Is the BD5 that much better then the BD?
Greg M is offline   Reply With Quote
Old 01-17-2011, 03:13 AM   #2470
altreyx's Avatar
i had the old BD, nice car. But the BD5 is really much better. I noticed a big improve upgrade my BD5 into the World Edition with the new lipo chassis, new topdeck, etc.
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 01-17-2011, 02:04 PM   #2471
SammyZ's Avatar
not worth the $$ to upgrade when you can just hopup the old BD with the BD5 steering plate and use BD5 jubs and steering knuckles.
Hotbodies USA
SweepRacing USA
Old 01-17-2011, 06:08 PM   #2472
kschu's Avatar
some parts for Yokomo
Old 01-17-2011, 06:14 PM   #2473
Trader Rating: 25 (100%+)
Does anyone have a Yokomo spring chart? or know the rating on the Yokomo springs?
matt rem is offline   Reply With Quote
Old 01-17-2011, 07:02 PM   #2474
Check this page
Arn0 is offline   Reply With Quote
Old 01-17-2011, 09:38 PM   #2475
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
I thought I would post pics of my BD to BD5 steering conversion for those that may be curious to see what it looks like. BD5 standard rack, c-hubs(BD5 c-hub is thinner so you will need a 1mm shim, or two .5 shims to space it on the BD arm), BD5 knuckles and kingpins. 45.5 front universals are used. Roche spool used but BD5 spool will fit. Also using the "thin type" wheel hexes(4.1mm width) available at the link below with no wheel hex spacers for 188mm front end width using TOP Solaris tires. I also used 39mm tie-rods for the steering assembly. I DID NOT have to drill out the arms for the outer pins going through the c-hub.
http://www.driftspeed.com/index.php?...oducts_id=2264
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
