Old 12-29-2010, 04:49 AM   #2401
dameetz's Avatar
Default What servo?
What servo do you guys use for your BD5? The one that does not rub or touch the steering post?
Thanks.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 12-29-2010, 06:01 AM   #2402
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Thanks.
Sanwa 801/851, futaba 9551 or KO 2413 all dont that i have tried
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 12-29-2010, 06:23 AM   #2403
Default suspension mount
Could somebody measure the distance between the screw holes on the suspension mounts for me?
Thank you,
Patrick
XCELL is offline   Reply With Quote
Old 12-29-2010, 06:43 AM   #2404
defcone's Avatar
Trader Rating: 15 (100%+)
Thank you,
Patrick
They're the same as the tamiya ones if that helps.
defcone is offline   Reply With Quote
Old 12-29-2010, 06:49 AM   #2405
Default thank you
Sure does, thank you for your help.
Patrick
Old 12-29-2010, 07:48 AM   #2406
dameetz's Avatar
Thanks, I do have the Sanwa 801 low profile servo, now I m waiting for my kit (BD5WR) which will arrive mid of January I hope. What other tuning parts that I need? The 8mm steering plate? What does it do? Change ackerman?
Old 12-29-2010, 09:53 AM   #2407
The kit run good out of the box, you just need to figure out your setup on your track, first thing broke in my kit was the plastic spool out drives... you will need to replace that with the steel from http://www.rc-mushroom.com/product_i...ducts_id=19229
you might want to get a set of springs & sway bars for tuning, I'm currently using my Xray spring. Are you running asphalt or carpet?
ddd2k is offline   Reply With Quote
Old 12-29-2010, 10:06 AM   #2408
Nico''s Avatar
what's the matter exactly about steering servo, some dubs with steering post?
I have a SAnwa ERG WRX and a Sav÷x SC-1257, will they suit please?
Nico' is offline   Reply With Quote
Old 12-29-2010, 04:17 PM   #2409
The 8mm steering rack places the holes closer together where the ballstuds screw into, effectively making it longer. std one would be 10mm. It will make the car more responsive.
The sanwa should fit, not sure on the Sav÷x.
Antoni Caretti
Old 12-29-2010, 05:53 PM   #2410
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Savox can fit ...im using them...
Give the best while u can !
kschu is offline   Reply With Quote
Old 12-29-2010, 11:29 PM   #2411
Nico''s Avatar
thank you both it's great
why always using the 8mm steering plate?
Do the car not turn enough at all with sdt 10mm plate?
Old 12-30-2010, 05:17 AM   #2412
kschu's Avatar
i dont know...haha...just like to add whatever that new on the market...
Old 12-30-2010, 05:34 AM   #2413
Nico''s Avatar
funny
Old 01-03-2011, 06:00 PM   #2414
kschu's Avatar
new release Low friction belt for BD5...same material that use on 417 belting...
Old 01-04-2011, 01:45 AM   #2415
Nico''s Avatar
Hi,
On W main plate, I saw you add one product to fix strongly the servo but I can't find anymore the name of this product.
Can someone help me please?
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
