Old 12-03-2010, 03:38 AM   #2341
Is there anywhere we can find Ronald & Martin's setup from the previous ETS?
Sleepstream is offline   Reply With Quote
Old 12-03-2010, 04:49 AM   #2342
defcone's Avatar
Trader Rating: 15 (100%+)
Ask on their facebook page?
defcone is offline   Reply With Quote
Old 12-06-2010, 06:37 AM   #2343
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Originally Posted by RAL View Post
What track width are people running on the front end for asphalt? I put the BD5 knuckles and c-hubs on my BD and it seems a little wide. Even with thin wheel hexes.
Thank you in advance.
it's just right the way it is.
every car is wider up front than in the rear (tamiya, hotbodies, xray ...)
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 12-06-2010, 06:37 AM   #2344
the oneway is glued
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 12-07-2010, 07:00 PM   #2345
hacker's Avatar
Trader Rating: 141 (100%+)
Default yokomo bd5wr
when did this car come out?
hacker is offline   Reply With Quote
Old 12-07-2010, 07:04 PM   #2346
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
judging from masami's blog sometime around Oct 31st? lol
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 12-07-2010, 07:19 PM   #2347
mikeygar's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Martin Hofer View Post
the oneway is glued
hi Martin - did you just put CA on the oneway bearings? Curious how you did this. Thanks!
mikeygar is offline   Reply With Quote
Old 12-07-2010, 08:24 PM   #2348
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
wr car kit only available in japan market...
Give the best while u can !
kschu is offline   Reply With Quote
Old 12-07-2010, 09:28 PM   #2349
I'm getting my BD5WR this thursday from driftspeed.com at Los Alamitos,CA superb customer service...if I need anything from japan...they get it in no time. I'll post pic once it's build hopefully by friday. This will be my first yokomo sedan car....any tips for setup? I'm running carpet mod...they said it comes with two bottom chassis.
ddd2k is offline   Reply With Quote
Old 12-09-2010, 12:39 AM   #2350
for modified always use the regular hard chassiplate (less cutouts) and ball diff. atleast as long as you race indoors. on tarmac tracks with NO! sugar water or similar the soft plate is better. gear or ball diff has to be tested outdoors but indoors ball all the way
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 12-09-2010, 02:09 AM   #2351
Holmenkollen's Avatar
the oneway is glued
How to glue it? Regular CA?
Xray - Hobbywing - Graupner
Holmenkollen is offline   Reply With Quote
Old 12-09-2010, 02:12 AM   #2352
thanks martin, just curious what spring do you use? HPI or Yokomo?
Old 12-11-2010, 07:10 PM   #2353
Does anybody have a good setup for carpet mod? Do you guys recommend shoe glueing the servo instead of double sided tape? I run my car today and it needs some work...this is my fisrt time running yoks...if you guys have any advise...send them in...the setup I have now is base on the book...what spring should I get? thanks
Old 12-13-2010, 01:30 AM   #2354
I use HPI Springs (pink/silver or gold/silver on carpet) 99% of times. If i don't, then I use Tamiya white/blue or yokomo orange/pink. (all in front/rear)
But tbh between all these springs the difference is quite marginal and on most tracks does not really make a difference.
outdoor hpi silver/silver or yokomopink/blue
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 12-13-2010, 12:21 PM   #2355
I broke the alu spool outdrives, what do you recommend for replacement? I'm gathering all the part# I need so I can order it overseas...it will be helpful if you have other recommendation as to which part I should stock base on your experience....both for tweaking and spares. what spur gear do you use, this one has 4 holes. also does Yok's sell the suspension holder in set?
thanks
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
