Old 11-26-2010, 12:52 AM   #2326
hacker's Avatar
Trader Rating: 141 (100%+)
no I dont have a chart, but just thought I'd let you know I know its not correct is all.
I would assume most people know AE shock oil is on average 2.5wt heavier than losi, ie. ae 35 = losi 32.5, which is not represented correctly on the chart.
hacker is offline   Reply With Quote
Old 11-26-2010, 02:05 AM   #2327
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
sounds like you're assuming alot
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 11-26-2010, 08:00 AM   #2328
After looking at that chart the reason why I'm asking if Team Yokomo shock oil is cst or not?
Sleepstream is offline   Reply With Quote
Old 11-26-2010, 12:20 PM   #2329
RAL
RAL's Avatar
Sleep-
From what I understand based upon conversations on here and at the local tracks, is that, that chart is incorrect. I thought they had updated it but it doesn't look like it.
This topic came up about a year ago and we had concluded that the muchmore oil ratings on this chart were wrong. Logically, if the Tamiya camp like Gilles etc are using 500-600 Muchmore oils that corresponds to 55-62.5 wt. Associated on this chart. I doubt that is true. Muchmore and Sweep are supposed to be the same. Just listen to Martin to be safe and run the Yok 450! Or try ASC 37.5 if thats what your shop has.
Old 11-26-2010, 02:40 PM   #2330
Cheers RAL,
Well that chart is from Sweep's official website. I use to be a strong believer that MM are cst until I saw this chart. Hence thought MM=Sweep. Until recently, i couldn't get any MM oil & Sweep was the only alternative. Don't really fancy AE. Quite difficult to get Yokomo oil as have to order abroad. Wish Martin would pop by & clarify:
I.) Is Yokomo oil (cst)?
II.) What oil is referring to when he said 450?
Old 11-27-2010, 02:29 AM   #2331
altreyx's Avatar
Originally Posted by Sleepstream View Post
Cheers RAL,
i found this old review on RedRc:
http://www.redrc.net/2007/06/much-mo...one-shock-oil/
The last oils, for me, have only a different bottle so i really think MM oil is cSt.
I also tryed to compare my MM400 with the original Yok400 (found into the car kit) and a KFactory 400 (that is cSt).
My feeling is that the density is the same, i can be wrong, but if i try to compare those oils with a MM600 last one seems a little bit high as density.
I think also Yokomo is Cst and also Martin i'm pretty sure he is talkin' about cSt oils.
May be for more info ceck this: http://www.twf8.ws/php/index.php?opt...per&Itemid=175
Some time ago i found this table and i found it pretty good. It is attached as pdf.
Hoping this can help you.
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 11-28-2010, 07:47 AM   #2332
Trader Rating: 45 (100%+)
Yokomo still on top in ETS - Hrotovice...No I in team.
http://ets.redrc.net/wp-content/gall...t-volkertq.jpg
Apex is offline   Reply With Quote
Old 12-02-2010, 03:16 AM   #2333
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Team Yokomo @ Facebook..
Hope to see more driver joining Team Yokomo !
Give the best while u can !
kschu is offline   Reply With Quote
Old 12-02-2010, 05:44 AM   #2334
Front Oneway
Old 12-02-2010, 05:46 AM   #2335
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Front Oneway
It is but they lock it Apparently its something to do with the outdrives being better.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 12-02-2010, 02:36 PM   #2336
RAL
RAL's Avatar
What track width are people running on the front end for asphalt? I put the BD5 knuckles and c-hubs on my BD and it seems a little wide. Even with thin wheel hexes.
Thank you in advance.
Old 12-02-2010, 04:52 PM   #2337
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
how do they lock the one-ways?
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 12-02-2010, 05:09 PM   #2338
Not sure TBO
Antoni Caretti
Old 12-02-2010, 09:22 PM   #2339
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Im sure they just add pins in a certain area to lock it. Kinda like how xray does with their multidiffs!
hotdognobun is offline   Reply With Quote
Old 12-02-2010, 11:24 PM   #2340
kschu's Avatar
yes, front is wider than rear. which it's does make the rear more gripper and easier to drive in any track.
sakura is front narrower than rear making the car too much steering and rear less grip which PITA on low traction track.
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
