Old 11-22-2010, 11:42 PM   #2311
kiddja's Avatar
I just bought a new BD5 W, and i am using stock shock piston but i would like
try a 2 holes 1.00MM or 1.10MM piston. I have look at the Yokomo website and i cannot find the 2 holes piston.
Does anyone know where should i get the piston? Can i use Tamiya, Xray and
HB?
Last, i have found Rayspeed MR4TC SD piston which look like the BD5W piston. Please advice.
kiddja is offline   Reply With Quote
Old 11-23-2010, 01:01 AM   #2312
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
HB?
why u wan to use 2 hole piston?
Give the best while u can !
kschu is offline   Reply With Quote
Old 11-23-2010, 01:29 AM   #2313
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
forget about 2-hole
get a 1.1mm drill, drill the holes in the kit piston with that. use 450 oil and forget about it!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 11-23-2010, 04:54 PM   #2314
housey's Avatar
Do you guys know anywhere the BD5W is in stock? Really fancy one but everywhere seems to be out.........or I'm blind
housey is offline   Reply With Quote
Old 11-24-2010, 02:22 AM   #2315
altreyx's Avatar
you got a PM for more info
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 11-24-2010, 08:52 PM   #2316
kschu's Avatar
pm me if u need some parts for Yokomo
Old 11-25-2010, 02:47 AM   #2317
Is Team Yokomo shock oils Cst? Anywhere on the net saying it so? When people are referring to 450 oil? Is it cst?
Sleepstream is offline   Reply With Quote
Old 11-25-2010, 03:01 AM   #2318
kschu's Avatar
if hv 0 behind would be cst...
Old 11-25-2010, 03:41 AM   #2319
Muchmore shock oil has an extra 0 in it but they are not cst.
Old 11-25-2010, 04:06 AM   #2320
kschu's Avatar
then im not sure..haha
Old 11-25-2010, 01:42 PM   #2321
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Many of the racers I know have been using this chart with success to compare oil viscosity variances between brands. The light blue color indicating "new Xray" has been found to be the same as Muchmore oils. Those using Muchmore oils including myself have been using the CPS ratings from the "new Xray" portion of the chart to make shock oil selections with Muchmore oils. I'm not sure how Yokomo compares to Muchmore or the "new xray" but it should help some of you out there who are more familiar with using Associated or Losi oils rated in the wt. systems to find comparable oils.
-Cheers
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 11-25-2010, 10:32 PM   #2322
kiddja's Avatar
Thank you for your message
Our track surface is very high grip which i would like to make the shock stiffer by changing the piston. Currently, i have used associated 60WT shock oil with HPI Red and HPI Gold spring when the track is in a high grip condition.
If our track has no preparation, we will change our set up to 45Wt oil with
Orange and Green yokomo spring.
I thougth if i change the piston from 3 to 2 holes may help to use softer spring and make the car more easier to drive.
I have seen couple set up sheet that they used two holes piston. Does anyone know where can buy the piston?
Old 11-25-2010, 10:34 PM   #2323
kiddja's Avatar
Originally Posted by Martin Hofer View Post
forget about 2-hole
Thank you for your advice.
I will try it.
Old 11-25-2010, 11:55 PM   #2324
hacker's Avatar
Trader Rating: 141 (100%+)
-Cheers
dont know where you found that chart from, but thats wrong
hacker is offline   Reply With Quote
Old 11-26-2010, 12:15 AM   #2325
RAL
RAL's Avatar
If you have a better chart please share. This was one of the many charts posted in the xray t3 thread. Many of them were proven to be wrong. This was supposed to be the right one.
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
