Old 10-27-2010, 05:33 AM   #2236
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
For modified W is much better but for stock racing I think the softer chassi can have it's advantages on some tracks.
I do have 2 cars which are identically apart from the chassi.
From my testing, I would never only have 1 car with the soft chassi as on some tracks it just does not work at all
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-27-2010, 09:47 AM   #2237
Hi!
Anyone can give me dimensions if have this axle
Spec-R - C.V. Universal Swing Shaft for BD5
I need length because I'm looking for double joint axle for my tc5r/tc6
Regards!
m.
edit: or standard BD-5 axle ... if spec-r fit, dimm of spec-r should be like stock part ...
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-27-2010, 01:24 PM   #2238
Hi Martin,
Could you explain what is the difference between both chassis in handling terms??
Caza Roedores is offline   Reply With Quote
Old 10-27-2010, 01:42 PM   #2239
CanyonCarverR1's Avatar
Default Gear Diff
Does anybody have any tips for building a leak-proof Yokomo gear diff?
CanyonCarverR1 is offline   Reply With Quote
Old 10-27-2010, 05:23 PM   #2240
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by M.Abramowicz View Post
Hi!
Regards!
m.
its 46mm bone..it's work well with bd5...
Give the best while u can !
kschu is offline   Reply With Quote
Old 10-28-2010, 12:59 AM   #2241
won't get a leak-proof one.
The downside of a geardiff is that it just does not work as well as a balldiff does and this is why you loose overall mechanical traction if you put it in. even if it runs really smooth and is pretty soft set.
If you where to make it leak proof, all you can do isuse a harder oil which makes it work even worse resulting in a even worse handling car.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-28-2010, 01:00 AM   #2242
Originally Posted by Caza Roedores View Post
Hi Martin,
the hard one (standard w) is easier, more consistant and carries more cornerspeed, so it is best 99% of times
the soft one is good for very low speed classes or outdoorracing on tracks with no sugar water applied as it gives more overall traction, which is what you usually don't need on carpet
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-28-2010, 01:29 AM   #2243
kschu's Avatar
Old 10-28-2010, 01:57 AM   #2244
Ok,
Thank you for the answer!!
Old 10-28-2010, 02:58 AM   #2245
Thanks!
Where is this 46mm?
I post two pics with arrows
1st is from manual and 2nd from litemodzwhatever
m
Michal Abramowicz
Old 10-28-2010, 04:10 PM   #2246
Hello everybody,
I'd like to switch to youkomo. So before buying the kit i need to know if the kit comes with the plastic or graphite parts (wishbones, C hub, f/r hubs).
Thanks in advance
Hugo is offline   Reply With Quote
Old 10-28-2010, 04:11 PM   #2247
Hello everybody,
I'd like to switch to yokomo (BD5 W). So before buying the car i need to know if the kit comes with the plastic or graphite parts (wishbones, C hub, f/r hubs).
Which spring & sway bar are included in the BD5 W kit?
Thanks in advance
Old 10-28-2010, 06:05 PM   #2248
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Hugo View Post
Hello everybody,
Thanks in advance
The arms, C hubs and knuckles are all graphite. Wishbones are steel front and rear. The Yokomo Pink (front) and blue (rear) springs are included in the kit. And 1.3 front, 1.1 rear sway bar is on the kit
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 10-28-2010, 08:31 PM   #2249
kschu's Avatar
Hello everybody,
Thanks in advance
if u crash alot, would recommend you to use plstic c-hub instead of the graphite ..
the other a quite durable for crash...
Hope to see another racer join Yokomo...
Old 10-29-2010, 01:51 PM   #2250
nocif13's Avatar
Send a message via MSN to nocif13
yokomo bd5 WR
http://www.teamyokomo.com/jpn/news/o...1029_bd5wr.pdf
What differences there are compared to the world spec?
teamspec/petitrc.com/TEAM WAVE/T.O.P racing/CBRacing.fr/rcmanufactory/Alien POWER/Team Terribles
nocif13 is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
