Old 10-05-2010, 07:16 PM   #2146
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by sosidge View Post
http://www.redrc.net/2010/10/yokomo-...late-gear-diff
Yokomo's own geardiff...
And new lower deck...
Sorry if this has been posted already, I couldn't see it.
the yokomo geardiff did look similar with spec-r geardiff...
Give the best while u can !
kschu is offline   Reply With Quote
Old 10-06-2010, 01:09 AM   #2147
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
I have built several Spec-R Gear Diffs for other drivers and can say the Yokomo Diff is nothing like the Spec-R. The Pins holding the spider gears are superstron 3mm Steel compared to the cheap plastic thing in the Spec R diff. The gears are much smoother and the sealing is a lot stronger which all results in the diff beeing a lot stronger than the Spec R.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-06-2010, 05:48 AM   #2148
memyselfandI's Avatar
hey Guys,
I am chasing a yokomo decal sheet, anyone know where I could get my hands on one??
Carisma Racing Australia
Modelflight.com.au
Team AKA
Ryper Hobbies
memyselfandI is offline   Reply With Quote
Old 10-06-2010, 05:54 AM   #2149
Hello Martin
For low grip condition, what degree of gear diff oil should we use? Thanks.
yokfans is offline   Reply With Quote
Old 10-06-2010, 07:17 AM   #2150
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by yokfans View Post
Hello Martin
Ronald recommends 800-1000 for Asphalt. Give it a try
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 10-06-2010, 07:19 AM   #2151
kschu's Avatar
Old 10-06-2010, 08:03 AM   #2152
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by memyselfandI View Post
hey Guys,
The usual hk online stores have them, but they're always out of stock. Depends on your luck really.
defcone is offline   Reply With Quote
Old 10-06-2010, 06:53 PM   #2153
Thanks.
Currently using the Spec-R one with 3000 deg oil...car hard to drive...lots of wheel spinning...
Old 10-06-2010, 07:09 PM   #2154
kschu's Avatar
Thanks.
oil too thick tho.....
Old 10-07-2010, 12:46 AM   #2155
On low traction tracks I recommend using a ball diff as it generally gives you more traction.
for asphalt with atleast a fair amount of grip diffoil between 700 and 1000 is the range to use
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-07-2010, 01:08 AM   #2156
altreyx's Avatar
Martin, any idea on which oil to use on indoor carpet?
Thank you
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 10-07-2010, 03:08 AM   #2157
well for capret it's rather a decision wether or not to use the geardiff at all.
At the IIC everybody ran balldiff!!
i will test this weekend and then i can tell more
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-12-2010, 01:09 AM   #2158
As for my testing.
For low-power application (stock racing) the gear diff feels just like a balldiff does (as long as the geardiff is properly built and runs without noticable gears).
For modified i found the geardiff to be quite a handfull to drive and especially for low traction tracks I think it will be too much of a challenge to do proper runs on carpet. Therefore I think for modified / low traction tracks the balldiff is better.
I used 1000 oil in my diff, but you have to refill it every once in a while as it leaks.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-12-2010, 01:11 AM   #2159
defcone's Avatar
As for my testing.
The yokomo gear diff leaks as well?
Old 10-12-2010, 02:59 AM   #2160
a little yes
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
