New Yokomo TC, the BD-5
#2131
So i figured out if i buy the BD5W here it will have spool front and solid center.
if i take the center one-way and use it in the Worlds car i'd either need to change the one-way bearing direction or change the belts.
1, can the belt still go on like in the older cars?
2, is the OW bearing removeble without destruction?
i want the center one-way because i drift and like the E-brake ability, also wish to use 2 gear diffs.
#2133
#2135
Question : for carpet stock racing the spec r gear diff is good ????
#2136
we are using 600 - 1000 on diffoil. sometimes harder but usually in this range as a geardiff is really hard to drive ( atleast harder than a ball diff) which makes it less of an option for carpet racing. but that very much depends on the conditions you race at.
At the IIC everybody used a ball diff. I will do some testing this weekend
#2137
I was thinking to use a gear diff instead of a spool with an oil of 300/400k
Noone has tryed to use this solution?
May be is only wrong idea...
#2140
#2141
Thanks Martin.
So if the knuckle fits i take it the axle spacing will be the same too?
Does the BD5 use large diameter hing pins both in board and out?
Basically i am trying to get my old SD up and running and would like to use BD5 parts where possible.
Many thanks for your help.
Chris
Chris
#2142
Yokomo bd5W
Hi,
is there anybody that knows where to get the yokomo bd5w In Denmark?
Regards
Martin
Regards
Martin
#2143
http://www.redrc.net/2010/10/yokomo-...late-gear-diff
Yokomo's own geardiff...
And new lower deck...
Sorry if this has been posted already, I couldn't see it.
#2144
#2145
I have a BD5 Spec-R diff for sale in the for sale forum if anyone is interested.
For Sale spec-r-gear-diff-yokomo-bd5-40t.html
