Old 09-03-2010, 04:58 PM   #2086
housey's Avatar
You know what mikeygar, I had exactly the same problem, I smashed up 2 standard chassis's pretty quick. Back in 2006 I had the same company (fibre-lyte) make me an exact copy of a standard chassis but without those cutouts and without the outer servo mount.
Had a few runs at the track tonight and I need to slap some anti-roll bars on there, but being late to the meeting meant I didn't have time to faff with setup. Its a little bit thrown together at the moment, but once I get it all tidied up and respectable looking I'll post a few more pics. Really happy with the chassis, I can fully recommend someone getting one if you are still a bit of a dinosaur like me and running the BD.
housey is offline   Reply With Quote
Old 09-04-2010, 12:39 AM   #2087
altreyx's Avatar
Originally Posted by housey View Post
Hope everyone likes it, I'm super happy with how it has turned out. Now I'm off to the track to test it out, cya!
Great Job Man! I had the BD also and my thought is about the flexibility. BD was pretty stiff, motor bulkhead was long so the rear torsion was pretty "bad" May be some "hole" on the chassis can help. But at the end is a fantastic work, let me know if you sell or ship those chassis i have some friend that is still using the BD and may be can be interested.
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 09-04-2010, 07:09 AM   #2088
housey's Avatar
If any of your friends wants one then they just need to contact this company,
http://www.fibre-lyte.co.uk/
and mention that they want a Yokomo BD chassis made to the same spec as me (Chris Swallow). I'm not sure about postage but I'm sure they would post worldwide for a reasonable fee.
There is a mod to the motor mount to fix the flex issue that the long bulkhead causes, although I haven't done it yet. Should be back at the track tomorrow for a big race meet, plenty of time to dial the car in, I'm hoping for a top 5 spot.
Old 09-08-2010, 10:28 AM   #2089
What size are the diff ball & thrust bearing?
Any recommendation for ceramics?
Sleepstream is offline   Reply With Quote
Old 09-08-2010, 07:19 PM   #2090
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
diff ball size is 2.4mm and thrust ball is 1/16mm
maybe u can try on Roche Ceramic balls.
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-09-2010, 02:05 AM   #2091
Cheers KSChu.
What other cars run the same thrust bearing size?
Heard you are running Sakura Zero now.
Old 09-09-2010, 02:35 AM   #2092
kschu's Avatar
Cheers KSChu.
other car that same thrust bearing with yokomo is Xray
im running both car....
Old 09-09-2010, 03:40 AM   #2093
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
the xray thrust bearing is NOT the same as yokomo and not even compatible ...
there is no compatible thrust bearing from any othe rcompany
but to be fair the thrust bearing is really good. No need for ceramic balls there.
Just go for the regular 2.4mm ceramic diff balls and you should be fine. sand your diffplates and thrustbearing plates with 2000 grit wet-sandpaper (but dry! gives a better finish for diff plates) at every rebuild and your fine
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-09-2010, 04:53 PM   #2094
Thanks for the info & tips Martin.. Hope to hear more from you soon.
Old 09-14-2010, 01:14 AM   #2095
Default CVDs
Hi,
can i use CVDs from 4TC BD or BD5 use diferent CVDs.
tomislav is offline   Reply With Quote
Old 09-14-2010, 02:50 AM   #2096
kschu's Avatar
i'm using 1/16" ceramic ball for my thrust bearing....
never fail me so far..
Old 09-14-2010, 02:51 AM   #2097
kschu's Avatar
Originally Posted by tomislav View Post
Hi,
BD5 can use Sakura zero CVD or Tamiya CVD.
Old 09-14-2010, 03:06 AM   #2098
defcone's Avatar
Trader Rating: 15 (100%+)
Can you use the bd5 axle?
defcone is offline   Reply With Quote
Old 09-14-2010, 03:53 AM   #2099
kschu's Avatar
yes, only thing to change is the crossjoint...
why dont just try the ROche Heavyduty axle which take ages to wear out...?
Old 09-16-2010, 11:19 AM   #2100
housey's Avatar
Guys what gear diffs will fit in the original BD?
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
