Old 08-23-2010, 03:08 AM   #2041
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by vitomon View Post
hi guys,
been drivin the bd5w now for 3 race meetings and it performed very well. however, at the last meeting one question came up which i couldnt answer. as far is i know the bd5w has a 2.5mm lower deck. which is rather thick compared to a 416 with 2.25 and a schumacher mi4lp with 2mm lower deck (xray 2.5mm) however, the most setups i have seen for the bd5w a rather "hard" meaning mostly with pink/silver hpi springs for similar yokomo springs. i have also looked at the xray setups on their hp and they all drive very soft springs like hpi blue at the hardest. could this be linked to the lower deck thickness/flex? and if yes, how come almost every setup for the bd5 is with pink/silver springs and not for example yokomo pink/yellow?? thanks for any help on this.
cheers
If you pickup another car, say a 416 or t3 you'd notice those cars have way less flex than the bd5w. That may explain why.
defcone is offline   Reply With Quote
Old 08-23-2010, 04:01 AM   #2042
Hi all;
Already test the BD5W and the difference with my other chassis ( a Mi4Lp) is incredible , has more stering, is faster and more stable, really a very good chassis.
Does anyone have news about the Gear Diff of Yokomo?
Or maybe they can adapt the TOP without too much problem.
Greetings
JordiM is offline   Reply With Quote
Old 08-23-2010, 06:19 AM   #2043
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by JordiM View Post
Hi all;
Greetings
Wait for the Yokomo or Spec R diff. It will be a lot better than the photon one Shouldnt be too long now hopefully
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 08-23-2010, 06:26 AM   #2044
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
I got back into touring and drove my BD 5W this weekend at my local track (blue diamond in Delaware, USA). The car was awesome, I was using a Trinity Duo 10.5 and was easily was the fastest there. Many were running 4.5, 6.5's We didn't have a organized race since it had rained several times throughout the day.
I have the servo mounted on the two sided tape and even though this works well, I was concerned about it coming loose. Has anyone had any problems with the servo coming loose??
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 08-23-2010, 06:34 AM   #2045
defcone's Avatar
Through normal use mine doesn't come loose.
Old 08-23-2010, 06:35 AM   #2046
Just use the one servo mount, double sided underneath and a bit of shoo goo on the outer edge. This is what i do and have yet to have a problem with it And it can easily be removed if you want
Antoni Caretti
Old 08-23-2010, 06:35 AM   #2047
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
hpi silver spring anyone??
Give the best while u can !
kschu is offline   Reply With Quote
Old 08-23-2010, 06:37 AM   #2048
kschu's Avatar
i put shoe goo under my servo too...work well without flex,,,,
Old 08-23-2010, 07:45 AM   #2049
fpart's Avatar
Originally Posted by kschu View Post
Thats what I am using front and rear!
スクービーは私のヒーローです!
Old 08-23-2010, 09:27 AM   #2050
CanyonCarverR1's Avatar
Do any of the Yokomo springs translate equally to this spring?
CanyonCarverR1 is offline   Reply With Quote
Old 08-23-2010, 09:56 AM   #2051
Do you have more details on the new Yokomo?
Tenkuro is offline   Reply With Quote
Old 08-23-2010, 12:51 PM   #2052
altreyx's Avatar
about the springs i found the HPI works better in indoor/carpet races. On the asphalt i use the yokomo springs (basic start for me is always blue/pink)
Anyway after some test i solved my chronic understeer, yesterday my car was perfect; has been the second fast car as best lap but the best car as lap time during the finals when the grip is went down. Often 0,5/0,7s per lap respect to the media of the other cars. Incredible corner speed and agility into the tech part of the track.
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 08-23-2010, 09:34 PM   #2053
Still waiting to hear when its officially released. Ive heard its a lot better than the spec R internally, and it dosent leak Im sure KS will let us all know when its released. I think its suppost to be September
Antoni Caretti
Old 08-23-2010, 09:35 PM   #2054
What did you change?
Antoni Caretti
Old 08-24-2010, 12:59 AM   #2055
kschu's Avatar
should be end of september...
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
