Old 07-28-2010, 03:13 AM   #1996
fastolfart's Avatar
Originally Posted by defcone View Post
Ouch, where was that at?
At the end of the straight at Whalan,found a parked RC car in the way during warm up laps and the driver didnt called it
It is so hard to fix the driver, but so easy to blame the car.
fastolfart is offline   Reply With Quote
Old 07-28-2010, 06:58 PM   #1997
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by fastolfart View Post
It things like this that make get very p!$$ed off with other drivers that don't call out that their car is stop on the end of the straightOver $200 worth of damage
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 07-29-2010, 01:55 AM   #1998
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
hi guys,
the test drives with the ws were good. only point i am looking for would be a little bit more steering in general without compromising to much rear grip and without the car "breaking" into corners and not roll through them.
for the moment the setup is pretty much as the kit came with a few exceptions:
FRONT
1mm rollcenter shims inner camber link
6mm droop under arm
pink spring hpi
450MM oil
1.5 camber
spool
1 toe
ground clearance: 5.5mm
43.5mm blocks
REAR
5mm droop under arm
silver hpi spring
450MM oil
2 camber
3 toe
ground clearance: 6mm
standard stabilizer (1.3/1.1)
kit shock positions
things i want to try:
harder stabilizer in the rear
4.5 droop under arm rear (to get more weight transferred to front)
you guys have any more ideas? any pointers would be glady appreciated.
cheers
ps: sofar luvin the car
vitomon is offline   Reply With Quote
Old 07-29-2010, 03:09 AM   #1999
Ryan Maker's Avatar
Send a message via MSN to Ryan Maker
It's probably worth trying more shims on the inside of the front camber link. Usually i run 2-2.5mm. This straightens the link and makes the steering more responsive, giving you the feeling of more steering, but keeping the rear stability. Also, i'm not sure what Kit shock positions are, but try 3 Front, 2 Rear. I've found this to give best balance of steering/stability. If you need a little more steering, you can just use 2 Front, 2 Rear
Hope this helps,
Ryan.
Awesomatix - Muchmore - Protoform - Silverback - Radtec - LeeSpeed - Hiro Seiko - SG PitDesign - Plaig
RC MAKER - www.rcmaker.com.au
AWESOMATIX - R1 WURKS - VOLANTE
Ryan Maker is offline   Reply With Quote
Old 07-29-2010, 03:42 AM   #2000
Hope this helps,
Ryan.
thanks ryan! i will try the 2-2,5mm shim in the front. any comments on the 8mm steering link? does it help steering as well?`or what does it actually?
Old 07-29-2010, 04:03 AM   #2001
Ryan Maker's Avatar
No Worries at all Oh, yes this is really good for steering. It also gives the impression of more steering, because it gives a higher steering response. This combined with the 2-2.5mm shim should help your car a lot. If it isn't enough, try changing shock positions, if you haven't already.
Ryan.
Old 07-30-2010, 09:08 AM   #2002
another question came up recently when testing. supposing you dont change nothing else. when the traction is high (sugar water) and track temperaturs are high (eg 40C) would you guys recommend harder oil with softer springs (hpi blue or softeR) or would you take normal oil with harder springs.
Old 07-30-2010, 09:16 AM   #2003
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Depends on what your car is doing I suppose If its overheating tyres, then maybe go harder oil with the same or softer springs, if its overgripping possibly harder oil and if its still not right, try harder springs. If its working... leave it
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 07-30-2010, 09:20 AM   #2004
yokemad's Avatar
Nice to see Ryan is driving bd5 now...
Great car but no UK support at all!!!
So sad
yokemad is offline   Reply With Quote
Old 07-30-2010, 12:39 PM   #2005
Jochim_18's Avatar
for that kind of damage you better off buying a new kit.... That's what I do to kit at the same time save me $$$$ on parts just tell your wife you got a better discount if you buy 2 car kits
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-30-2010, 01:45 PM   #2006
Matt Howard's Avatar
So sad
No U.S. support either, oh well
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-30-2010, 05:15 PM   #2007
hotdognobun's Avatar
Trader Rating: 31 (100%+)
driftspeed.com here in good ol Cali
hotdognobun is offline   Reply With Quote
Old 08-03-2010, 02:40 AM   #2008
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Order online is cheaper i think.....
btw, roche axle and titanium coated hingpin for bd5 are available now...
Give the best while u can !
kschu is offline   Reply With Quote
Old 08-03-2010, 08:57 AM   #2009
WhooHooo Been waiting for those titanium pins!!! Thx KS
Old 08-04-2010, 06:40 AM   #2010
kschu's Avatar
ROche heavyduty axle for BD5
BD5 Titanium coated hinge pin
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
