Old 07-14-2010, 02:59 AM   #1936
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
That is a Yokomo gear diff, i believe it will be released later. Spec R have made one that should be available pretty soon.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 07-14-2010, 11:34 PM   #1937
Cool Hope they release it soon.
FrankH is offline   Reply With Quote
Old 07-15-2010, 01:53 AM   #1938
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Default first drive
hi guys, just finished my first real extensive training session with my new bd5ws. as it is my first yokomo i was very curios however, i used the kit setup, which includes the short 39.5mm rear arms. only thing i changed was to a 450 oil and hpi blue springs. the car was immediatly as fast as the fastest guys of the local club and was easy to drive. as i ran kit setup and could do the same laptimes as with my previous car (416) i am quite opptimistic that if a little bit fine-tuned the car is just ballistic.
lots of grip, super steering. only weak point - besides the spool which is being changed - is the taped steering servo which is really causing some problems when i get hit by another car. will try stronger tape at the next race.
if anyone is interessted i was running vtec 30x pre-glued tires, 450 much more oil, hpi blue springs, droop 6/5mm, 3 rear toe, 1 front toe, 5.5/6mm ride-height.
car seems to responed well to a little bit more ride height as it seems it can lean more to the side generating more corner speed.
great car and i am not in any way regretting switsching from the tamiya to the yokomo.
cheers
ps: anyone knows a dealer where i can order spares and pay via pay-pal??
vitomon is offline   Reply With Quote
Old 07-15-2010, 02:52 AM   #1939
altreyx's Avatar
Hobbyhaven or just PM Mr. Elwyn
About the doubletape for the servo i use the Muchmore one (the strong version) or Sweep.
They are working really well
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 07-15-2010, 02:57 AM   #1940
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
cheers
great to know u like the car well...
have some parts available here..
KS Hobby
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-15-2010, 03:41 AM   #1941
If u can get shoogoo try that to hold your servo I use that on the outerside of my servo with double sided tape underneath and the mount on the inner ear.
Antoni
Antoni Caretti
Old 07-15-2010, 03:43 AM   #1942
jychow's Avatar
cheers
Great to know you enjoy the car. BD-5 World Spec is receiving favorable comments from users around the globe. Thanks for your kind support.
For the servo, my solution would be: ShoeGoo + double sided tape.
Usually, I would apply the double side tape in the center and apply ShoeGoo at the perimeter of the servo. This way, it will be bullet-proof. When it comes to removing the servo, just use a blade/knife to open the ShoeGoo at the side. Once it reached the double sided area, the servo can be removed entirely with a little force.
I would suggest 3M double sided tape as I have great experience with them.
For parts support, we can assist you on this as we have been representing Yokomo for over 14 years. We can also offer attractive shipping costs to your country. Please contact Elwyn Lee for your requirement of parts.
Thanks for your kind reference, altreyx.
ERIC CHOW | HOBBY HAVEN SDN BHD | Pearl Point Shopping Mall, 2nd Floor, Lot 1.2.78-1.2.80, Batu 5, Jalan Klang Lama, Kuala Lumpur. Malaysia | Tel: +603-74994191 | http://www.hobbyhaven.com.my |
***** Team Yokomo Malaysia Blog -- http://teamyokomo.blogspot.com *****
***** Hobby Haven Blog -- http://hobby-haven.blogspot.com *****
jychow is offline   Reply With Quote
Old 07-15-2010, 03:57 AM   #1943
thx for the suggestions but i have to ask....what is ShoeGoo??
Old 07-15-2010, 04:25 AM   #1944
altreyx's Avatar
it is a sort of specific glue, Just type Shoe Goo in google
I'll give it a try next time that i'll remove my servo.
Orca-Gm120
Reedy-Lrp
Helios EX10
Old 07-16-2010, 11:55 PM   #1945
kschu's Avatar
Yokomo Geardiff
Old 07-17-2010, 01:32 AM   #1946
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Originally Posted by kschu View Post
I run 17.5 class. Is a gear diff a good option or is it meant only for high powered motor class?
hotdognobun is offline   Reply With Quote
Old 07-17-2010, 06:59 AM   #1947
Trader Rating: 23 (100%+)
Hi All. does the worlds conversion kit do a full conversion or are there still some parts needed to convert 100%? tossing up a conversion or a new car
thanks.
poop is offline   Reply With Quote
Old 07-17-2010, 07:11 AM   #1948
kschu's Avatar
thanks.
world conversion = lower deck, upperdeck, new motor mount, motor mount support...
depend on you dude, if your car is more than 50% wear out, will be recommended you to get a new car....
Old 07-17-2010, 07:12 AM   #1949
kschu's Avatar
i think geardiff is very good for mod class and also high traction...high turn motor might not need it but it's mostly depend on your track traction...
low traction track is not really recommended to use geardiff...
hope more chip in idea on this ....Antoni where r u ?
Old 07-17-2010, 08:07 AM   #1950
im using Gear diffs in medium traction, its all in the oil you use. In higher traction you could use anything up 2 5k, and low traction we have been using 500cst.
Antoni Caretti
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
