Old 06-07-2010, 08:25 AM   #1846
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by manchu View Post
I am using the setup that you publish and 35w oil schumacher and tires LRP VTEC 30x
go 45 or 50wt oil
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 06-07-2010, 08:38 AM   #1847
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by Yokomo_Ant3 View Post
go 45 or 50wt oil
go 60wt!
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-07-2010, 03:03 PM   #1848
Default for antoni or kschu
I have 500 and 550.600 of mugen, which I recommend, the ambient temperature is over 30 degrees
manchu is offline   Reply With Quote
Old 06-07-2010, 04:03 PM   #1849
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Default Gear Diff
So anyone know if J-Spec will be making a gear diff for a bd5?
hotdognobun is offline   Reply With Quote
Old 06-07-2010, 07:12 PM   #1850
kschu's Avatar
jspec?? or u mean spec-R? ?
i will making my own geardiff for bd5 soon by using NT1 rear geardiff.....
Old 06-07-2010, 10:53 PM   #1851
thx for the correction! let us know hownit runs
Old 06-08-2010, 12:56 AM   #1852
Go 500 and see how it feels, if the car is overheating tyres go thicker oil. Only way to know is to test it
Antoni Caretti
Old 06-08-2010, 01:20 AM   #1853
mikeygar's Avatar
Trader Rating: 14 (100%+)
since we're talking about oil, which brand suits the yokomo shocks the best?
mikeygar is offline   Reply With Quote
Old 06-08-2010, 01:41 AM   #1854
kschu's Avatar
any brand will do...i will go for cheapest oil...
Old 06-08-2010, 09:33 AM   #1855
Barry White's Avatar
Originally Posted by Dual Fuel View Post
I actually totally agree with you. When I did my Mechanical theory at trade school we did a whole chapter on springs and yes Progressive springs are supposed to be tighter coiled either at one end or both. At least in the full-size world!
I was told by some-one at the last worlds who was told by an X-Factory Yokomo driver that the Yokomo springs were progressive.
Maybe they are not!! Perhaps Martin could jump in here and put the record strait.
I guess what really matters is how they perform for each of us but it would be nice to know for sure!
I could be wrong but here's what I think:
There are different linear coiled springs that for example read 200gr at 1cm compression. From those springs the are some with fewer/more winds or a smaller/bigger diameter. Although the winds are parallel to each other one spring will have for example 100gr @ 0.5cm, 200gr @ 1cm, 300gr @ 2cm and an other will have 75gr @ 0.5cm, 200gr @ 1cm, 325gr @ 2cm. So people will say one is more progressive becouse it gets harder compared to an other spring although spring rates stay linear and is something completely different than a real progressive spring with different coils.
Barry White is offline   Reply With Quote
Old 06-08-2010, 01:12 PM   #1856
altreyx's Avatar
i agree on what you say but i find really hard build a spring with a different diameter because a spring is build working on a single steel (thin) bar. I have the HPI springs and the Yokomo ones. I was looking at the coil diameter and is not changing, every coil has the same diameter.
At the end I think that there is a misunderstanding on what PRO means on Yokomo springs... could be PROfessional?..don't know.
For me this link explain well what a "progressive spring" is, http://www.tuninglinx.com/html/suspension-springs.html
I use HPI and Yokomo springs and I found the HPI ones better in Indoor tracks while Yokomo, for me, are a little bit better for our Outdoor tracks.
May be Martin will enlighten us about this
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 06-08-2010, 01:17 PM   #1857
The springs I am talkin' about are perfectly linear. By the the dia I mean the spring dia (Tamiya is 13mm and a bit and most others are 14mm) and not the wire dia becouse then you WOULD have a progressive spring.
Old 06-08-2010, 06:17 PM   #1858
dsyed1's Avatar
so where can one buy a yokomo bd-5 kit and parts? teamyokomo.com did not seem very helpfull... are there any other sites that I can look at?
thanks!
dsyed1 is offline   Reply With Quote
Old 06-08-2010, 06:27 PM   #1859
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
thanks!
I got my one from here..
http://www.rcmart.com/catalog/rc-yok...s-p-31297.html
and got my spares from
http://rcmarket.com.hk/index.php?cPath=51_98_116_246
http://www.rc-mushroom.com/index.php?cPath=36_382
Hope this help and I did not take all the spares
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 06-09-2010, 01:10 AM   #1860
and how I overheat when the tires, what is the correct working temperature of a tire if it is 30 degrees air temperature and 40 degrees alphalto greetings
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
