Old 06-06-2010, 03:49 AM   #1831
Send a message via Skype™ to JordanC
Originally Posted by kschu View Post
im not sure mate, even my self cant adapt to the yokomo spring...i feel my car stiff if i use them even i use softer yokomo spring like pink and blue....
my laptime bcome slower if i use them....
maybe different preference from each driver..
You could be right KS. Both Ryan and I have had a bit of a "rule of thumb" when it comes to the Yoke springs. Whenever the temperature is low, they seem to work, when it becomes warmer than 20-25 deg C then they seem to go off a little bit. Given you are in Malaysia, you may find exactly the same thing. Can't explain why they are like that, just what we have noticed.
JordanC is offline   Reply With Quote
Old 06-06-2010, 05:10 AM   #1832
mikeygar's Avatar
Trader Rating: 14 (100%+)
Great discussion going on here! I'll try the HPI Pinks and Silvers and see if they will suit my driving style. The PInks in front and Blue ones in the back seem to work for me already, but I'm assuming that since the silver ones are closer in rate, they should give an even more consistent feel. Will try it out on Tuesday and report back here my findings
Thanks guys!!!
mikeygar is offline   Reply With Quote
Old 06-06-2010, 12:24 PM   #1833
altreyx's Avatar
Originally Posted by Dual Fuel View Post
Yeah,have to wonder if he even owns any other springs at all!
Just as a bit of info here are the rates:
HPI:
Silver: 16.9 lb Linear
Pink: 18.0 lb Linear
Yoke:
Green: 17.0 lb Prog
Orange: 18.5 lb Prog
As you can see the advertised rates are very similiar, but as Jordo says the Yoke springs we have at least, tested a bit softer across the board.
Also the yoke springs are progressive, not linear like the HPI springs. This seems to make the car a little easier to drive for us mere mortals. So for those guys who dont own the above HPI springs or even if you do; give the yokes a go as well, they are a great alternative at times. Especially on med/high traction. If the traction drops just go down a spring rate all around. Either Pink/Green or even Yellow/green.
i was reading something about the springs: linear or progressive.
HPI are linear because the progressive ones are build with differents coils, cecking on the HPI website is possible find what is progressive or not.
But having both sets (HPI and Yokomo) for me Yokomo aren't progressive because are similar to the HPI while the progressive springs should have a difference space between their coils.
For me they are simple called Yokomo Pro Springs but PRO doesn't mean progressive.
May be i'm wrong but how can you define a progressive spring, for what i saw all the progressive springs have like a top and a bottom side.
Many thanks for who can explain me if i'm right or not
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 06-06-2010, 01:40 PM   #1834
Default ANTONI
Hi I have a problem with the wear of the front and rear wheels, I was more worn on the outside and inside a slot is marked by the center as new, I'm using 1.5 camber angle
manchu is offline   Reply With Quote
Old 06-06-2010, 04:47 PM   #1835
Goingfast's Avatar
Trader Rating: 29 (100%+)
yokomo BD drive shaft ( dogbone end)
Can someone tell ,what mm is the length of the unversal drive shaft? 44mm,42mm ?
question 2 ...what mm size of the ball end that goes inside the outdrive? 68mm.59mm 62mm not sure...Thanks
question 3
What other TC are interchangeable shaftdrive to yokomo BD5?
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 06-06-2010, 07:33 PM   #1836
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
question 3
tamiya 46mm, 44mm, top photon 46mm
but need to use the whole set...
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-06-2010, 07:34 PM   #1837
kschu's Avatar
Thanks guys!!!
i tried hpi blue for rear, make my rear very bouncing/floating....maybe good for smooth and flat surface
Old 06-06-2010, 07:36 PM   #1838
kschu's Avatar
it's might cause by the tyres insert...insert that thin and soft will cause this happen....try sorex c-med insert...
Old 06-06-2010, 09:03 PM   #1839
Hello
Would anyone tell me the purpose of raising the camber link by adding shims on both the inside and outside mounting (i.e., e.g. adding 0.5mm shim on the rear hub and also adding 0.5mm shim on the bulkhead at the same time)? Actually, the link angle doesn't change, right?
Thanks!
yokfans is offline   Reply With Quote
Old 06-06-2010, 11:41 PM   #1840
I actually totally agree with you. When I did my Mechanical theory at trade school we did a whole chapter on springs and yes Progressive springs are supposed to be tighter coiled either at one end or both. At least in the full-size world!
I was told by some-one at the last worlds who was told by an X-Factory Yokomo driver that the Yokomo springs were progressive.
Maybe they are not!! Perhaps Martin could jump in here and put the record strait.
I guess what really matters is how they perform for each of us but it would be nice to know for sure!
Dual Fuel is offline   Reply With Quote
Old 06-06-2010, 11:52 PM   #1841
Originally Posted by yokfans View Post
Hello
Thanks!
You are correct in that the angle of the Upper Camber Link does stay the same if you place the same shim under each end. However you do increase the intersection point of the upper and lower arms and the wheel contact point (Instant Roll Centre)
To cut a long story short by raising both you will lower the roll center very slightly giving the rear slightly more grip, especially on-power. It will also stabilize the cat slightly as well.
Old 06-06-2010, 11:54 PM   #1842
OK, OK,I know we all like a stabilized CAT. But in this case I meant CAR
Old 06-07-2010, 12:40 AM   #1843
Thanks a lot!
Old 06-07-2010, 02:14 AM   #1844
Yokomo_Ant3's Avatar
sounds like your car is rolling too much. Try 1 rate harder spping front and rear, or go 10wt oil harder all round
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 06-07-2010, 04:15 AM   #1845
Unhappy for antoni or kschu
I am using the setup that you publish and 35w oil schumacher and tires LRP VTEC 30x
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
