Old 05-05-2010, 02:09 PM   #1696
RC MARKET's Avatar
Originally Posted by yokfans View Post
Great thanks. Would you tell us the tire insert you are using? Thanks again.
Yokomo Wheel TW-1012-2
Yokomo ZR-039M
Sorex Tire
had best choice !
RC MARKET is offline   Reply With Quote
Old 05-05-2010, 05:13 PM   #1697
Yokomo ZR-039M
Sorex Tire
had best choice !
But the fast guys in my local track use Hara V2 purple insert or RIDE orange insert.....anyway, the 039M is really good....
yokfans is offline   Reply With Quote
Old 05-06-2010, 06:57 AM   #1698
altreyx's Avatar
Default Yokomo BD5W Setup Sheet Low Quality
hello guys,
i made a new setup sheet and now is possible share on this forum our setups.
Now the file is less than 300Kb so will be possible upload it without problems.
I called it "low quality" but in real is not so bad as quality.
Hoping you will like my job,
Andrea
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 05-06-2010, 09:10 AM   #1699
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by altreyx View Post
hello guys,
Andrea
thanks mate
Give the best while u can !
kschu is offline   Reply With Quote
Old 05-08-2010, 05:20 AM   #1700
Wicksy1's Avatar
Hey guys could you tell me where i can get a Roche Spool from ???
That'll do donkey, That'll do.
Wicksy1 is offline   Reply With Quote
Old 05-08-2010, 05:33 AM   #1701
Elwyn Lee's Avatar
Wicksy1,
You can PM me for more info.
Cheers,
Elwyn
Hobby Haven Sdn Bhd
Tel / Fax : +603-7499 4191
Email: [email protected]
http://www.hobyhaven.com.my - http://www.hobby-haven.blogspot.com - http://www.teamyokomo.blogspot.com
Elwyn Lee is offline   Reply With Quote
Old 05-08-2010, 05:36 AM   #1702
Send a message via Skype™ to JordanC
Welcome Matt.....
JordanC is offline   Reply With Quote
Old 05-12-2010, 04:56 AM   #1703
KoolRC's Avatar
Trader Rating: 67 (99%+)
Originally Posted by JordanC View Post
Welcome Matt.....
yokomo ttt
top photon ex
top rebel 12
crc xti
DANIEL MEDINA
KoolRC is offline   Reply With Quote
Old 05-12-2010, 02:40 PM   #1704
SammyZ's Avatar
Trader Rating: 138 (100%+)
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 05-14-2010, 09:20 PM   #1705
hotdognobun's Avatar
Trader Rating: 31 (100%+)
Anyone having issues with the front belt rubbing on the steering post? my paint paint is starting to wear
hotdognobun is offline   Reply With Quote
Old 05-15-2010, 08:04 AM   #1706
Hello all
Run my BD5W the 1st time today....very very happy with the car.
Tons of grip....super easy to drive
Thanks to Antoni for sharing his setup for reference....
I'm now using the following with my car:
Fr suspension mount: FF & FR 42mm
Rr toe: 3 deg
Shock mounting on Fr shock tower: hole 3 (car more responsive)
Center link: R8
Hole on steering block: outer hole
Tire: Sorex 36R
Insert: Hara purple (I've tested Ride orange and Hara black but it's just too much grip and results in a little understeer)
Tire treatment: Tire Tweak
Fr & RR downstop: 6mm under arm
Fr & RR camber: -1.5 deg
Fr Drive: Spool
Motor: X12 4.5t
Shell: Speed 6
All others are kit setup. Track condition is med-grip asphalt.
Old 05-16-2010, 04:22 AM   #1707
Default BD-D5W
Here's a video of my BD-5W, to constipation, the track did not have as much grip it had rained the night before, the setup used is anguna antoni with small modification
http://www.youtube.com/watch?v=wCHHyhX4xDE
manchu is offline   Reply With Quote
Old 05-16-2010, 04:50 AM   #1708
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Looking good
I ran my car the past 2 weekends. Last week was at a large IC car track with low traction. The car worked great and i didnt have to change anything besides making the front spring harder. Today i ran at my normal track and had a reasonable day. I was paying around with a few things, mainly testing between 43.5 and 42mm front suspention blocks. Im still undecided to which is better but the 43.5 did give the better laptimes, but the car was a bit more inconsistant to drive (mainly me). I guess ill have to keep testing
I have the 2010 victorian state Titles here in Australia in 2 weeks so hopefully the car works well over there.
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 05-16-2010, 12:58 PM   #1709
altreyx's Avatar
Originally Posted by Yokomo_Ant3 View Post
Looking good
Hello Antoni, what is changing with 42mm blocks?
Thank you
Orca-Gm120
Reedy-Lrp
Helios EX10
Old 05-17-2010, 03:44 AM   #1710
Thank you
Yesterday it seemed hard to tell for me but this is what i found. The 43.5mm front blocks definatly have more high speed steering, but you lose some initial turn. Other than that car was pretty similar. I also traction rolled (once)with the 43.5mm front blocks and never had this problem with the 42mm.
Antoni
Antoni Caretti
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
