Old 04-14-2010, 12:06 PM   #1561
Could someone or some people please help me with a list of spares and option/tuning parts for the BD5W.
I'm looking to place an order for one, but as i'm in the UK want to add some spares and as i'm new to Yokomo, some Tuning parts also.
What is exactly new on the BD5W that i will need extras of in case of breakage ?
And the suspension holders, what extra ones do i buy?
Shall i get some Driveshaft Bones for the front? Are those the 45.5mm ones? In case i bend one...
For the above, do i get the Standard (Steel) ones or the blue Alloy ones?
Do the C Hubs come in different degree's of Castor?
The main reason i'm asking all this is i could only download the 'old' BD5 Manual and that was mainly in Japanese, which unfortunately i can not understand...
Sorry for all the questions, hopefully once the car is here, i'll have the info in the manual
Cheers
russmini is offline   Reply With Quote
Old 04-14-2010, 04:26 PM   #1562
KoolRC's Avatar
Trader Rating: 67 (99%+)
does anyone have anyold bd or bdm parts roller etc they wanna get rid of? im still gonna get the bd5w but still love my bdm
top photon ex
top rebel 12
crc xti
DANIEL MEDINA
KoolRC is offline   Reply With Quote
Old 04-14-2010, 06:06 PM   #1563
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Cheers
u might need to get a plastic C-Hub (if your crash alot), Knuckles, front spool (roche or the new spool of Yokomo).
the rest is quite durable.... i never bent a Dog bone yet,,,,front is 45.5mm, rear is 44mm. BD5 C-Hub only 4degree....
Give the best while u can !
kschu is offline   Reply With Quote
Old 04-14-2010, 07:34 PM   #1564
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Here are the spares/options i would get
Roche spool
BD-008FG - Lightweight Graphite Front Suspension arms
BD-008RG1 - Lightweight graphite rear suspension arms
(Damper mounting position 39.5mm)
BD-010TP - Joint / pin (pin φ2)
BD-189L - Rear Drive Belt (Rofurikushon)
BD-301RR1 - Rear block (Makes 3d toe). Get the 45.7 rear block if racing slower classes also (17.5 and down)
BD-412W - sway bar kit
BD-412H - Aluminum stabilizer (Swat bar holder) x2
BD-201R8 - 8mm sentre steering rack (Makes car more twitchy)
BD-413 - plastic c-hub
BD-415SG - Graphite steering block
BD-415RG - Graphite rear hubs
BD-500DP - Diff blades
BD-506 - Diff rings
BD-516L - Front belt
Also a spare thrust bearing which i cant find the part number for. $2 US
There are other spares that you can buy if you like having spares. An extra diff for example. etc etc....
There are other bling parts that make the car look pretty like mine. But they wont make you go any faster
Hope that helps,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-14-2010, 07:52 PM   #1565
kschu's Avatar
Roche spool
BD-506 - Diff rings
Hope that helps,
Antoni
You r early mate....cant wait to test your W ???
Old 04-14-2010, 07:56 PM   #1566
Nope cant wait... A few more hours
I forget to mention spurs. Get a couple spare. The xenon spurs work well.
Antoni
Antoni Caretti
Old 04-14-2010, 08:05 PM   #1567
Send a message via Skype™ to JordanC
Antoni
What took you so long. Been there, done that!
JordanC is offline   Reply With Quote
Old 04-15-2010, 01:23 AM   #1568
Cheers all, big help.
1 more...
Do the Xenon 48DP Spur Gears fit fine ?
I've always run 48DP so have all the Pinions i need, would rather stay with those than having to buy all new pinions as well.
Thanks again.
Russ.
Old 04-15-2010, 01:25 AM   #1569
Sorry, 1 more
What is the Drive Ratio of the BD5W ??
Will help me work out what Spurs to buy.
Thanks yet again
Old 04-15-2010, 01:30 AM   #1570
kschu's Avatar
Sorry, 1 more
Thanks yet again
bd5W internal ratio = 2.0
yes, u can use 48p xenon on bd5w...
Old 04-15-2010, 01:50 AM   #1571
defcone's Avatar
Trader Rating: 15 (100%+)
Were the internal ratio's across all bd5's 2?
defcone is offline   Reply With Quote
Old 04-15-2010, 01:52 AM   #1572
kschu's Avatar
yes...all bd5 2.0 internal ratio....
Old 04-15-2010, 02:30 AM   #1573
Default center link
MARTIN Hello can you tell me I can say that is noticed in the car when I add a link center of 1 mm machine or if it remains at 0 mm thanks
manchu is offline   Reply With Quote
Old 04-15-2010, 03:05 AM   #1574
university_dave's Avatar
Cheers
I'd say Antoni is pretty much on the money there - although I'd get some of the Team Bomber belts and keep the originals as spares. Also, the graphite front c-hubs are fragile so it's probably worth keeping a few sets as spares. I've never had any problems with the standard UJs, although I am looking to have some new lighter ones on the car for the weekend - I'll post some pics when I've got them.
Where are you going to be racing it? I'm doing all the STCC rounds this summer so if you're around come and find me and we can talk setups.
university_dave is offline   Reply With Quote
Old 04-15-2010, 07:10 AM   #1575
fastolfart's Avatar
Well still no suitable answer to my question about the wheel hexs. Someone posted a part number, but these are not the original parts for a BD and no one stocks them as far as I have contacted.
As usual, there is no support for after you after you buy a Yokomo on here.
Go to the Xray, TOP, Tamiya threads and ask a question, and you are pounded by information.
BTW where is Martin of late, maybe a no show because his cars are so far removed from the average production cars that we spend our money on.
It is so hard to fix the driver, but so easy to blame the car.
fastolfart is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
