Old 11-18-2003, 06:47 AM   #1
fatdoggy's Avatar
R/C Tech Charter Subscriber
Default Rim Warping
Is there any way to either fix warp'd rims or stop rims from warping?
I run foams and the foam lasts alot longer then the rims do. Warping is a problem I've found with TRC and fast tyre rims(even the mtx3 rims). I'm willing to switch to rubbers to get rid of the warping problem if there are no stiff foam rims.
I run a C4 and if the rims warp even a little they rub on the hubs(I've already filed them down as much as possible). What company makes rims that don't warp and are stiff as all hell. I don't care if the rims break easily since I don't crash too much and you can just boil off the rubbers and re-use them. I'm sick of having the rims rubbing and creating drag.
Thanks for the help,
fatdoggy.
fatdoggy is offline   Reply With Quote
Old 11-18-2003, 07:22 AM   #2
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
didnt think foam rims warped by themselves. maybe those odd times you hit something the rims were warped.
i had a C4 all rims (except for the good ol inchups) rubbed on the hubs.
why dont you get a new car? x-ray hubs dont rub on any rim.
dontfeelcold is offline   Reply With Quote
Old 11-18-2003, 09:50 AM   #3
johnnywhopper's Avatar
CRC has a rim (for foam) that is exactly what you're looking. Very stiff and durable. It is a yellow 5 spoke though, not a white dish.
check out teamcrc.com for more info. click on track magnet directory and then yellow 5-spoke.
John
johnnywhopper is offline   Reply With Quote
Old 11-18-2003, 12:25 PM   #4
fatdoggy's Avatar
dontfeelcold - Yes I should have said, too much any more, I've had the rims for a few months and I crashed a fair bit when I first got them. I'm saving up for a Corally Assassin. Inch-ups, when I run rubbers. Thanks.
johnnywhopper - Thanks, they look good but they don't have them in soft enough compounds, also their 28mm not 26mm.
Old 11-18-2003, 09:30 PM   #5
Joel Lagace's Avatar
Try JACOS, The rims are very good. Also they have a good range of compounds. In 26 and 28mm.
26mm in spokes(not as strong)
28mm in dish the strongest(i always buy 28mm and trim to suite what ever car i run.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 11-18-2003, 10:29 PM   #6
Neil Rabara's Avatar
The only time rims won't warp is if it is made of metal.
Neil Rabara is offline   Reply With Quote
Old 11-19-2003, 04:50 AM   #7
hmmm stainless, chrome, titanium rims
Old 11-19-2003, 07:14 AM   #8
Matt Howard's Avatar
Have you tried Sorex rims? they are the stiffest ones I've found
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-19-2003, 07:54 AM   #9
John Fontaine's Avatar
Send a message via AIM to John Fontaine
I think the ofna dish rims are pretty strong, and at 8 bucks/8 pack they're a very good deal. I mounted my sorex on there and the tires wear off before the rims warped.
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 11-19-2003, 05:17 PM   #10
fatdoggy's Avatar
Thanks for the help guys, I think I'll take the foams I have off the rims and mount them on white 24mm ofna foam rims and hope for the best.
Old 11-20-2003, 10:07 AM   #11
Eddie M's Avatar
Thumbs up
Speed Mind foam tire work well with C4 and Serpent Impulse.
To solve the front rims fitting issue on the C4, you can replace the Serpent steering block with XRay steering blocks.
Let me know if you want to see some pictures.
Eddie M is offline   Reply With Quote
Old 11-21-2003, 08:24 AM   #12
fatdoggy's Avatar
Eddie M - Cool thanks for the info, I'll definately look into that if I decide to keep the car long term instead of updating.
Old 11-21-2003, 04:25 PM   #13
Eddie M's Avatar
Smile
You are welcome.
Take a look at what I did for the front end
The down side of this conversion is that you need to replace all the steering block parts with XRay Evo2 Freedom of choice steering block parts.
The speedmind foam and rims on the C4
Old 11-21-2003, 08:13 PM   #14
fatdoggy's Avatar
Wow that is cool! very clean intallation. It would get rid of the hugh amount of play my C4 has in the front end too. The speedmind rims have a heap of space.
Thanks man that's a big help.
Mtx 3 bumper warping,limiting suspension,any fixes? alvinm Nitro On-Road 8 08-04-2003 06:18 PM
