Belt Sizes from Various Cars >
Like Tree1Likes
    Hide Wikipost
Old 08-13-2018, 05:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Belt Sizes from Various Cars
Last edit by: WagwanBumba
Belt Length = (teeth count) x (teeth size)
Car Name {center/f-r pulleys} (front/rear teeth count) (teeth size)
  • HB Cyclone (169/62) (3.0mm)
  • HB Cyclone TC (170/63) (3.25mm)
  • HB TCX (171/64) (3.0mm)
  • Yokomo BD (172/63) (3.0mm)
  • Kyosho TF5 (149/74) (3.0mm)
  • Tamiya TRF414m (169/59) (4mm)
  • Tamiya TRF414m2 (169/59) (4mm)
  • Tamiya TRF 415(169/59) (3.0mm)
  • Tamiya TRF 416 (172/58) (3.0mm)
  • Tamiya TRF 416X (172/59) (3.0mm)
  • Xray T1/ T2 / 007 (169/60) (3.0mm)
  • Xray T2 008/009 EU {20/3a 4t} (169/61) (3.0mm)
  • Xray T2 008 EU {16/38t} (??/??) (3.0mm)
  • Xray T2 008/009 US {20/34t} (169/62) (3.0mm)
  • Xray T2 009 EU Motor Forward Conversion {20/38t} (167/66) (3.0mm)
  • Xray T3 EU {20/38t} (171/63) (3.0mm)
  • Xray T2 2012 {20/38t} (171/63) (3.0mm)
  • Xray T4 {20/38t}
  • AE TC5 (172/64) (3.5mm)
  • AE TC6 (172/64) (3.5mm)
  • Corally RDX/Phi (169/62/70/71) (3.0mm)
  • Schumacher Mi2/3 (171/60) (3.6mm)
  • Schumacher Mi6Evo (171/60) 3.0mm
  • Serpent S400 (167/59) (3.5mm)
  • Robitronics Avid (185/62) (3.00mm)
  • TOP Racing Scythe {15/33t} (130/94) (3.00mm)
  • TOP Racing Photon {20/40t} (172/63) (3.0mm)
  • TOP Racing Photon with XRay 38t spool/diff {20/38t} (171/62) (3.0mm)
  • Awesomatix A800 {20/38t}
  • Awesomatix A800X {20/38t}
  • Gizmo Beta {20/38}
  • Gizmo GZ2 {18/35}
  • Capricorn TE03 {19/38}
  • Destiny Rx-10sr {20/37t}
  • Destiny Rx-10sr {20/38t}
  • Destiny Rx-10sr {20/40t}
  • Sakura Zero (174/57) (~3.5mm)
  • Sakura Xi (172/59) (~3.5mm)
Print Wikipost
Old 03-06-2009, 12:18 AM
  #16
Skitee's Avatar
Originally Posted by airborneranger
If the belts are the same teeth, does that mean that they are the same length?
Yes all the belts use a 3mm tooth pitch so belts for different cars with the same number of teeth will be the same length.
Skitee is offline
Old 03-06-2009, 03:13 AM
  #17
Andy63's Avatar
What about the Kyosho TF-5 SHIN or regular TF-5?? Can it fit the Xray T2 008
Andy63 is offline
Old 03-06-2009, 04:52 AM
  #18
Skitee's Avatar
Another update
HB Cyclone (169/62) (3.5mm)
HB Cyclone TC (170/63) (3.5mm)
Yokomo BD (172/63) (3.5mm)
Xray T2 008 (169/61) (3.0mm)
AE TC5 (172/63) (3.75mm)
Skitee is offline
Old 03-06-2009, 07:24 AM
  #19
seaball's Avatar
Originally Posted by Skitee
Another update
AE TC5 (172/64) (3.75mm)
that is beautiful. one tweak added.
seaball is offline
Old 03-06-2009, 08:32 AM
  #20
ShaunMac's Avatar
The Cyclone belts are 3.0mm wide.
ShaunMac is offline
Old 03-11-2009, 11:55 PM
  #21
wheruat's Avatar
whats up everyone the Robotronics Avid is 185T/62T
wheruat is offline
Old 05-07-2009, 09:35 AM
  #22
seaball's Avatar
another update
seaball is offline
Old 05-07-2009, 10:09 AM
  #23
Hyde's Avatar
You should do them in order from the nost tooth belt to the less tooth belt that would be cool
Good to know that belts are interchangable from cars
Hyde is offline
Old 05-07-2009, 10:14 AM
  #24
razzor's Avatar
TOP Racing Scythe 15/33t pulleys (130/94 ) (3mm)
razzor is offline
Old 05-07-2009, 10:43 AM
  #25
Thirtybird's Avatar
Great resource! I've been trying to source belts for my car as the oem belts are no longer available in the US!
I'll add one, and will probably be the only one to care it's on the list :
Kawada SV10 Alcyon (172/57) 3.0 mm
Thirtybird is offline
Old 05-07-2009, 11:23 AM
  #26
HB Moose's Avatar
These 3mm pitch belts are not just used on RC cars. There are suppliers you can buy directly from. I don't know of any off hand but a little online research should find a parts house.
HB Moose is offline
Old 05-07-2009, 11:45 AM
  #27
asw7576's Avatar
The belt manufacturers like bando and mitsuboshi, they sell their belts by 1 sleeve. 1 sleeve can be cut into 70 to 90 belts, depending on the width you want to be cut. The retailer have the cutting machine.
If you have group of friends willing to buy 5 belts at once, you'll be surprice each belt only cost you few dollars.
Most RC belts are coded S3M XXX, S3M means 3mm pitch, and XXX means the total length of belt in mm. Divide the length ( XXX) by 3, and you get the number of teeth.
asw7576 is offline
Old 05-07-2009, 11:49 AM
  #28
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Here is where I get my belts from
http://www.gatespowerpro.com/Comerge...TOKEN=68572846
Marcos.J is offline
Old 05-07-2009, 12:12 PM
  #29
asw7576's Avatar
Originally Posted by Marcos.J
Thanks for the link ....... but I don't see 3.5mm or 4mm width in there
I live outside USA...... The last time I contact Gates was Gates's distributor in my country, the sales lady wanted me to buy 1 sleeve
asw7576 is offline
Old 05-07-2009, 12:47 PM
  #30
seaball's Avatar
obviously, the front is easy. here's your rear:
seaball is offline
