What is the Best LiPo Race Charger?
Thunder Power and the Hyperion chargers look pretty good. If you have a GFX now you can send it in for a Lipo software update and just use that. You would only need to get yourself a balancer to use with it. I believe the two I mentioned about come with a balancer already.
Tech Legend
Hyperion makes some really good chargers with the built in balancer already. Also they can be updated by hookup to a PC.
The Duo one they sell also can charge two individual packs at the same time regardless of what they are. when I was doing 1/10 scale truck, I would charge my 7.4V pack, and then also charge my transmitter pack at the same time.
now, I chage 2 7.4V packs together as one pack (sync mode) for my E-revo.
It's hard to beat Hyperion with the upgradable software. The AC/DC version is nice if you don't plan on charging above 1C. The DUO is sweet if you need to charge two packs at once, and will go up to 10A per side.
http://www.allerc.com/product_info.p...oducts_id=3367
http://www.allerc.com/product_info.p...oducts_id=3589
Hyperion also has some PC software you can use to watch your packs more carefully while they're charging. It's neat stuff, with pretty graphs and the like.
Finally figured out that you weren't scooby hahaha.
I have an extra hotwire brand new in the box if you still need one (this is tory from the mushroombowl).
I've been using a duratrax ICE and an Orion advantage carbon. The carbon charges MUCH faster than the ICE does, but doesn't have the ports to plugin the balancer and the screen is a little small, Marvin has the checkpoint and that one charges faster than the ice as well, the ice does a great job consider the price and all things considered i'm happy with it.
I am thinking about upgrading to a hyperion myself though because all the electric flight and heli guys say they are the best there is at lower cost lipo.
probably either pulsar 3 or core rc
I know who you are now i was yelling at scooby the whole weekend until he figured out what i was talknig about haha. I kept asking him for his tekin so i could put it on the computer hahaha.
Either way, i have a couple differnet types of lipo chargers and i've been looking to the electric heli and plane boards for help as they've been using lipo's for years longer than we have. They all seem to like the hyperion stuff, and most of the stuff we are getting are rebranded plane stuff like the core-rc which is actually an Imax charger rebrnaded, so is the losi. Imax is another brand that has a high end lipo charger but the hyperion connects to the pc and allows some killer stuff!! The downside is it doesn't cycle batteries (at least not yet) so you will need some way to discharge if you feel the need to cycle your nimh cells.
Once your battery is done on the Carbon, put it on the Ice and see how much more charge it takes. For giggles, charge your pack with each charger and then measure the voltage afterwards. The carbon doesn't fully charge the pack. All those little chargers like it have the same problem. I was putting in another 300mah between the carbon and Ice.
I also like that the checkpoint and hyperion allows you to charge at more than 1c, the checkpoint allows up to 10 amps (it's little brother the ICE is 1c only).
I had the Checkpoint, it's definitely a nice little charger.
