Old 02-23-2009, 09:11 PM   #1
Default Does it matter?
what is better (hypothetically thinking), 2 25C 2S 6000mah in series or 2 25C 4S 3000mah in parallel. I understand they would have the same characteristics but was curious if one would perform better than the other
sivob is offline   Reply With Quote
Old 02-23-2009, 09:17 PM   #2
snoopyrc's Avatar
Well in series is going to give you twice the voltage so there it is. Double the voltage will make a bigger differrence than the C or the mah, but it sounds like you are getting ready to fry some electronics. Are you sure you are ready for that? The other thing is what are you looking for when you say performance? If you want it to run twice as long then go for the parallel wiring.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 02-23-2009, 09:23 PM   #3
wingracer's Avatar
Trader Rating: 24 (100%+)
Voltage and runtime is the same with these two set-ups.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-23-2009, 09:27 PM   #4
Wouldn't they be the same voltage of 14.8v?
Old 02-23-2009, 09:41 PM   #5
LOSI123's Avatar
Trader Rating: 63 (100%+)
Mathematicly C rating total and mah and voltage will all be the same, but i would think the 2 x 2S 6000mah packs would be better and more relaible as there is a total of 4 cells in the car (less conections and less to go wrong)
As with the other configuration there is a total of 8 cells in the car.
Cheers
LOSI123 is offline   Reply With Quote
Old 02-23-2009, 10:30 PM   #6
snoopyrc's Avatar
2s verses 4s ok. I missed that the first time.
Old 02-24-2009, 11:59 AM   #7
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
Generally C rating refers to the pack. If you put two 25 C rated packs in parallel you have assembled a 50 C pack. The series packs would only be 25C. If you are doing a speed record run at very high amps (250 or so amps) or you have the packs in a powerfull airplane this may make a difference. If not you will notice little difference.
John
John Stranahan is offline   Reply With Quote
Oshkosh Racing HALFFAST Wisconsin & Illinois Racing 7667 07-15-2017 07:46 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 08:58 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
Canadian Off-Road Championship Series Gary Fliegel Canadian R/C Scene 927 07-14-2009 11:20 PM
FK05 conversion Branden Moody Electric On-Road 24 10-13-2007 02:45 PM
2006 1/10 Fuel On Road Nationals. Info. reeso Nitro On-Road 618 09-28-2006 01:27 PM
Hobbytown KC Racing kansasracer Kansas/Missouri Racing 2842 05-24-2003 08:47 PM
