Old 02-24-2009, 01:47 PM   #16
revo61's Avatar
Trader Rating: 18 (95%+)
What is your complete setup?
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 02-25-2009, 02:10 AM   #17
tc3team's Avatar
You may find it beneficial to use lighter springs / oil / 3 hole pistons or a combination of these on the front/rear, as well as moving the shocks closer into the chassis on the top mounts if you have a lot of low speed corners. (but don't overdo it, do things in moderation ).
The simple reason for this is to generate more bite with the harder shore tyres, keeping the shocks upright on power will probably make the car push...
Even higher track temperatures can go in your favour also, It is more than possible to have fun with harder foams outdoors, so keep with it!
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 02-25-2009, 04:50 AM   #18
1rcracer's Avatar
Red face
hello....
well bogging down.... losing too much corner speed... scrubing all the momentum.... the car almost stops...
this is with a one way or diff...
would increasing just the shock oil or springs help carry a bit more speed in the corners....
1rcracer is offline   Reply With Quote
Old 02-25-2009, 05:02 AM   #19
tc3team's Avatar
1rcracer- with a one way of any description you should have plenty of entry speed off power.
The most important thing once you are there, naturally is getting the amount of speed and enough rotation from the back of the car to get it round the corner, and out the other end.
Too much speed, and obviously you will be off the racing line... Finding a balance of grip and speed is where we are now in any cornering situation.
I would experiment first with laying in the top of the shocks a little, to see if that helps.
If it doesn't, I would then look at changing springs, and if there is a big change needed to the springs, look at changing oil and possibly the pistons too.
You may also want to try changing your droop settings, but these can make very big changes to the cars behaviour, and sometimes even aid lifting an inside wheel on the entry or apex... so play with that setting very carefully.
Only change one thing at a time each time the car goes on the track to see any change taking place, or you will be chasing the setup...
If the grip is low full stop, I would suggest either a spool or a diff up the front, as with lots of off power speed and no grip, you are asking for one thing.... trouble! lol
If anything in low grip situations, you want the drivetrain "drag effect" to be helping you when you let off the throttle, to help the car scrub speed and stand a better chance of rotating well mid corner.
You wont get that with a one way.... Drag brake dialled into the ESC if its a small track may help.
If there is no grip, you just have to slow the car down, plain and simple and wait until you have passed the apex before you can use the throttle.
But!!! If you are using drag brake, that may just be masking an unsuitable setup for where the car is being used...
Old 02-25-2009, 06:04 AM   #20
Ricky/C's Avatar
Send a message via MSN to Ricky/C
Originally Posted by 1rcracer View Post
hello....
Hiya, you're racing at K90 right? I recon you should use less droop. My car is set like a go cart, but you're racing mods, so I can be totally wrong, hahaha
TRF 416 WE | LRP SPX Stock Spec| 17.5 SP | Sanwa M11
TRF 416 WE | LRP TC Sphere | Novak 3.5 | Sanwa M11
www.oneten.co.za >>>>>>>>>>>>>>>> Home of RC in SA
Ricky/C is offline   Reply With Quote
Old 02-25-2009, 06:26 AM   #21
1rcracer's Avatar
yeah k90 dude...
what class u race....
im gonna try and get the car to work with a diff.... get some brakes going...
the times im gettin now aint too bad... will make b-main at the nats...
but A is the target....
tks ill try less droop next time out...
what class do you race ?
Old 02-25-2009, 06:27 AM   #22
1rcracer's Avatar
hey tc3team .... some good advice tks.....
Old 02-25-2009, 06:40 AM   #23
tc3team's Avatar
No problem, any time.
To understand what is going wrong, you have to ask yourself "why?", which you are
Old 02-25-2009, 10:43 AM   #24
revo61's Avatar
Take a look at the xray setup book. Its great for general setup knowledge.
Old 02-26-2009, 04:10 AM   #25
tc3team's Avatar
Right guys, just to add on my first post about suntan lotion...
For it to work well, you will need some high factor cream.
What the sun tan lotion does is "seal the additive" into the tyre. So with that in mind, put some of your usual additive into your foam, wipe off any excess, then apply your sun tan lotion.
(But don't use the same bottle of sun tan lotion for yourself, unless you want to replace heat rash with tyre additive rash.... )
Old 02-26-2009, 05:51 AM   #26
1rcracer's Avatar
lol.
Old 03-01-2009, 01:05 AM   #27
smilekt's Avatar
i'm already using form trye with 37 shore front & rear .. with same rubber setup .. running on mod class .. very nice handling & good traction .. but out of corner having little spinning when you pull throttle to full .. need drop more shore to 35 or 36 .. nice thread .. so far i will use form tyre for practice ... coz of saving then rubber tyre..
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 03-01-2009, 01:08 AM   #28
smilekt's Avatar
what suntan lotion u use ? .. how to use or how to apply to form tyre .. ?
Old 03-01-2009, 08:31 AM   #29
1rcracer's Avatar
Hey dude...
well i gotta say i tried 38 front and 35 rear worked ok
just as long as the track is consistant through all the turns...
its funny some cars take nicely to the foams and some need some serious upgrades.... ie thicker decks all round....
Old 03-01-2009, 10:44 AM   #30
Ricky/C's Avatar
I've got a 4mm bottom deck on my TRF and I run foams Boy is it running sweet! I ran regionals today and did super... Reached my goal
1/12 forum ovalnator Electric On-Road 46189 Today 08:13 AM
Team Corally RDX Touring Car Kenshin Electric On-Road 10561 11-21-2015 12:54 AM
F201 MYXTYPLYX Electric On-Road 2509 03-03-2013 10:24 PM
Kyosho Touring Car kylehirano Electric On-Road 2057 12-08-2011 11:37 PM
‘Official’ On-Road racing of 1/18 scale Off-Road Vehicles Thread imjonah Micro and Mini Scales 13 10-10-2007 08:45 AM
RCO Racing in PA chef88 Racing Forum 7190 03-10-2006 01:32 PM
Belt Driven vs. Shaft Driven Allen Sondej Electric On-Road 69 11-05-2004 08:51 PM
