Old 11-15-2003, 08:21 AM   #1
Super Steve's Avatar
Send a message via AIM to Super Steve
Talking Plugs and plugs and plugs
There are many brands of "Corally-type" battery plugs.
Are they all the same or some of them are better then the others?
http://www.carttonic.com/files/pic.p...400&noconfig=1
http://www2.gpmd.com/image/t/tric6022.jpg
http://www.corally.com/images/1630.jpg
The teamorion and the corally male plugs are twisted for "30% ore efficeincy" whil the trinity one is not.
Please project your thoughts!
Super Steve is offline   Reply With Quote
Old 11-15-2003, 11:03 AM   #2
Regional Moderator
disaster999's Avatar
i dont like the trinity stuff...its really stiff and it doesnt shove into the plug that much, i like the team orion the best!
disaster999 is offline   Reply With Quote
Old 11-15-2003, 11:23 AM   #3
dpaton's Avatar
Send a message via AIM to dpaton
The spiral plugs will be somewhat better from a mechanical standpoint. They'll be less likely to pull out, and more stable under vibration. Electrically...they're about the same. The spiral ones may have a slightly better contact profile, but with the low resistance of a gold-gold contact, it's not much of an issue.
If I wasn't using Deans plugs, I'd probably have the spiral Corally/Orion ones.
-dave
dpaton is offline   Reply With Quote
Old 11-15-2003, 02:28 PM   #4
V12
V12's Avatar
The Corally and the Orion plugs are basically the same. I think MC contacs are producing both. Corally brought them into the RC market long time ago. Iīm using them from the beginning and I think they have the lowest resistance. Also they never had been pulled out by crash in about 10 years.
V12 is offline   Reply With Quote
Old 11-15-2003, 02:39 PM   #5
do you solder the female plugs directly on the cell, or do you use a batt bar first?
Old 11-15-2003, 02:51 PM   #6
V12
V12's Avatar
directly on the cell for lowest resistance
Old 11-16-2003, 02:08 AM   #7
dpaton's Avatar
If you can do it in under 4 seconds, I'd recommend direct to the cell. if it takes more than 4 seconds to get a really pretty solder joint, use a bar too. The difference in resistance is so small you can ignore it...think thoudandths of a percent. It's better to be safe than sorry. Good packs aren't cheap. I've detailed the resistances of connectors and wire elsewhere. Suffice it to say that when soldered well, connectors are as good or better than the same length of wire.
My $0.02.
-dave
Old 11-16-2003, 04:17 AM   #8
V12
V12's Avatar
Of course you have to be fast when soldering directly at batteries. You have to use a good soldering station and itīs a matter of practice. So any newbie shouldnīt solder at the batteries.
But I have to say I donīt like connectors on batterie bars. Looks ugly.
OS Plugs joydude630 Nitro Off-Road 31 07-17-2008 02:22 AM
OS P3 plugs slowpokeRRR R/C Items: For Sale/Trade 6 05-31-2007 10:17 PM
Anybody tried these plugs? jamiekulhanek Onroad Nitro Engine Zone 5 11-17-2004 07:55 AM
Rex Plugs NitroOB4You Onroad Nitro Engine Zone 2 04-03-2004 01:28 PM
Plugs CeleryGod Electric On-Road 12 04-24-2003 08:00 PM
