---Good Idea? Something new---
#16
Very nice idea, but...
I think the electronics and sensors are already out there for us to in the future include them on motors internally, by the means of a small replacable PCB board, sensor and LCD temperature display, or with additional wiring meens, placing the LCD away from the motor.
Anyone else think this would look sick? (and not forgetting, work well lol)
Welcome to the F1 style and technical side of r/c, the Brushless motor system...
We are already hooking our Laptops up to ESC software, why not to have sensors connected to a PC with USB, or having standalone temperature sensors too?
You could probably get a greater degree of accuracy with a sensor too.
Or, a clip on sensor, with a connector of some description, connect it to your laptop without even having to take the shell off, job done.
#17
So are these things reusable? Meaning do they "reset to zero" when they cool off, or do they permanently the highest temperature they see? We had similar stickers were I used to work and I was always under the impression that those just recorded the highest temperature they saw, meaning once a square turned colors it never turned back (one use item). If these reset when they cool off, then this is definitely cool.
Though I already own a temp gun.
#18
Location: Colorado, USA, The land of the free and the home of the brave!
I can't talk for the ones mr. ament posted, but the ones used for the inside of fish tanks don't "stick" to one temp, they will fluctuate with different temps.
#19
Im pretty sure it tells the current temperature. So if your motor isnt in use, the sticker obviously wouldnt respond in color, because the motor is below the certain heat (around 140 at the lowest). So yeah, it would just be in the "Neutral" stage when its not in use.
#20
#21
Heh, like the other guy said, can't wait till Hudy gets his paws on these stickers, slaps the "OPTIMIZED" and "LUXURIOUS" tags on it then sells em for $35 a pop, instead of 3 for $20. LOL!!
I wonder if I took a dump in a bag and sent it over to Hudy, how much he can "optimize" and "luxuriate" my bag of dump and sell it!
Learn more about Slovakia: http://en.wikipedia.org/wiki/Slovakia
#22
#23
There you go Novak, LRP and all you other brushless companies out there!! Extra $$$ for you guys right there!! Now get on it!!
#24
I have one that is from Trinity. I got it from Josh H. If I am correct they have not been released for purchase. It works great!!!! I would like a couple more.
#26
#27
Hmm.... $20 for three...? the cheapest temp gun is about $25.....
Do these stickers give more accurate readings? Otherwise, i'd go for the $25 temp gun... even with S+H,... maybe $40... isn't that better than 6 stickers?
Though the stickers do look cool.....
#28
When?
the only downside is keeping the weight off the car as much as possible, and keep as many components in within the external hardware source, like ESC programming devices.
So you'd have a heat sensor or probe internal to the motor, soft flexible wire plugged into the nessesary hardware, hardware into PC/Laptop USB port, then fed into a frequent montioring software package, which updates every 2-5 seconds the temperature.
Maybe hella more long winded over a sticker, but some guys are suckers for uber high tech stuff.
I think the software would cost more to develop than the hardware imho, as it would be an add on to the motor if made internal rather than clip on....
The only downside to the heat sensor being built in to the motor is if the sensor goes way west, you may not have any way of replacing it unless the design of including it in the motor has been well thought out....
#29
if you want something digital then just use the Venom Micro temp monitor
weighs only 15g and cost only $15.99
http://www3.towerhobbies.com/cgi-bin...&I=LXHUH2&P=SM
#30
I'm pretty sure we have the tech to make it happen too, question is, as always...
When?
When?
