Spool?
Old 02-18-2009, 05:09 PM
minittrackmann's Avatar
Default Spool?
It seems as though all of the fast guys that run asphalt/rubber all run spools in the front. What exactly is a spool. I have a basic idea but not 100%. Why do they run them only in the front.
Also wouldn't a one way be equivalent to a "spool"?
Thanks,
Cody
minittrackmann is offline
Old 02-18-2009, 05:39 PM
Thanks,
Cody
Spool or a solid axle usually used for tracks that is slippery, small technical, or big wide tracks & tracks that needs braking. Thats for me...
A One-way is only a spool when on-power. Or not its not considered a spool. Usually I'll use a 1 way on small or mid size tracks with no need for braking for a hairpin.
Spool also suits a more aggrasive driving style.
Ben.C is offline
Old 02-18-2009, 06:03 PM
Thanks Ben, I was also reading a setup sheet. For toe it said 3degrees total. Does that mean 1.5 to each rear wheel?
Cody
Old 02-18-2009, 06:19 PM
Trader Rating: 71 (100%+)
Cody
thats 3deg on each side...
joey is offline
Old 02-18-2009, 06:24 PM
trdsupra88's Avatar
Trader Rating: 25 (100%+)
From what I have read, spools arent used on small tech tracks...they are only used up front because in the rear, they would act like a locked diff on a drift car...try running it only in the rear and you will quickly see what I mean...
trdsupra88 is offline
Old 02-18-2009, 06:25 PM
Thanks Joe.
Hey are you going to be coming down to Jackson at all this upcoming season?
Cody
Old 02-18-2009, 07:36 PM
Thanks Joe.
Cody
yup should be down a few times this summer since they are racing sundays this yr.. what car are you running now? thought you had a FK05
joey is offline
