Need help to get a 47 rollout. >
Old 02-13-2009, 08:30 PM
portyansky's Avatar
Trader Rating: 54 (100%+)
Default Need help to get a 47 rollout.
Im building a F103rm and was told to achieve a 47 rollout. When I plug the info into the rollout calculater the pinion spur combo doesnt seem right. Can anyone give me advise where I should start. I wanna run 64pitch, I currently have 64p pinions ranging from 18-22 so I would prefer to just buy a spur instead of pinions. Any help would be great.
Porty
portyansky is offline
Old 02-13-2009, 08:34 PM
rccar306109's Avatar
what is the formula for rollout?
what kind of track do you race on? oval?
rccar306109 is offline
Old 02-13-2009, 08:37 PM
Trader Rating: 71 (100%+)
your going to need to know the tire size to calculate a rollout....
joey is offline
Old 02-13-2009, 09:05 PM
portyansky's Avatar
I used this calc http://www.rcuniverse.com/community/gearwizard.cfm
Indoor carpet.
According to Towers spec, brand new rear tires for the F103rm are 60mm. And i am pretty sure i read somewhere 3.7 ratio. But the calc asked for tranny ratio, i assume its the same thing.
Porty
Old 02-13-2009, 09:42 PM
Thumbs up RE....Rollout
Try gearchart.com....The 103 is direct drive isn't it?????
THEBIGBULL is offline
Old 02-13-2009, 09:52 PM
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default rollout
yes go to gearchart .com and you can find what you want i was just there and if you have a 96 spur and a 24 tooth pinion you will get a 47.12 roll out and yes where it says pic a car you need to pick 10th /12th scale which they call pan car because your trans is 1.1 good luck and have fun you can just put your spur and the rest of your numbers in and go from there and dont forget as your tires get smaller you will half to recalculate your rollout
2056dennis is offline
Old 02-14-2009, 04:03 AM
Trips's Avatar
Trader Rating: 16 (100%+)
Porty,
80 spur 20 pinion will get you 47.1 rollout on a 60mm tire. For a direct drive car like yours, the tranny ratio is 1.0 or 1:1
To calculate rollout, use this formula:
(tire diameter * 3.14) * (pinion / spur) = rollout
for the number above,
(60mm * 3.14) * (20 / 80) = rollout, or
(188.4) * (.25) = rollout, or
47.1 = rollout.
Another handy formula is this one:
(spur/(tire diameter*3.14)) * rollout = pinion
Use that one when you know the rollout you want, and need to find the pinion to use.
Trips is offline
Old 02-14-2009, 05:06 AM
rcdude8's Avatar
Seen as this is sort of a gearing topic. I have a problem with motor heat. My 540 motor is getting extremely hot. At the moment I have a 96 spur and 58 pinion in. Is that over geared?
Ratio is: 4.03
Originally I had 96 spur and 48 pinion but that made the motor get hot as well. Well any help is very much appreciated.
rcdude8 is offline
Old 02-14-2009, 05:08 AM
portyansky's Avatar
Thank you!!
Thank you!!
Originally Posted by Trips View Post
Porty,
47.1 = rollout.
Thank you!!
All written down and saved.
