Old 11-11-2003, 09:06 PM   #1
Default holes in carbon fiber?
hey i have an old yokomo and i want to run it but it has no servo mounts so when i put the servo on with servo tape it always comes off. so i was wondering if i could make my own holes for my servo mounts
losi4life is offline   Reply With Quote
Old 11-11-2003, 09:09 PM   #2
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Yes you can
Drill the hole and then on the bottom drill it out with a bigger size drill bit but don't go all the way through the Graphie so that the Screws are then flush with the chassis. Then take some CA and a Q-Tip and seal the graphite where you drilled so it does not delaminate.
mike_Webb is offline   Reply With Quote
Old 11-11-2003, 09:10 PM   #3
Registered User
Suradaj's Avatar
You can drill a 3mm hole and install mounts. Try to counter sink the hole so that way you can use countersink screws and your chassis stay smooth.
Or......
You can use "Shoe Goo" or "GOOP". Glue it down where you want it and let it sit overnight. You can find that at a hobby store or a shoe store.
Suradaj is offline   Reply With Quote
Old 11-11-2003, 10:06 PM   #4
wagonman72's Avatar
Be VERY careful when drilling or cutting graphite, I have been told the dust is very dangerous and it makes you itch ALOT.
wagonman72 is offline   Reply With Quote
Old 11-11-2003, 10:14 PM   #5
horniez's Avatar
it's best to wet the chasis before drilling, & apply constant flow of water...
also, for precaution's sake, wear a mask to prevent breathing in the poisonous dust...
horniez is offline   Reply With Quote
Old 11-12-2003, 07:32 AM   #6
lee82gx's Avatar
if u have problems countersinking the holes,use a body reamer and do it manually,after the 3mm holes have been cut.
lee82gx is offline   Reply With Quote
Old 11-12-2003, 05:57 PM   #7
Talking
thank you alot i will my yoke running in no time
looking for some Carbon Fiber Scott8ight Nitro Off-Road 1 09-17-2007 04:55 PM
Carbon Fiber HK Racing Joe Electric On-Road 7 01-24-2006 03:33 PM
4mm carbon fiber ksj44 Electric On-Road 3 04-11-2005 02:45 PM
carbon fiber? cencalballer Electric On-Road 10 03-20-2004 12:45 AM
Carbon Fiber? SPC Racing Electric On-Road 17 02-26-2004 06:00 PM
