Old 02-11-2009, 06:49 PM   #1
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Default traction compound application
can i get a few sugguestions when to apply traction compound? this will be the first time applying it.
im using stick-it on foams on my f103
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 02-11-2009, 07:27 PM   #2
Fastforward's Avatar
I have an F103 that I run on carpet, here is what I do. 1) I apply cheap suntan loation on all four tires all the way across each tire. let it dry (about 15 minutes) and then wipe it off. Then apply paragon all the way across all four tires. Let soak for 3-5 minutes then wipe off with a rag. If this gives too much steering just do the inside 2/3's of the front tire.
I am not familiar with stick it but this is what I do.
Good luck
Bob DeGood
AKA Big Bad Bob
AKA BBB
Fastforward is offline   Reply With Quote
Old 02-11-2009, 07:41 PM   #3
Good luck
i will be rinning on concrete. is there a such thing as applying too early? like 2-3 days early?
Old 02-11-2009, 08:02 PM   #4
On foam tires I think 2-3 days ahead of time would not be useful. For concrete you might try sun tan lotion 30 minutes before run time. Sun tan lotion opens up the cells of the foam.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Old 02-11-2009, 08:07 PM   #5
I would start out by doing and using whatever the fast guys at your track use.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 02-11-2009, 09:08 PM   #6
CHRIS CHAVEZ's Avatar
Which suntan lotion are you using?
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 02-11-2009, 09:13 PM   #7
there are no "fast" f1 racers. now that i think about it, there are no pther F1 racers...
Old 02-12-2009, 04:03 PM   #8
run your f1... more people will see it, buy it, and the class will grow
rccartips is offline   Reply With Quote
Old 02-12-2009, 04:10 PM   #9
HarryN's Avatar
Send a message via AIM to HarryN
Not at my track it hasn't. Pan car expanded from a couple people to now 5. But F1 has not grown at all.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 02-12-2009, 05:52 PM   #10
I use jan tana.
ricktheracer is offline   Reply With Quote
Old 02-12-2009, 06:06 PM   #11
but when is "too early" to add?
Old 02-12-2009, 06:08 PM   #12
s13evo's Avatar
most people use coppertone sunblock 30-50 spf, they sell them at walmart for like $1.50. sunblock worked for me but only lasted a few run,, so im using paragon compound but is highly toxic and smelly.
s13evo is offline   Reply With Quote
Old 02-12-2009, 06:11 PM   #13
s13evo's Avatar
you can also use corally jack compound i heard alot of positives about that also. its ok to soak the compound overnight before a race next day ,but not sure about 2-3 days, thats a little too much. the longer you soak the better tho.
Old 02-12-2009, 06:30 PM   #14
Lebatek's Avatar
Send a message via AIM to Lebatek
Silver,
Whatever compound you choose to use, it needs to be applied 20 to 30 minutes prior to running your car, and worked in with your fingers in the case of suntan lotion, or let sit to absorb for Paragon. Wipe off throroughly before running. And repeat the same process before EVERY run. Applying it days or even hours in advance or not doing it for every run will completely negate the benefit it can provide. Start out doing full rears and maybe a quarter to third of the inside edge fronts, and add more or less based on how much steering you need.
And as mentioned above, check what the fast guys are doing to their tires at your track -- even if it's for a different class.
Good luck!
John Lebak
Sponsored by: Team Associated, Reedy, Airtronics, LRP, and Mugen
Lebatek is offline   Reply With Quote
Old 02-12-2009, 06:38 PM   #15
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default tire compound
i see alot of guys at our local track will put whatever compound they areuseing on there tires the day befor and then put then in zip lock baggies and when they get the tires out them things are just like they just put it on they claim that the sauce stays in the foam or rubber longer
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46181 Yesterday 02:42 PM
General Discussion Modena AL MSRA (Memphis, TN) 7895 05-05-2014 05:50 AM
Niftech Traction Compound odpurple Electric On-Road 42 01-01-2014 08:28 AM
Rain City rcracerric Northwest Racers 6484 04-30-2011 01:01 PM
Why did the stock drivers stay away fastolfart Australian Racing 159 05-16-2006 04:49 AM
