Tekin RS/RS PRO on 1s Lipo Q&A >
Old 11-27-2012, 07:56 PM
  #1141
Tech Legend
Cain's Avatar
Trader Rating: 251 (100%+)
thats the plan for sure just was hoping he could run.
I'll see if he wants to use my booster, I think my ESC will work without it as its a different brand.
Cain is offline
Old 11-27-2012, 11:22 PM
  #1142
RCknight's Avatar
Randy I didn't know where to post this so I'll go ahead and ask on this thread. Will Tekin ever make a speedo specifically for VTA racing? If not, why? Thanks
RCknight is offline
Old 11-28-2012, 07:20 AM
  #1143
Tech Legend
Cain's Avatar
got it confirmed by Tekin rep that it no longer works that way. Buddy got a booster on the way so will see how it goes.
Cain is offline
Old 11-28-2012, 08:27 AM
  #1144
Team Tekin
Randy_Pike's Avatar
I can neither admit nor deny that we may or may not be making a VTA acceptable esc.
Randy_Pike is offline
Old 11-28-2012, 12:25 PM
  #1145
RacinJ's Avatar
Randy,
You mentioned in the Duo 3.5 thread that 1s causes issues in the sensor port after hard hits. How can we check the voltage of the sensor port at home?
I sent my RSPro in for service back in july to check the sensor port and it still cuts out.
RacinJ is offline
Old 11-28-2012, 03:20 PM
  #1146
Team Tekin
Randy_Pike's Avatar
Grab a dvom, car on battery negative to the first pin on the motors sensor harness. Should be at 5v or higher. Some boosters though lower this to say 4.8v.
Old 12-28-2012, 12:28 AM
  #1147
RCknight's Avatar
Man...lol...seriously? Well how about a possible release date to neither admit or deny?
RCknight is offline
Old 12-28-2012, 03:55 AM
  #1148
Trader Rating: 62 (100%+)
I'm going to be running a RS Pro with TQ booster in 1/12. Should I stick with the Tekin cap or would something like this LRP setup be better? http://www.amainhobbies.com/product_...-48V-Capacitor
PROMODVETTE is offline
Old 12-28-2012, 07:06 AM
  #1149
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Use the Tekin cap
RedBullFiXX is offline
Old 01-07-2013, 01:09 AM
  #1150
SNIPR's Avatar
I run a RS Pro, Tekin Gen2, Radiopost radio w/ a hitec servo in my 1/12. I have to use booster or life pack. My friend has the exact same but different servo (can't remember which) and a RS and does not need to use booster/life in his 1/12... We can't figure it out other then perhaps his servo is not pulling as much amps?
SNIPR is offline
Old 06-18-2013, 05:42 AM
  #1151
ok so here is my problem. as the kick off to our on road is only a couple months away, I sit with 2 1s cars with no speedos I want a esc that wont need a booster/reciver pack and herd of a possability of tekin making one in the gen2. do i wait or no?
zeestraten46 is offline
Old 02-21-2016, 08:08 PM
  #1152
Default Rs no output voltage on a b c
Running tekin rs on 1s.. Have a Novak booster hooked from positive and negative on esc to receiver. Receiver switched off and booster on it powers up. Voltage on the pin of esc for positive and negative equal the voltage of the battery... Now here's my dilemma. When checking voltage on the output pins when u initially turn the esc on they jump up to 3 something volts... Then drop down to .54 volts on a b c posts... When throttle is applied the voltage drops to zero on abc but the positive and negative on esc are not affected... I'm sure someone has had this problem... Just curious what to do or if the esc is junk.... Used speedo, new booster and sensor wire....
8ightRacer14 is offline
Old 02-22-2016, 01:04 PM
  #1153
liljohn1064's Avatar
Trader Rating: 17 (100%+)
What you should see when you hook the booster to the 1S battery is 4.2 volts to 3.7 volts on the input side of the booster and 5.5 to 6 volts on the output side. The output side gets hooked into the receiver to ramp up the voltage required to run the receiver and the servo. Check the output with a volt meter. The ESC switch can remain off when you finally do have it running.
liljohn1064 is offline
Old 12-07-2016, 08:18 AM
  #1154
Rusty12nitro's Avatar
New to 1 S And Looking for some Info
I have a Tekin RS I put it on 1 S mode with the hot wire.
Now do I need to unplug The Red Wire or no ,
Can I use the on / off switch or no
I know this is a Old info but info on 1s is very limited out here
I just don't want to ruin a new ESC
Rusty12nitro is offline
