Old 10-25-2011, 10:41 AM   #1051
Buckaroo's Avatar
3 of us abused the crap out of our Novak boosters with boosted 13.5, never once saw a brown out. One of the guys even ran one with a 4.5 in Mod, never browned out on him, either.
Not saying it can't happen, just that you think it would have if it were common or a design limitation.
Either way, there are better choices on the market for a booster than the Novak unit, and units as good as the TQ for about a third of the price (if you're willing to put in 5 minutes soldering).
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 10-25-2011, 12:06 PM   #1052
scootr117's Avatar
Originally Posted by CarbonJoe View Post
I thought that the correct term is "Code Brown"? That's sort of a "melt down", right?
Is that how the football team up there got the name
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 10-25-2011, 12:10 PM   #1053
scootr117's Avatar
Thanks for sharing your experience. I have had the booster and will use it until it fails then replace it with something like the TQ.
RK Designs
CD SuperPro Motors
Old 10-25-2011, 12:16 PM   #1054
Regional Moderator
CarbonJoe's Avatar
Sure, just like Code Brown Stadium down in your neck of the woods.
HobbyKing boosters work great, and you can't beat the price.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-25-2011, 12:18 PM   #1055
Regional Moderator
CarbonJoe's Avatar
Looks like I was right!
Old 10-25-2011, 09:17 PM   #1056
CypressMidWest's Avatar
excellence.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 10-26-2011, 08:18 AM   #1057
Send a message via Skype™ to slotracer577
Everyone at our track who had smart boosts took them out once V203 came out. They would hit the LVC and knock out the RX. Now we are running oval. Was a real problem. I used dimension engineering boosters which all failed once I switched to V203. The TQ and Wreckless Abandon boosters both work well and had no issues.
Team Epic
slotracer577 is offline   Reply With Quote
Old 10-30-2011, 11:45 AM   #1058
What's the lowest in start RPM that people are using ?
Friulimotosport is offline   Reply With Quote
Old 10-30-2011, 11:55 AM   #1059
Still Bill's Avatar
For what class? For what track?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is online now   Reply With Quote
Old 10-30-2011, 12:20 PM   #1060
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
2-3k
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-30-2011, 12:21 PM   #1061
WGT and indoor carpet 80' by 30'
Old 10-30-2011, 07:15 PM   #1062
idbdoug's Avatar
Trader Rating: 33 (100%+)
Who sells or where can you get the wreckless abandon boosters???
thanks
idbdoug
idbdoug is offline   Reply With Quote
Old 10-30-2011, 08:03 PM   #1063
Still Bill's Avatar
Nor-Cal's track is only a tad wider; so, I would recommend an end of approximately 8,000 rpm and start of approximately 2,500 rpm. Come down by hundreds from 8,000 to fine tune for your situation...doubt you will get below 7,600...pretty easy.
FYI...I have some very good 17.5/13.5/10.5 motors; so, I am only speaking to good motors. Can't help a so-so motor...Sorry!
Bill
Old 10-30-2011, 08:22 PM   #1064
liljohn1064's Avatar
Trader Rating: 17 (100%+)
thanks
idbdoug
Some other boosters out there. No switch, but I've seen them work just fine. The current rating might be a limiting factor depending on the servo.
BEC Booster
Turnigy Booster
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
Last edited by liljohn1064; 10-31-2011 at 10:22 AM. Reason: More information, better link
liljohn1064 is offline   Reply With Quote
Old 10-31-2011, 10:08 AM   #1065
thanks
idbdoug
Its a local guy, I bought mine through e-team hobby plex, http://www.eteamhobbyplex.com/ I talked to the builder/designer of the booster yesterday. The gen 1, which I use is rated at 1.5 amps. He is now working on a 5+ amp version, which should be out shortly. I guess the Savox servo's draw tons of current due to how they control the servo vs futaba and others. Cant wait for his new booster. He is removing the switch from the power circuit, and putting it on the booster to just control the IC. Should be able to handle all the power you need.
Team Epic
