Old 12-17-2010, 07:00 PM   #961
pakk's Avatar
Trader Rating: 79 (100%+)
Post your setup and track dimensions.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 12-17-2010, 08:21 PM   #962
boost 50
turbo 14
start rpm 1500
end rpm 8000
rollout is 80 (im new to this so 74 spur 46 pinion 41mm wheelies)
I race med size track with a decent straight.
Just recently my novak beeps red and now im losing throttle! Always finished races until I got this booster 12th scale jinx. Drive clean is my motto, but now I dont even finish! Viagra
likeakid is offline   Reply With Quote
Old 12-17-2010, 08:45 PM   #963
pakk's Avatar
What motor and how much timing on the motor?
What radio?
So you only have had this problem since you put the booster in? The novak booster is known to have lipo cut issues. I've never seen it the cause of lack of turbo.
Most of the time when cars tend to start falling off toward the end of the race, it's because of too much timing. I'm not saying that's your problem, just have seen it a lot.
Your timing looks fins as long as you have the motor set to 0 or close to it. I forget what brand radios have had problems with the end point wondering, but I think it is the KO's. You should probably try the calibration trick anyway since you are having the problem.
*Photon* *SC10 4x4*
RCRD
Old 12-17-2010, 09:37 PM   #964
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by likeakid View Post
Ok, probally the most asked question but i'm new to 12th scale. Using 17.5 x12 tekin rs and novak booster. After 4 min or soo boost is gone and I can drive full throttle the whole track... Sucks Donkey D's. Is this fixable?
What vers hotwire ?
Novak booster issues are common.
Try TQ booster, or rec pack.
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-18-2010, 01:36 AM   #965
darrenoakley's Avatar
I have the wiring diagram to remove the lipo protection on the Novak booster and that stops it cutting out. Pm me your email address and I will send it to you.
As for it dropping off mid/late race I would say it's the motor going soft due to it only being 17.5. I had the exact same problem with the same motor and rollout. I switched to 10.5 because of it on the end.
Hope this helps
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 12-18-2010, 08:04 AM   #966
avs
avs's Avatar
with such a low rpm range for boost, you may be overtaxing your battery.
to prove it to yourself, you might try switching in a fresh battery after 4minutes and verify that you regain the speed and punch that you had.
adding boost with a larger rpm range (like 3k to 10k for start and end) will put less stress on the battery. your initial lap times might be a little slower, but you won't lose so much after 5 minutes.
Tony Shimko
avs is offline   Reply With Quote
Old 12-18-2010, 05:41 PM   #967
what motor?
I have both a duo 1, and duo 3 and my profile looked like yours when I started tinkering. I was having the fade problem too. If the motor temp gets over 140 ish on a 17.5 on 1s you will see the motor "lay down".
My profile now is
boost 35
turbo 10 ramp 3 .05 delay.
Gearing is 76/45 with 1.70 tires Rollout is around 3.16
My car is just as fast and consistent the whole race. I found in my experimenting that having the boost above 35 seemed to make a lot of heat without any positive effect on laptimes.
The booster issue is just that. The booster isn't keeping your reciever from hitting LVC failsafe. I prefer a life or lipo receiver pack in my 12th scales.
Almost everyone at my local track has dropped back under 40 on their boost since I made my discovery and our temps dropped around 15- 20 degrees an every brand 17.5
racer357 is offline   Reply With Quote
Old 01-17-2011, 05:22 PM   #968
Hi,
About lowering your boost setting.
You use almost no delay on the turbo setting.
Does that mean that you directly press full throttle exiting a corner?
A lot of people seem to use that lately, when i ran my tekin in a TC, i only used the turbo on the straight with or without a delay, i had so much punch that i did not need to open the throttle in full in the infield.
In 12th scale, it seems that most drivers open it in full in stock and then use the turbo to directly add up to the boost exiting the corner.
I only ran it once like that and it is much easier to drive since you never pace your throttle you use it almost on/off.
I was wondering if everyone was doing it this way in stock.
Jeppi is offline   Reply With Quote
Old 01-17-2011, 11:10 PM   #969
Blue Screw's Avatar
Send a message via AIM to Blue Screw
hey guys can u help me with a speeedo setup.. this track is a small one 60by30..13.5 212 verzion.. pretty much no turbo
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 01-18-2011, 06:09 AM   #970
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
2-3 start
8500 end,you can lower if you want it more aggressive
45,you can add more as you run to get a feel for it,around 50-53
5 motor
everything else is to your feel,
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 01-19-2011, 01:14 AM   #971
Originally Posted by 20 SMOKE View Post
2-3 start
5 motor
+1
I don't bother with any turbo when running 1s unless the track has a really long straight. I found on short tracks it just dumps a load of timing/heat just at the end of the straight. Don't get me wrong when I run on a large track it is great.
Xray x11
Xray T3 011
Old 01-19-2011, 01:53 PM   #972
Originally Posted by darrenoakley View Post
+1
+1. If I need good pickup on a tight infield, I add 5 deg to the motor and gear down. Otherwise, I use full boost and no turbo. Car is fast and motor is cool.
SlowerOne is offline   Reply With Quote
Old 01-19-2011, 03:11 PM   #973
20 SMOKE's Avatar
i have found anything over 10-12* which is still a couple on the high side on the motor will create heat and your not gaining much
Jamie W
Old 01-20-2011, 01:48 PM   #974
+1
Old 08-08-2011, 11:50 AM   #975
will Tekin release an ESC that feature auto cell detection that will support 1-cell lipo?? something like LRP SXX Competition Version 2 OR SpeedPassion GT2.1 EX??
I'm a big fan of Tekin
hansenhon is offline   Reply With Quote
